Home » Archived » BIRT » CSS - Cascading Style Sheets
CSS - Cascading Style Sheets [message #33194] |
Tue, 03 May 2005 01:10  |
say i have 10 or 50 reports whose headers are exactly the same, assume in
the header contains the company name, logo & etc... how can i change the
company name, font size or style for example in 1 go and make the changes
applied to all my reports...how to use the CSS in detail...
thanks,
wins
Re: CSS - Cascading Style Sheets [message #33641 is a reply to message #33194] |
Tue, 03 May 2005 17:00   |
Wins,
You have just discovered the need for one of the features proposed for the
next version of BIRT: libraries. In BIRT 1.0, designs are self-contained.
The idea in a later version is that BIRT elements can be moved into a
shareable library. The ROM specs describe this concept in detail. The idea
is that styles will also be shareable. With libraries, you can update
styles, headers and other "boilerplate" once and have it used by many
reports.
For now, you can use a home-grown solution that uses your favorite scripting
tool to update your design XML files. I don't have an example handy, but
perhaps someone could create a little utility that does this. The design
files are XML, so you can use an XML or text-based tool to make the required
updates.
- Paul
Paul Rogers
BIRT PMC
"wins" <winstonguadiz@yahoo.com> wrote in message
news:ef8d56340a0499c024ca46b490556b71$1@www.eclipse.org...
> thanks,
> wins
Re: CSS - Cascading Style Sheets [message #33913 is a reply to message #33641] |
Tue, 03 May 2005 22:41   |
Hi Paul,
thanks for the info. i'll try to find out on how to update my design XML
files for i'm really new to java and to all its stuff....you mean the
libraries will be available on BIRT 2.0 by December this year?...is it ok
to make our reports now using BIRT 1.0 and then wait for the release 2.0
to apply the libraries feature?
thanks,
wins
Paul Rogers wrote:
> Wins,
> reports.
> updates.
> - Paul
> Paul Rogers
> BIRT PMC
>> thanks,
>> wins
Re: CSS - Cascading Style Sheets [message #33931 is a reply to message #33913] |
Tue, 03 May 2005 23:16   |
Wins,
Libraries are on the candidate list for 2.0, and December is the working
target. Won't know actual feature set until we get community input, and
won't know the final date until we see the feature list -- you know how
software planning goes...
Designs created with 1.0 will be fully compatibile with 2.0. You will be
able to convert 1.0 designs to use libraries when they become available. So,
you can have "reuse" by copy & paste in R1, then "true reuse" with libraries
- Paul
Paul Rogers
BIRT PMC
news:32acba55e50e924361bbfdf2912d0fd6$1@www.eclipse.org...
> Hi Paul,
> thanks,
> wins
> Paul Rogers wrote:
>> Wins,
>> the next version of BIRT: libraries. In BIRT 1.0, designs are
>> self-contained. The idea in a later version is that BIRT elements can be
>> moved into a shareable library. The ROM specs describe this concept in
>> detail. The idea is that styles will also be shareable. With libraries,
>> you can update styles, headers and other "boilerplate" once and have it
>> used by many reports.
>> scripting tool to update your design XML files. I don't have an example
>> handy, but perhaps someone could create a little utility that does this.
>> The design files are XML, so you can use an XML or text-based tool to
>> make the required updates.
>> - Paul
>> Paul Rogers
>> BIRT PMC
>>> Hi,
>>> in the header contains the company name, logo & etc... how can i change
>>> the company name, font size or style for example in 1 go and make the
>>> changes applied to all my reports...how to use the CSS in detail...
>>> thanks,
>>> wins
Re: CSS - Cascading Style Sheets [message #33954 is a reply to message #33931] |
Wed, 04 May 2005 00:16  |
Hi Paul,
i really need help on how to update design XML files using scripting, w/c
part of XML file i need to update..how changes can be applied to all the
reports in order to simulate the library/ies features..can anyone help me
w/ this...
thanks,
wins
Paul Rogers wrote:
>> Paul Rogers wrote:
>>> Wins,
>>> - Paul
>>> Paul Rogers
>>> BIRT PMC
>>>> Hi,
>>>> thanks,
>>>> wins
Current Time: Fri Jul 18 10:44:57 EDT 2025
Powered by FUDForum. Page generated in 0.11095 seconds
