Home » Eclipse Projects » Eclipse Platform » update repository
update repository [message #327669] Mon, 28 April 2008 12:36 Go to next message
Hi All,
Do you know how I can get update repository for whole eclipse.org projects?
I'm not sure that I get latest versions of eclipse projects.
Best Regards تحياتي
Muhammad Bashir Al-Noimi محمد بشير النعيمي
My Blog مدونتي
http://mbnoimi.net/
Re: update repository [message #327671 is a reply to message #327669] Mon, 28 April 2008 13:10 Go to previous messageGo to next message
There is no single repository for all Eclipse projects. The closest
thing is the Europa Discovery Site which contains all the projects that
participate in the "Europa" release train (there's about 20 of them).
The Europa Update site should already be available in update manager.
If you download one of the milestones of the Ganymede release (June
2008), an update site for the projects participating in the Ganymede
release train are available.
HTH,
Wayne
On Mon, 2008-04-28 at 19:36 +0300, M. Bashir Al-Noimi wrote:
> Hi All,
Re: update repository [message #327672 is a reply to message #327671] Mon, 28 April 2008 13:45 Go to previous messageGo to next message
> HTH,
> Wayne
Last downloaded distro of eclipse was at January 2007, then every month
I update the distro from:
"http://download.eclipse.org/tools/cdt/releases/europa"
"http://update.eclipse.org/tools/cdt/releases/europa"
"http://update.eclipse.org/updates/3.3"
but from 3 months ago I noticed that there isn't new versions of
installed eclipse's plug-ins, so I'm wondering if there is an update
repository can give latest versions.
Note:
Could you provide me links for update repository, if there is.
Best Regards تحياتي
My Blog مدونتي
http://mbnoimi.net/
Re: update repository [message #327683 is a reply to message #327672] Mon, 28 April 2008 23:29 Go to previous message
That sounds about right. The Europa "winter" release would have been
about three months ago.
It seems that you have the latest and greatest in the "Europa" stream
(based on Eclipse 3.3).
The Ganymede stream is currently under development. If you want more
recent updates, you'll need to switch over to Ganymede (based on Eclipse
3.4). The official release date for Ganymede is at the end of June, but
there are milestone builds of the projects available.
Check here:
http://www.eclipse.org/downloads/packages/
The new update sites don't apply (i.e. they won't work) for the Europa
stream. If you want to use them, you'll have to get one of the new
packages.
HTH,
Wayne
> > HTH,
> > Wayne
> Note:
Previous Topic:How to use an external cvs diff tool
Next Topic:Eclipse 3.4 strange project naming upon import
Current Time: Sun Nov 02 09:47:50 EST 2025
Powered by FUDForum. Page generated in 0.05231 seconds
