Home » Eclipse Projects » Eclipse Platform » EFS question ...
EFS question ... [message #327549] Thu, 24 April 2008 08:42 Go to next message
Hi all,
Not sure this is the right forum where post questions on EFS . if no please
just let me know .
The question is about the use of EFS . and what I have done in mapping
(using EFS) my Object database.
Following the examples I have found I built the XXXFileStore and linked it
at the resources view .
everything was just working fine (I can see the tree nicely created and I
could open modify and save back content files and so on)
But
What about creating my own view?
I just created a simple TreeViewer with its own provider based on
XXXFileStore input
It worked just fine but I can only open file (using the file store) using
the default text editor .
I have seen that the OpenAction from the resource view works on
IDE.openEditor(IWorkbenchPage, IFile).
Do I really need to implement my own XFile object that implements the IFile
interface .
Probably there are things not clear for me and what I'm trying to do is
wrong .
If someone could give me any information . I would really appreciate it.
Kar
Re: EFS question ... [message #327552 is a reply to message #327549] Thu, 24 April 2008 09:36 Go to previous messageGo to next message
Kar,
There are other open methods that take an IEditorInput or a URI so you
might try those. Here's a snip from of some utility code in
org.eclipse.emf.edit.ui.uti.EditUIUtil we wrote recently to make opening
editors in RCP easier for us:
IWorkbench workbench = PlatformUI.getWorkbench();
IWorkbenchPage page =
workbench.getActiveWorkbenchWindow().getActivePage();
IEditorPart editorPart = page.openEditor(editorInput,
workbench.getEditorRegistry().getDefaultEditor(uri.lastSegme nt()).getId());
KarSc wrote:
> Hi all,
> please just let me know .
> linked it at the resources view .
> and I could open modify and save back content files and so on)
> But
> XXXFileStore input
> using the default text editor .
> IFile interface .
> is wrong .
> Regards
> Kar
Re: EFS question ... [message #327654 is a reply to message #327552] Mon, 28 April 2008 04:28 Go to previous messageGo to next message
Hi Ed and thanks for your help ...
the point is ... what is the right way to create the EDITOR INPUT, do I need
to create one?
I was hoping that using efs I could deal with the logic of reading the
content from the db using the xxxfilestore ... (my previous version was
only using custom editor input ...)
in some examples I have seen the use of NonExistingFileEditorInput (but not
sure this is the correct approach) and all the classes from EditUIUtil deal
with IFile that I haven't got :(
what shall I do?
thanks in advance
Kar
"Ed Merks" <merks@ca.ibm.com> ha scritto nel messaggio
news:fuq2dt$9uh$1@build.eclipse.org...
> Kar,
> KarSc wrote:
>> Hi all,
>> But
>> XXXFileStore input
>> IFile interface .
>> wrong .
>> Regards
>> Kar
Re: EFS question ... [message #327655 is a reply to message #327552] Mon, 28 April 2008 04:30 Go to previous message
to create one?
what shall I do?
thanks in advance
Kar
> Kar,
> KarSc wrote:
>> Hi all,
>> But
>> XXXFileStore input
>> IFile interface .
>> wrong .
>> Regards
>> Kar
Previous Topic:getActivePage throws NullPointerException
Next Topic:Best practices for notifications
Current Time: Sun Aug 31 20:13:20 EDT 2025
Powered by FUDForum. Page generated in 0.08980 seconds
