Home » Eclipse Projects » Eclipse Platform » SAXON in Eclipse
SAXON in Eclipse [message #327885] Wed, 07 May 2008 08:56 Go to next message
Hi all,
I'm trying to get a transform working from an RCP application. Works fine
for simple transform but I need to use SAXON 2.0 processor.
I'm guessing what I need to do is get some kind of SAXON plugin?
I'm not sure exactly what I need. I've seen a couple of Commerical pugins
but I need something free.
Can someone recommend what I should use.
Gaff
Forgot to mention... [message #327886 is a reply to message #327885] Wed, 07 May 2008 09:04 Go to previous messageGo to next message
... I dont't need an editor or anything like that. I just want to execute
the transform from java. (so I'm guessing I need some kind of plugin, if
possible to do transform without a new plugin all the better?) Along the
lines of:
try {
in = new FileInputStream("C:/test.xsl");
out = new FileInputStream(fileNamePublish);
FileInputStream xmlFile = out;
FileInputStream xsltFile = in;
Source xmlSource = new StreamSource(xmlFile);
Source xsltSource = new StreamSource(xsltFile);
TransformerFactory transFact =
TransformerFactory.newInstance();
try{
Transformer trans = transFact.newTransformer(xsltSource);
trans.transform(xmlSource, new StreamResult(System.out));
}catch(TransformerException me ) {}
Re: SAXON in Eclipse [message #327890 is a reply to message #327885] Wed, 07 May 2008 09:45 Go to previous messageGo to next message
Gaff wrote:
> Hi all,
> fine for simple transform but I need to use SAXON 2.0 processor.
> pugins but I need something free.
I would just include the SAXON JAR in the project (in a lib/ directory
and included on the project's classpath) and then you can call it's code
directly. When your app is built/exported, the JAR will be included - no
extra plugin necessary.
Hope this helps,
Eric
Re: SAXON in Eclipse [message #327908 is a reply to message #327890] Thu, 08 May 2008 05:24 Go to previous messageGo to next message
Hi Eric,
I right-clicked on my project and used Build path to add external
libraries. I can now import saxon API's.
However I'm not sure I've done this correctly as my code does not execute.
I'm using net.sf.saxon.TransformerFactoryImpl, when I try to execute code
with this it stops at this line and does not go any further.
The code I'm using is from:
http://blog.msbbc.co.uk/2007/06/simple-saxon-java-example.ht ml
So should work?
Gaff
Re: SAXON in Eclipse [message #327920 is a reply to message #327908] Thu, 08 May 2008 09:01 Go to previous message
Gaff wrote:
> Hi Eric,
> code with this it stops at this line and does not go any further.
I'm not sure what that means. Does it throw an exception?
Adding a library to the project's build path is only half the work - you
also need to include the same library(ies) on the runtime classpath; you
need to make sure it is specified in the Launch Configuration that you
use to run your application.
Eric
Previous Topic:how to write a runner
Next Topic:Eclipse 3.4 dropins folder not working?
Current Time: Thu Jul 24 11:14:50 EDT 2025
Powered by FUDForum. Page generated in 0.04288 seconds
