eclipse 3.4M6 won't run from NFS disk [message #327899] |
Wed, 07 May 2008 17:21  |
We are trying to host our eclipse install(s) on a server, then export the
installs via NFS, or Samba, etc.
We have the exported path mounted on a client, and eclipse installed, this
is all Linux, but running eclipse results in the following...
.../3.4M6/eclipse-java$ ./eclipse
!ENTRY org.eclipse.osgi 4 0 2008-05-07 14:29:23.326
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:362)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
Can someone give me any ideas on what is wrong here.??
I have install 3.4M6 in many other directories and it runs with no
problems at all.
Mark.
Re: eclipse 3.4M6 won't run from NFS disk [message #327901 is a reply to message #327899] |
Wed, 07 May 2008 17:52  |
Eclipse Webmaster Messages: 607353 Registered: July 2009 |
NFS is likely not the problem. I run lots of Eclipse instances from
various NFS mounts on a whole bunch of platforms.
> the installs via NFS, or Samba, etc.
> this is all Linux, but running eclipse results in the following...
> !STACK 1
> (see config.ini).
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> problems at all.
> Mark.
FUDForum. Page generated in 0.05422 seconds
