| How to disable a feature without Eclipse Configuration Manager? [message #327854] |
Tue, 06 May 2008 07:54  |
I installed a plugin that causes Eclipse to crash on startup. I've already
posted a bug to the plugin vendor.
I want to disable the feature, but I can't since Eclipse does not start,
therefore I can't access the Help->Software Updates->Manage Configuration
menu.
¿Is there a way to do this? ¿Maybe editing a configuration file?
Mariano.
| Re: How to disable a feature without Eclipse Configuration Manager? [message #327856 is a reply to message #327854] |
Tue, 06 May 2008 10:02  |
You could remove the plug-ins and features from the the "plugins" and
"features" directories and then start Eclipse with "-clean" on the
command line.
HTH,
Wayne
On Tue, 2008-05-06 at 11:54 +0000, Mariano Eloy Fernández wrote:
> menu.
> Mariano.
FUDForum. Page generated in 0.04604 seconds
