Home » Eclipse Projects » Eclipse Platform » Running ant task within Eclipse
Running ant task within Eclipse [message #327828] Mon, 05 May 2008 07:40 Go to next message
If I run an Ant task within Eclipse I sometimes have to manually refresh the
folders in Eclipse to get the desired result. Details on my problem below.
Is it possible in Eclipse to refresh a specific folder after a certain ant
task? This would be in the middle of the complete ant excecution.
Alternatively I can run ant outside Eclipse, which also solves my problem.
Best regards, Lars
Details:
I do an Xinclude of docbook files. As the source code which is included in
these XIncludes gets special delimiter signs I have to remove these via a
small Java program.
<target name="specialsign" depends="xinclude">
<java classname="removeStrings.RemoveSpecialSigns">
</java>
</target>
The coding is really simple:
public class RemoveSpecialSigns {
public static void main(String[] args) throws FileNotFoundException {
FileListing fileListing = new FileListing();
fileListing.setDir("./output.tmp");
List<File> files = fileListing.getFileListing();
MyFile workingFile = new MyFile();
for (File file : files) {
System.out.println(file);
String fileName = file.getAbsolutePath();
workingFile.copy(fileName);
workingFile.delete(fileName);
workingFile.move(fileName);
MyFile does replace the characters:
String newLine = line.replaceAll("&#13;", "") + "\n";
Re: Running ant task within Eclipse [message #327844 is a reply to message #327828] Mon, 05 May 2008 13:30 Go to previous messageGo to next message
Do the options on the "Refresh" tab of the "Run As... > Ant Build..."
dialog help?
Wayne
On Mon, 2008-05-05 at 13:40 +0200, Lars Vogel wrote:
> Best regards, Lars
> Details:
> small Java program.
> </java>
> </target>
Re: Running ant task within Eclipse [message #327845 is a reply to message #327844] Mon, 05 May 2008 16:43 Go to previous messageGo to next message
Hi Wayne,
thanks for the reply.
I assumed this would refresh the workspace / project after the ant script is
finished. I'm looking for a refreash after a certain ant task (before the
next is excecuted).
Is my assumption incorrect? Best regards, Lars
"Wayne Beaton" <wayne@eclipse.org> wrote in message
news:1210008656.6034.0.camel@BADWOLF...
> dialog help?
> Wayne
>> the
>> below.
>> ant
>> problem.
>> Best regards, Lars
>> Details:
>> in
>> small Java program.
>> </java>
>> </target>
Re: Running ant task within Eclipse [message #327846 is a reply to message #327845] Mon, 05 May 2008 17:29 Go to previous messageGo to next message
Hi Lars,
you can use the eclipse.refreshLocal ant task (see
http://help.eclipse.org/help33/topic/org.eclipse.platform.do c.isv/guide/ant.htm).
Be sure to let the ant build run in the same JRE as your eclipse runs in
(see Launch dialog of the ant launch configuration).
Greets
Benny
Lars Vogel wrote:
> Hi Wayne,
> next is excecuted).
>> dialog help?
>> Wayne
>>> Hi,
>>> the
>>> below.
>>> ant
>>> problem.
>>> Best regards, Lars
>>> Details:
>>> in
>>> small Java program.
>>> </java>
>>> </target>
Re: Running ant task within Eclipse [message #327898 is a reply to message #327846] Wed, 07 May 2008 16:48 Go to previous message
Hi Benny,
thank you, cool tip!
Best regards, Lars
"Benjamin Muskalla" <bmuskalla@innoopract.com> wrote in message
news:fvnu76$h51$1@build.eclipse.org...
> Hi Lars,
> Greets
> Benny
> Lars Vogel wrote:
>> Hi Wayne,
>> is finished. I'm looking for a refreash after a certain ant task (before
>> the next is excecuted).
>>> dialog help?
>>> Wayne
>>>> Hi,
>>>> refresh the
>>>> below.
>>>> ant
>>>> problem.
>>>> Best regards, Lars
>>>> Details:
>>>> in
>>>> a
>>>> small Java program.
>>>> </java>
>>>> </target>
Previous Topic:ProjectAnnotation not persisted?
Next Topic:Ganymede IHandler2/AbstractHandler execute() method not recognized in @Override
Current Time: Mon Sep 22 15:32:38 EDT 2025
Powered by FUDForum. Page generated in 0.03707 seconds
