update repository [message #327669] |
Mon, 28 April 2008 12:36  |
Hi All,
Do you know how I can get update repository for whole eclipse.org projects?
I'm not sure that I get latest versions of eclipse projects.
Best Regards تحياتي
Muhammad Bashir Al-Noimi محمد بشير النعيمي
My Blog مدونتي
http://mbnoimi.net/
Re: update repository [message #327683 is a reply to message #327672] |
Mon, 28 April 2008 23:29  |
That sounds about right. The Europa "winter" release would have been
about three months ago.
It seems that you have the latest and greatest in the "Europa" stream
(based on Eclipse 3.3).
The Ganymede stream is currently under development. If you want more
recent updates, you'll need to switch over to Ganymede (based on Eclipse
3.4). The official release date for Ganymede is at the end of June, but
there are milestone builds of the projects available.
Check here:
http://www.eclipse.org/downloads/packages/
The new update sites don't apply (i.e. they won't work) for the Europa
stream. If you want to use them, you'll have to get one of the new
packages.
HTH,
Wayne
On Mon, 2008-04-28 at 20:45 +0300, M. Bashir Al-Noimi wrote:
> Wayne Beaton wrote:
> > There is no single repository for all Eclipse projects. The closest
> > thing is the Europa Discovery Site which contains all the projects that
> > participate in the "Europa" release train (there's about 20 of them).
> > The Europa Update site should already be available in update manager.
> > If you download one of the milestones of the Ganymede release (June
> > 2008), an update site for the projects participating in the Ganymede
> > release train are available.
> > HTH,
> > Wayne
> Last downloaded distro of eclipse was at January 2007, then every month
> I update the distro from:
> "http://download.eclipse.org/tools/cdt/releases/europa"
> "http://update.eclipse.org/tools/cdt/releases/europa"
> "http://update.eclipse.org/updates/3.3"
> but from 3 months ago I noticed that there isn't new versions of
> installed eclipse's plug-ins, so I'm wondering if there is an update
> repository can give latest versions.
> Note:
> Could you provide me links for update repository, if there is.
FUDForum. Page generated in 0.04172 seconds
