Home » Eclipse Projects » Eclipse Platform » [Databinding] Use converter when binding to TableViewer
[Databinding] Use converter when binding to TableViewer [message #327788] Thu, 01 May 2008 15:00 Go to next message
Originally posted by: tskaufma.gmail.com
I have a model which has java.util.Date objects and I've created a custom
converter for Date to String conversion.
I would like to use my converter with a TableViewer. I currently use the
ObservableListContentProvider and ObservableMapLabelProvider classes to fill
the TableViewer. Is there some easy way to attach the converter this setup?
If not, is there a per-column label provider for use with Databinding so I
only have to write a custom label provider for my Date columns?
Trevor Kaufman
Re: [Databinding] Use converter when binding to TableViewer [message #327791 is a reply to message #327788] Thu, 01 May 2008 15:57 Go to previous messageGo to next message
Sure ColumnLabelProvider?
Tom
Trevor Kaufman schrieb:
> Hello,
> custom converter for Date to String conversion.
> fill the TableViewer. Is there some easy way to attach the converter
> this setup?
> I only have to write a custom label provider for my Date columns?
> Trevor Kaufman
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [Databinding] Use converter when binding to TableViewer [message #327798 is a reply to message #327791] Thu, 01 May 2008 18:26 Go to previous messageGo to next message
Hello Tom,
ColumnLabelProvider is a per column, yes, but there is no
ObservableColumnLabelProvider that I can find.. and
ObservableMapLabelProvider doesn't implement ColumnLabelProvider.
If I switch to a per column system, I'd only want to write custom label
providers for my Date columns and use an Obversable label provider for the
other columns.
Hope that clarifies my issue,
Trevor Kaufman
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:fvd7bt$eln$1@build.eclipse.org...
> Tom
>> Hello,
>> fill the TableViewer. Is there some easy way to attach the converter this
>> setup?
>> Thanks,
>> Trevor Kaufman
Re: [Databinding] Use converter when binding to TableViewer [message #327800 is a reply to message #327798] Fri, 02 May 2008 06:22 Go to previous message
http://publicsvn.bestsolution.at/repos/java/at.bestsolution. dataforms/trunk/src/at/bestsolution/dataforms/util/viewers/
Tom
> Hello Tom,
> the other columns.
> Trevor Kaufman
>> Tom
>>> Hello,
>>> the ObservableListContentProvider and ObservableMapLabelProvider
>>> classes to fill the TableViewer. Is there some easy way to attach the
>>> so I only have to write a custom label provider for my Date columns?
>>> Thanks,
>>> Trevor Kaufman
Previous Topic:[Fwd: compile plugins using commandline]
Next Topic:Databinding and Date Selection Widgets
Current Time: Tue Jul 15 09:36:23 EDT 2025
Powered by FUDForum. Page generated in 0.07505 seconds
