Home » Eclipse Projects » Eclipse Platform » new project wizard
new project wizard [message #327674] Mon, 28 April 2008 14:41 Go to next message
I have a wizard to make a new X project and now I want it to show up when I
right-click in Project Explorer and select the New submenu. I am able to get
it to show up there, but I want it to show up in the same group as the
'Project...' item (similar to how the new Java project shortcut in JDT shows
up there). I think all I need is the correct menuGroupId to make this
happen, but I cannot find what that is.
Does anyone know where I can find that information?
David
Re: new project wizard [message #327746 is a reply to message #327674] Wed, 30 April 2008 04:02 Go to previous message
Originally posted by: automatic.javalobby.org
Hi David
Have a look at the extension point "perspectiveExtensions". Here is a snippet if you want to extend the standard resource perspective:
   <extension point="org.eclipse.ui.perspectiveExtensions">
      <perspectiveExtension targetID="org.eclipse.ui.resourcePerspective">
         <newWizardShortcut id="com.test.wizards.SampleNewWizard"/>
      </perspectiveExtension>
   </extension>
If it does not show up, resetting the perspective does normally help.
Cheers, Stephan
Previous Topic:Drop Down Tree View
Next Topic:Assertin failed for editor.
Current Time: Fri Jul 18 11:48:53 EDT 2025
Powered by FUDForum. Page generated in 0.03595 seconds
