Home » Eclipse Projects » Remote Application Platform (RAP) » Problem launching my application outside the IDE
Problem launching my application outside the IDE [message #33162] Thu, 14 June 2007 08:03 Go to next message
Originally posted by: benedikt.arnold.beyondsoft.de
Hi!
Currently I try to get my RAP application running outside Eclipse IDE. I
exported my feature, I downloaded the equinox launcher put all plugins I
need to run my application in the directory structure of the launcher and I
launched the framework using eclipsec.exe -console
So everything is fine. All bundels are active and jetty is running on port
8080
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.3.0.v20070530
1 ACTIVE org.eclipse.rap.jface_1.0.0.200706141255
2 ACTIVE org.eclipse.equinox.preferences_3.2.100.v20070522
3 ACTIVE de.beyondsoft.voipconf.fileprovider_1.0.0
4 ACTIVE org.eclipse.core.contenttype_3.2.100.v20070319
5 ACTIVE org.eclipse.equinox.app_1.0.0.v20070606
6 ACTIVE org.eclipse.core.runtime_3.3.100.v20070510
7 ACTIVE de.beyondsoft.voipconf.snom_1.0.0
8 ACTIVE org.eclipse.equinox.http.jetty_1.0.0.200706141255
9 ACTIVE org.eclipse.osgi.services_3.1.200.v20070605
10 ACTIVE org.mortbay.jetty_5.1.11.200706141255
11 ACTIVE org.eclipse.equinox.http.servlet_1.0.0.v20070606
12 ACTIVE org.eclipse.core.jobs_3.3.0.v20070423
13 ACTIVE org.eclipse.rap.rwt_1.0.0.200706141255
14 ACTIVE de.beyondsoft.voipconf.commons.default_1.0.0
15 ACTIVE org.eclipse.equinox.common_3.3.0.v20070426
16 ACTIVE de.beyondsoft.voipconf.core_1.0.0
17 ACTIVE org.apache.commons.logging_1.0.4.200706141255
18 ACTIVE org.eclipse.equinox.registry_3.3.0.v20070522
19 ACTIVE org.eclipse.core.expressions_3.3.0.v20070525-1050
20 ACTIVE javax.servlet_2.4.0.200706141255
21 ACTIVE org.eclipse.rap.ui.workbench_1.0.0.200706141255
22 ACTIVE org.eclipse.equinox.http.registry_1.0.0.v20070608
23 ACTIVE de.beyondsoft.voipconf.web.ui_1.0.0
24 ACTIVE org.eclipse.rap.w4t_1.0.0.200706141255
25 ACTIVE org.eclipse.equinox.log_1.0.100.v20070226
26 ACTIVE de.beyondsoft.voipconf.httpdelivery_1.0.0
27 ACTIVE org.eclipse.core.commands_3.3.0.I20070523-1500
28 ACTIVE de.beyondsoft.voipconf.core.hibernate_1.0.0
29 ACTIVE de.beyondsoft.voipconf.web.core_1.0.0
osgi>
But if I try to access the application with firefox I got the attached
exception. I am working with the current cvs HEAD but I also tried it with
the M4 target. If I run the application from my IDE everything workes fine.
Greetings,
Benedikt
Stack trace:
osgi> java.lang.UnsupportedOperationException
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:267)
org.eclipse.jface.resource.ImageDescriptor.createResource(Im ageDescriptor.java:160)
org.eclipse.jface.resource.DeviceResourceManager.allocate(De viceResourceManager.java:56)
org.eclipse.jface.resource.AbstractResourceManager.create(Ab stractResourceManager.java:85)
org.eclipse.jface.resource.ResourceManager.createImageWithDe fault(ResourceManager.java:185
org.eclipse.ui.internal.WorkbenchPartReference.getTitleImage (WorkbenchPartReference.java:5
03)
org.eclipse.ui.internal.presentations.PresentablePart.getTit leImage(PresentablePart.java:2
37)
org.eclipse.ui.internal.presentations.util.PartInfo.set(Part Info.java:44)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.initTab(PresentablePartFo
lder.java:328)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.insert(PresentablePartFol
der.java:185)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.add(LeftToRightTabOrder.jav
a:37)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.addInitial(LeftToRightTabOr
der.java:44)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.addPart(TabbedStackPres
entation.java:330)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:15 57)
org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:615)
org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:542)
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:557)
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:242)
org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:876)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2421)
org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindo w.java:2731)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2712)
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:643)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:898)
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1715)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1662)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:1
90)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:755)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1224)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2186)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:341)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:153)
de.beyondsoft.voipconf.web.ui.VoIPConfWorkbench.createUI(VoI PConfWorkbench.java:24)
org.eclipse.swt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:82)
org.eclipse.swt.internal.lifecycle.PrepareUIRoot.execute(Pre pareUIRoot.java:32)
org.eclipse.swt.internal.lifecycle.RWTLifeCycle.execute(RWTL ifeCycle.java:81)
at com.w4t.engine.W4TModel$ServiceAdapter.execute(W4TModel.java :47)
com.w4t.engine.service.FormRequestServiceHandler.service(For mRequestServiceHandler.java:65
com.w4t.engine.service.ServiceManager$HandlerDispatcher.serv ice(ServiceManager.java:104)
at com.w4t.engine.W4TDelegate.doPost(W4TDelegate.java:75)
org.eclipse.ui.internal.servlet.RequestHandler.service(Reque stHandler.java:41)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletMa
nager.java:180)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistr
ation.java:90)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:109)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59)
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.servi
ce(HttpServerManager.java:280)
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
03)
37)
lder.java:328)
der.java:185)
a:37)
der.java:44)
entation.java:330)
90)
nager.java:180)
ation.java:90)
Re: Problem launching my application outside the IDE [message #33198 is a reply to message #33162] Thu, 14 June 2007 08:13 Go to previous messageGo to next message
the exception is caused due to some missing images. Could you take a
look at your build.properties if you really export all icons/images
you're using (especially the ones for the views).
If that doesn't help, try to run the workbench demo
(org.eclipse.rap.demo) the same way and tell us if there are the same
exceptions.
Greets
Benny
Benedikt Arnold wrote:
> Hi!
> 8080
> id State Bundle
> osgi>
> Greetings,
> Benedikt
> Stack trace:
> at
> at
> at
> at
> at
> at
> 03)
> at
> 37)
> at
> at
> lder.java:328)
> at
> der.java:185)
> at
> a:37)
> at
> der.java:44)
> at
> entation.java:330)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 90)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> nager.java:180)
> at
> ation.java:90)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 03)
> at
> 37)
> at
> at
> lder.java:328)
> at
> der.java:185)
> at
> a:37)
> at
> der.java:44)
> at
> entation.java:330)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 90)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> nager.java:180)
> at
> ation.java:90)
> at
> at
> at
> at
> at
> at
> at
> at
Re: Problem launching my application outside the IDE [message #33271 is a reply to message #33198] Thu, 14 June 2007 08:39 Go to previous message
Thanks! I've forgotton to check the icons folder.
Greetings, Ben
"Benjamin Muskalla" <bmuskalla@innoopract.com> schrieb im Newsbeitrag
news:f4rbdb$k59$1@build.eclipse.org...
> the exception is caused due to some missing images. Could you take a look
> at your build.properties if you really export all icons/images you're
> If that doesn't help, try to run the workbench demo (org.eclipse.rap.demo)
> the same way and tell us if there are the same exceptions.
> Greets
> Benny
>> Hi!
>> I launched the framework using eclipsec.exe -console
>> port 8080
>> id State Bundle
>> osgi>
>> with the M4 target. If I run the application from my IDE everything
>> workes fine.
>> Greetings,
>> Benedikt
>> Stack trace:
>> at
>> at
>> at
>> at
>> at
>> at
>> 03)
>> at
>> 37)
>> at
>> at
>> lder.java:328)
>> at
>> der.java:185)
>> at
>> a:37)
>> at
>> der.java:44)
>> at
>> entation.java:330)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> 90)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> nager.java:180)
>> at
>> ation.java:90)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> 03)
>> at
>> 37)
>> at
>> at
>> lder.java:328)
>> at
>> der.java:185)
>> at
>> a:37)
>> at
>> der.java:44)
>> at
>> entation.java:330)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> 90)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> nager.java:180)
>> at
>> ation.java:90)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Previous Topic:why my rap demo doesnt run ?
Next Topic:no 'default' entrypoint outside of exclipse
Current Time: Tue Jul 15 13:29:09 EDT 2025
Powered by FUDForum. Page generated in 0.29468 seconds
