| Providing contextual help in tooling [message #327871] | Tue, 06 May 2008 17:20  |  |
| Eclipse User  |  |  |  |  | Originally posted by: david_whiteman.us.ibm.com
 What is the preferred method of providing contextual (F1) help in
 tooling?  Is there good documentation somewhere showing how one would
 instrument their tooling so that F1 brought up the appropriate
 documentation?  I have a couple of Eclipse books, but something someone
 told me recently made me think that there is a different preferred
 method these days.
 David
| Re: Providing contextual help in tooling [message #327877 is a reply to message #327876] | Tue, 06 May 2008 21:07   |  |
 Chris Aniszczyk wrote:
 > If you create a view using one of the PDE templates, there should be a
 > checkbox that says "create context help." With that, the template should
 > generate the proper context xml files for you along with the html file.
 > Furthermore, it will also add the hook where it informs the Platform
 > that you're providing context-sensitive (F1) help.
 > Let me know if this helps, if not, I can blog about this.
 > Cheers,
 > ~ Chris
 I've had the view for a long time and did not use the templates when I
 created it initially.  However, I can certainly generate a dummy view
 just to see what is needed, and then copy that approach for my plugin.
 Thanks, Chris!
 David
| Re: Providing contextual help in tooling [message #327931 is a reply to message #327877] | Thu, 08 May 2008 13:17   |  |
 >> should generate the proper context xml files for you along with the
 >> html file. Furthermore, it will also add the hook where it informs the
 >> Platform that you're providing context-sensitive (F1) help.
 >> Cheers,
 >> ~ Chris
 > Thanks, Chris!
 > David
 OK, I have set this up.  What I've observed is you can add help hooks to
 any control, which takes you to a context that can link you to a topic
 in the documentation.
 What I'd like to do is have the help hook go straight to the
 documentation.  If the documentation describes the indicated control,
 why should the user have to read something like "This is the panic
 button." and click on a link to see the real documentation?  Plus, this
 introduces more maintenance if you have more to document in the
 contexts.xml file.
 It would be nice if I could define a <context> and then indicate that a
 <topic> auto-loads.  That would solve the problem I mentioned nicely.
 [Cross posting to eclipse.platform.ua, since I just learned of that
 group, and this really belongs there.]
 David
| Re: Providing contextual help in tooling [message #327940 is a reply to message #327933] | Thu, 08 May 2008 17:17  |  |
 Chris Goldthorpe wrote:
 > If you use Eclipse 3.4M7 or later a context with a single topic and no
 > description will take you straight to the page in the link.
 Wow, exactly what I was looking for.  Thanks!
FUDForum. Page generated in 0.04619 seconds
