Home » Eclipse Projects » Eclipse Platform » EFS – FILESTORE – EDITORS …
EFS – FILESTORE – EDITORS … [message #327700] Tue, 29 April 2008 08:05 Go to next message
Hi all one more question on efs and opening editors …
I have my XXXFileStore that links to objects in a db (returns a FileSystem
reppresentation)
I manage (thanks to Ed) to create an EditorInput on the file store so now I’m
able to open xml and txt file easily.
MyFileEditorInput implements IEditorInput, ILocationProvider,
IStorageEditorInput, IURIEditorInput
Question 1:
When I do press the save button the XXXFileStore.setContents is correctly
called
But why the editor still displays a * on the title like the editor is still
dirty (i do update the fetch info with the new time but still doesn’t
change)
Question 2:
Save as: how to deal with this button … clearly the file is in my db but the
save button will pop up the save as dialog on the file system ... any way I
can trap this and display my own dialog
I could probably do something overriding the default editors (xml/txt/html)
but I would love to use the already existing one otherwise I will just end
up creating a new one for each type :-(
Question 3:
Is there a way of distinguish between the normal save operation and when the
editor is closed.
Guess my editorInput is missing of something ...
Kar
Re: EFS – FILESTORE – EDITORS … [message #327702 is a reply to message #327700] Tue, 29 April 2008 08:56 Go to previous messageGo to next message
> FileSystem reppresentation)
> now I’m able to open xml and txt file easily.
> Question 1:
> correctly called
> still dirty (i do update the fetch info with the new time but still
> doesn’t change)
Is this with the normal text editor? If so, how do you open your file store?
Dani
> Question 2:
> but the save button will pop up the save as dialog on the file system
> ... any way I can trap this and display my own dialog
> (xml/txt/html) but I would love to use the already existing one
> otherwise I will just end up creating a new one for each type :-(
> Question 3:
> when the editor is closed.
> Thanks
> Kar
Re: EFS – FILESTORE – EDITORS … [message #327706 is a reply to message #327702] Tue, 29 April 2008 09:13 Go to previous messageGo to next message
Messaggio multiparte in formato MIME.
------=_NextPart_000_00D8_01C8AA0B.8E798570
Content-Type: text/plain;
format=flowed;
charset="utf-8";
reply-type=response
Hi Daniel
IEditorPart editorPart = page.openEditor(editorInput,
getEditorId(fileStore));
the editor depends on the file ext ...
my previous version of code was using just plain editorInput and I was
extending all the well known editor (default text editor and Structured text
editor from the swt project) ...
now I would love just use the EFS and use plain editor but I'm not sure that
what I'm doing is possible or correct.
private String getEditorId(IFileStore fileStore)
IWorkbench workbench = Activator.getDefault().getWorkbench();
IEditorRegistry editorRegistry = workbench.getEditorRegistry();
IEditorDescriptor descriptor =
editorRegistry.getDefaultEditor(fileStore.getName());
if (descriptor != null)
return descriptor.getId();
return EditorsUI.DEFAULT_TEXT_EDITOR_ID;
"Daniel Megert" <daniel_megert@ch.ibm.com> ha scritto nel messaggio
news:fv75tt$qjp$3@build.eclipse.org...
>> Question 1:
>> called
>> still dirty (i do update the fetch info with the new time but still doesn’t
>> change)
> store?
> Dani
>> Question 2:
>> the save button will pop up the save as dialog on the file system ... any
>> (xml/txt/html) but I would love to use the already existing one otherwise
>> Question 3:
>> Thanks
>> Kar
Content-Type: text/java;
name="MyNonExistingFileEditorInput.java"
Content-Disposition: attachment;
filename="MyNonExistingFileEditorInput.java"
* Copyright (c) 2000, 2006 IBM Corporation and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* IBM Corporation - initial API and implementation
package testefs.views;
import java.io.InputStream;
import java.net.URI;
import org.eclipse.core.filesystem.EFS;
import org.eclipse.core.filesystem.IFileStore;
import org.eclipse.core.filesystem.URIUtil;
import org.eclipse.core.resources.IStorage;
import org.eclipse.core.runtime.Assert;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.IPath;
import org.eclipse.core.runtime.Path;
import org.eclipse.jface.resource.ImageDescriptor;
import org.eclipse.ui.IEditorInput;
import org.eclipse.ui.IPersistableElement;
import org.eclipse.ui.IStorageEditorInput;
import org.eclipse.ui.IURIEditorInput;
import org.eclipse.ui.editors.text.ILocationProvider;
* @since 3.1
public class MyNonExistingFileEditorInput implements IEditorInput,
ILocationProvider,
private IFileStore fFileStore;
private String fName;
public MyNonExistingFileEditorInput(IFileStore fileStore, String =
name)
Assert.isNotNull(fileStore);
fFileStore =3D fileStore;
fName =3D name;
* @see org.eclipse.ui.IEditorInput#exists()
public boolean exists()
return true;
* @see org.eclipse.ui.IEditorInput#getImageDescriptor()
public ImageDescriptor getImageDescriptor()
return null;
* @see org.eclipse.ui.IEditorInput#getName()
public String getName()
return fName;
* @see org.eclipse.ui.IEditorInput#getPersistable()
public IPersistableElement getPersistable()
return null;
* @see org.eclipse.ui.IEditorInput#getToolTipText()
public String getToolTipText()
return fName;
* @see =
org.eclipse.core.runtime.IAdaptable#getAdapter(java.lang.Cla ss)
public Object getAdapter(Class adapter)
//System.err.println("asking adapter: " + adapter);
if (ILocationProvider.class.equals(adapter))
return this;
return null;
// return Platform.getAdapterManager().getAdapter(this, =
adapter);
* @see
org.eclipse.ui.editors.text.ILocationProvider#getPath(java.l ang.Object)
public IPath getPath(Object element)
if (element instanceof MyNonExistingFileEditorInput)
MyNonExistingFileEditorInput input =3D
(MyNonExistingFileEditorInput) element;
return URIUtil.toPath(input.fFileStore.toURI());
//return new Path(input.fFileStore.toURI().getPath());
return null;
* @see java.lang.Object#equals(java.lang.Object)
public boolean equals(Object o)
if (o =3D=3D this)
return true;
if (o instanceof MyNonExistingFileEditorInput)
(MyNonExistingFileEditorInput) o;
return fFileStore.equals(input.fFileStore);
return false;
* @see java.lang.Object#hashCode()
public int hashCode()
return fFileStore.hashCode();
public IStorage getStorage() throws CoreException
return new IStorage()
public InputStream getContents() throws CoreException
InputStream is =3D fFileStore.openInputStream(EFS.NONE, =
null);
System.out.println(" asked content: " + is);
return is;
public IPath getFullPath()
// TODO Auto-generated method stub
System.err.println(">>>>> to path: " +
URIUtil.toPath(fFileStore.toURI()));
return URIUtil.toPath(fFileStore.toURI());
return fFileStore.getName();
public boolean isReadOnly()
return false;
return null;
public URI getURI()
System.out.println(" asked uri: " + fFileStore.toURI());
return fFileStore.toURI();
------=_NextPart_000_00D8_01C8AA0B.8E798570--
Re: EFS – FILESTORE – EDITORS … [message #327710 is a reply to message #327706] Tue, 29 April 2008 09:43 Go to previous messageGo to next message
KarSc wrote:
> Hi Daniel
> Structured text editor from the swt project) ...
> sure that what I'm doing is possible or correct.
This should work. If not, please file a bug report with steps to reproduce.
>>> so now I’m able to open xml and txt file easily.
>>> Question 1:
>>> correctly called
>>> is still dirty (i do update the fetch info with the new time but
>>> still doesn’t change)
>> store?
>> Dani
>>> Question 2:
>>> system ... any way I can trap this and display my own dialog
This is currently not possible (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=87863) unless you have an
RCP and build your main menu yourself.
Dani
>>> Question 3:
Why do you need to tell the diff?
Dani
>>> Thanks
>>> Kar
Re: EFS – FILESTORE – EDITORS … [message #327716 is a reply to message #327710] Tue, 29 April 2008 10:14 Go to previous messageGo to next message
ok ... I shall fill a bug report for the the dirty status ...
about point 3:
the FileStore is a mapping on a file inside an object db ...
I would love to lock the file the just first time I save the document (and I
can do that using a simple flag on the setContents) but I have no control on
when the editor is really closed so I could actually do the check in on the
file ...
right now I can do check out/in on the setContent (creating lots of
versions)
I could previously taking care of this extending the editor ... but this is
to hard to manage every time a new editor is requested or assigned :-(
thanks for ur help
Kar
news:fv78lq$ho4$1@build.eclipse.org...
> KarSc wrote:
>> Hi Daniel
> reproduce.
>>>> Question 1:
>>>> correctly called
>>>> doesn’t change)
>>> store?
>>> Dani
>>>> Question 2:
> Dani
>>>> Question 3:
> Dani
>>>> Thanks
>>>> Kar
Re: EFS – FILESTORE – EDITORS … [message #327718 is a reply to message #327710] Tue, 29 April 2008 10:19 Go to previous messageGo to next message
not sure this is the right place where to say that ...
but I would say that one more step to perform in EFS is the ability to
extract from IFileStore a real resource (IFile/...) and I believe that
already a lot of this job has been done under the NavigationTree
Kar
> KarSc wrote:
>> Hi Daniel
> reproduce.
>>>> Question 1:
>>>> correctly called
>>>> doesn’t change)
>>> store?
>>> Dani
>>>> Question 2:
> Dani
>>>> Question 3:
> Dani
>>>> Thanks
>>>> Kar
Re: EFS – FILESTORE – EDITORS … [message #327720 is a reply to message #327718] Tue, 29 April 2008 10:40 Go to previous messageGo to next message
Kar,
I wonder if http://wiki.eclipse.org/index.php/EFS answers some of this?
The section "The relationship between EFS and IResource" describes the
steps you'd need to have the workspace refer to your EFS-backed resources...
> Kar
>> KarSc wrote:
>>> Hi Daniel
>>> was extending all the well known editor (default text editor and
>> reproduce.
>>>>> Question 1:
>>>>> correctly called
>>>> file store?
>>>> Dani
>>>>> Question 2:
>>>>> db but the save button will pop up the save as dialog on the file
>> an RCP and build your main menu yourself.
>> Dani
>>>>> Question 3:
>>>>> and when the editor is closed.
>> Dani
>>>>> Thanks
>>>>> Kar
Re: EFS – FILESTORE – EDITORS … [message #327747 is a reply to message #327720] Wed, 30 April 2008 05:18 Go to previous messageGo to next message
I did check few examples ...
some of them plays with creating each time a local file
other actually will link the filestore to the resource view (and for me this
is not possible - the db could be really big and the navigation view will
inspect all the db each time a refresh is pressed or a new user will log for
the first caching operation ...)
"Ed Merks" <merks@ca.ibm.com> ha scritto nel messaggio
news:fv7bto$gru$1@build.eclipse.org...
> Kar,
> resources...
>> Kar
>>> KarSc wrote:
>>>> Hi Daniel
>>> reproduce.
>>>>>> Question 1:
>>>>>> correctly called
>>>>>> doesn’t change)
>>>>> store?
>>>>> Dani
>>>>>> Question 2:
>>> Dani
>>>>>> Question 3:
>>> Dani
>>>>>> Thanks
>>>>>> Kar
Re: EFS – FILESTORE – EDITORS … [message #327750 is a reply to message #327747] Wed, 30 April 2008 08:06 Go to previous messageGo to next message
Kar,
Unfortunately, if you want an IFile, it has to live in the workspace
somewhere... Is your directory tree really so big that extracting it is
very expensive? I don't imagine it should be necessary to actually
construct the contents of all the leaf files in the tree...
> me this is not possible - the db could be really big and the
> navigation view will inspect all the db each time a refresh is pressed
> or a new user will log for the first caching operation ...)
>> Kar,
>> this? The section "The relationship between EFS and IResource"
>> describes the steps you'd need to have the workspace refer to your
>>> to extract from IFileStore a real resource (IFile/...) and I believe
>>> that already a lot of this job has been done under the NavigationTree
>>> Kar
>>>> KarSc wrote:
>>>>> Hi Daniel
>>>> reproduce.
>>>>> messaggio news:fv75tt$qjp$3@build.eclipse.org...
>>>>>>> store so now I’m able to open xml and txt file easily.
>>>>>>> Question 1:
>>>>>>> correctly called
>>>>>>> editor is still dirty (i do update the fetch info with the new
>>>>>>> time but still doesn’t change)
>>>>>> file store?
>>>>>> Dani
>>>>>>> Question 2:
>>>>>>> my db but the save button will pop up the save as dialog on the
>>>>>>> file system ... any way I can trap this and display my own dialog
>>>> have an RCP and build your main menu yourself.
>>>> Dani
>>>>>>> Question 3:
>>>> Dani
>>>>>>> Thanks
>>>>>>> Kar
Re: EFS – FILESTORE – EDITORS … [message #327753 is a reply to message #327750] Wed, 30 April 2008 09:24 Go to previous messageGo to next message
Hi Ed ...
honestly what I did try was just creating a fake project in the resource
view (using as a root the XXXFileStore).
the resource view was doing all the job for me and editor where just fine
but cashing all the name and object information (fetchInfo) ... was tacking
up to 10 or more min ... impossible for me ...
that's why I'm creating my own view
what I have seen is that the navigation/resource view is able to create
ifile starting from filestore ...
editor will deal easily with ifile ... plus all the operation like delete
copy and so on will be automatically inherited ... (and the logic is still
inside the filestore ... not in the ifile)
clearly this ifile doesn’t realy exist in the filesystem ... so why not make
it a bit more general?
Kar
news:fv9n9n$sc6$1@build.eclipse.org...
> Kar,
>> this is not possible - the db could be really big and the navigation view
>> will inspect all the db each time a refresh is pressed or a new user will
>>> Kar,
>>> resources...
>>>> Kar
>>>>> KarSc wrote:
>>>>>> Hi Daniel
>>>>> reproduce.
>>>>>>>> Question 1:
>>>>>>>> correctly called
>>>>>>> file store?
>>>>>>> Dani
>>>>>>>> Question 2:
>>>>> Dani
>>>>>>>> Question 3:
>>>>> Dani
>>>>>>>> Thanks
>>>>>>>> Kar
Re: EFS – FILESTORE – EDITORS … [message #327757 is a reply to message #327753] Wed, 30 April 2008 10:43 Go to previous message
Kar,
Comments below.
KarSc wrote:
> Hi Ed ...
> resource view (using as a root the XXXFileStore).
Yes, but it sounds like the project has a monstrously big tree of
resources...
> fine ...
> tacking up to 10 or more min ... impossible for me ...
Approximately how big was your tree?
And you have a different set of problems. :-P
> create ifile starting from filestore ...
Indeed.
> delete copy and so on will be automatically inherited ... (and the
> logic is still inside the filestore ... not in the ifile)
> not make it a bit more general?
It's important to realize that an IFile like any IResource has a
getParent, and if you walk up, you eventually get to an IProject and the
IWorkspaceRoot. The implication of this is that while an IFile doesn't
have to live in the file system, it does have to exist in the
workspace. So if you decide you don't want your stuff in the workspace,
you've also made the decision not to have an IFile.
> Kar
>> Kar,
>> is very expensive? I don't imagine it should be necessary to
>> actually construct the contents of all the leaf files in the tree...
>>> pressed or a new user will log for the first caching operation ...)
>>>> Kar,
>>>>> ability to extract from IFileStore a real resource (IFile/...) and
>>>>> I believe that already a lot of this job has been done under the
>>>>> NavigationTree
>>>>> Kar
>>>>> messaggio news:fv78lq$ho4$1@build.eclipse.org...
>>>>>> KarSc wrote:
>>>>>>> Hi Daniel
>>>>>>> I was extending all the well known editor (default text editor
>>>>>>> and Structured text editor from the swt project) ...
>>>>>>> not sure that what I'm doing is possible or correct.
>>>>>> reproduce.
>>>>>>>>> a FileSystem reppresentation)
>>>>>>>>> Question 1:
>>>>>>>>> is correctly called
>>>>>>>> your file store?
>>>>>>>> Dani
>>>>>>>>> Question 2:
>>>>>>>>> the file system ... any way I can trap this and display my own
>>>>>>>>> dialog
>>>>>>>>> one otherwise I will just end up creating a new one for each
>>>>>>>>> type :-(
>>>>>> Dani
>>>>>>>>> Question 3:
>>>>>>>>> operation and when the editor is closed.
>>>>>> Dani
>>>>>>>>> Thanks
>>>>>>>>> Kar
Previous Topic:Problem with xxxFileStore AND editor
Next Topic:Marker, update view
Current Time: Sat Aug 30 23:33:03 EDT 2025
Powered by FUDForum. Page generated in 0.05266 seconds
