Home » Archived » Visual Editor (VE) » Comments under VE
Comments under VE [message #33179] Tue, 27 April 2004 01:52 Go to next message
is use Eclipse M8 with the VE-SDK-M1RC1 plugin, all works fine but
the commenttext/doctext have a line break when he put a new method (bean).
* This method initializes jContentPane
* @return javax.swing.JPanel
Is there a config point to disable that (without a line break) ??
thanks ...
Re: Comments under VE [message #33288 is a reply to message #33179] Tue, 27 April 2004 08:14 Go to previous messageGo to next message
Originally posted by: mendelgili.netscape.net
M.Kroll wrote:
> Hello,
> thanks ...
Which platfrom are you running on?
Re: Comments under VE [message #33477 is a reply to message #33288] Tue, 27 April 2004 23:57 Go to previous messageGo to next message
Gili Mendel wrote:
It's running on a Windows-XP Prof. and Java 1.4.2_04
Re: Comments under VE [message #33511 is a reply to message #33477] Wed, 28 April 2004 08:39 Go to previous messageGo to next message
M.Kroll wrote:
Open a Bugzilla with this info, and please attach an actual file that re
produces this symptom.
Our builds are performed on a Linux machine (with a different \n). Code
is being generated by JavaJet templates, which will be using the Linux
\n for line feed. We are working with the EMF guys (own the JavaJet
technology), at this time, to get dynamic multi platform "\n" support
for JavaJet templates ... but it is not here yet.
Re: Comments under VE [message #34215 is a reply to message #33511] Sat, 01 May 2004 23:33 Go to previous messageGo to next message
Originally posted by: mgareil.hotmail.com
I do have the same problem on XP pro / eclipse 3.0.0 26 march 2004
"Gili Mendel" <mendelgili@netscape.net> a
Re: Comments under VE [message #35473 is a reply to message #33511] Wed, 05 May 2004 06:35 Go to previous message
Originally posted by: leo_zen.gmx.at
Was there a ticket opened for this issue? If so, what #? I wanna add also,
that the linebreak is also on automatic generated Events.
Re: Comments under VE [message #587262 is a reply to message #33179] Tue, 27 April 2004 08:14 Go to previous message
M.Kroll wrote:
> Hello,
> thanks ...
Re: Comments under VE [message #587349 is a reply to message #33288] Tue, 27 April 2004 23:57 Go to previous message
Re: Comments under VE [message #587363 is a reply to message #33477] Wed, 28 April 2004 08:39 Go to previous message
Re: Comments under VE [message #587619 is a reply to message #33511] Sat, 01 May 2004 23:33 Go to previous message
Re: Comments under VE [message #588045 is a reply to message #33511] Wed, 05 May 2004 06:35 Go to previous message
Previous Topic:VE 0.5.0 on Eclipse 2.1.3?
Next Topic:How to set the layout of a pane?
Current Time: Mon Jul 14 00:52:51 EDT 2025
Powered by FUDForum. Page generated in 0.28778 seconds
