Home » Eclipse Projects » Eclipse Platform » Exporting as aproduct
Exporting as aproduct [message #327884] Wed, 07 May 2008 07:46 Go to next message
Originally posted by: swetha.yahoo.co.in
When I am exporting my application as an eclipse product.. I am getting
the following error..I included org.eclipse.core.runtime as a dependency..
!MESSAGE Authorization infrastructure
(org.eclipse.core.runtime.compatibility.auth) not installed.
!STACK 0
java.lang.NoClassDefFoundError:
org/eclipse/core/internal/runtime/auth/AuthorizationHandler
org.eclipse.core.internal.runtime.InternalPlatform.initializ eAuthorizationHandler(InternalPlatform.java:603)
org.eclipse.core.internal.runtime.InternalPlatform.start(Int ernalPlatform.java:745)
org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:31)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:282)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:468)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:297)
Swetha
Re: Exporting as aproduct [message #327905 is a reply to message #327884] Thu, 08 May 2008 00:31 Go to previous messageGo to next message
Can anyone help me
Re: Exporting as aproduct [message #327911 is a reply to message #327905] Thu, 08 May 2008 05:41 Go to previous messageGo to next message
Swetha,
That stack trace isn't much to go on. I've seen the same stack in the
newsgroup quite a few times, all related to some or other issue with a
bad installation. Does the same installation run fine without your
exported product? There are no preceding stack traces in the log that
might give a clue?
Swetha wrote:
> Can anyone help me
Re: Exporting as aproduct [message #327912 is a reply to message #327911] Thu, 08 May 2008 06:31 Go to previous messageGo to next message
Thanks for the reply.. The same application is running fine without
exporting it..
After It has been exported as a product, if I run the eclipse.exe file
, only that stack trace is coming in the log file generated in
configuration folder of exported one..
Swetha
Re: Exporting as aproduct [message #327914 is a reply to message #327912] Thu, 08 May 2008 07:12 Go to previous messageGo to next message
Swetha,
I'm not sure how this product export thing works since I never used it
and I'll bet that's the case for most readers of this newsgroup. Do you
need an eclipse installation into which you install the exported result
or to which you target the exported result? Does that installation run
before you exported your result to it?
Swetha wrote:
> exporting it..
> file , only that stack trace is coming in the log file generated in
> Swetha
Re: Exporting as aproduct [message #327916 is a reply to message #327884] Thu, 08 May 2008 07:26 Go to previous messageGo to next message
Originally posted by: phillipus.nowhere.net
Swetha wrote:
> !STACK 0
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Swetha
I can reproduce this error if I remove some plugins from my product's
configuration. Ensure that you include the following in your product
configuration list of plugins:
org.eclipse.core.runtime.compatibility.registry
P.
Re: Exporting as aproduct [message #327979 is a reply to message #327916] Sun, 11 May 2008 18:43 Go to previous message
Phillipus wrote:
> Swetha wrote:
>> getting the following error..I included org.eclipse.core.runtime as a
>> dependency..
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks,
>> Swetha
> P.
You're welcome.
Why, thanks!
Previous Topic:SWT_AWT Popup menu problem
Next Topic:Eclipse Icons
Current Time: Thu Jul 17 21:39:40 EDT 2025
Powered by FUDForum. Page generated in 0.36498 seconds
