Plug-in Dependency Difficulty of Java Service usage [message #1713407] |
Tue, 03 November 2015 19:59 |
eunjung park Messages: 72 Registered: April 2015 |
Member |
I'm trying to use Java Service. I read an article that for the Java Service, odesign project has the plug-in which contains its ecore file.
To do it, I made the plug-in for my bpmn ecore file.
By the way, when I click an add button for the dependency plug-in, there is no plug-in which I added in the ~/eclipse/plugin/.
The following is the picture.
Does any body know why this happen?
I tried to execute -clean when execute the eclipse.
Thanks in advance.
Best Regards,
Eunjung Grace
[Updated on: Wed, 04 November 2015 09:47] Report message to a moderator
Re: Plug-in Dependency Problem for Java Service [message #1713458 is a reply to message #1713407] |
Wed, 04 November 2015 09:26 |
Esteban Dugueperoux Messages: 472 Registered: July 2009 |
This seems a deployement issue, to have your metamodel plugin deployed
you can :
- in development mode, launch a second runtime from your workspace
containing your metamodel plugin.
- in production mode, have your metamodel plugin deployed through a
feature or exported directly in the dropins folder of your Eclipse target.
Note your question is not Sirius related but only a deployment issue.
Best Regards.
Le 03/11/2015 20:59, eunjung park a écrit :
> Hello,
> Thanks in advance.
> Best Regards,
> Eunjung Grace
Esteban Dugueperoux - Obeo
FUDForum. Page generated in 0.04255 seconds
