OHF - IHE Plugin question [message #33160] |
Thu, 16 August 2007 15:23  |
Hi all
Im using OHF plugins to implement the IHE functionality into our
application. I have the following questions:
1. Is the NIST down? Im not able to submit documents to the NIST
http://hcxw2k1.nist.gov:8080/xdsServices2/registry/soap/port als/yr3a/repository.
2. When I submit a CCD document created from my application, the
source patient id and patient ids within the document are created from our
application. The submission fails stating that the patient id should be in
the affinity domain. Should I then perform a Patient Identity Feed
transaction as a Patient Identity Source actor and register my system
generated patient id into the NIST registry? If that is the case, to which
NIST specific MLLP destination should I send the Patient Feed to?
3. How can I perform the secure submission for the XDS document
source actor to the NIST?
4. While performing a XDS-MS document submission transaction, I had
set the MIME default type text/xml and the format code to "CDAR2/IHE
1.0" and DocumentDescriptor to CDA_R2. If I set the MIME type to
"text/x-cda-r2+xml" Im getting a SOAP error. I also notice that there is
a XDS_MS DocumentDescriptor. When I tried to use this too Im getting an
error?
5. There some DocumentEntry and SubmissionSet meta data such as the
HealthCareFacilityCode, ClassCode, PracticeSetting Code, ContentTypeCode
which are not part of the generated CCD document. Can u tell me how and
from whom these values will be received in a real installation.
I would greatly appreciate any help.
Venkat
Re: OHF - IHE Plugin question [message #33267 is a reply to message #33160] |
Sat, 25 August 2007 18:44  |
Hi Venkat,
Thank you for your post to the newsgroup and sorry for the delay in
reply. I'm the person to address this issue and am on buisness travel
until mid-September. I'll do my best to check this out during this time.
Regarding the questions I can answer:
1. I'm not sure of this. The system may be down while they update for
the coming connectathon. Or the URL may have changed. Note that NIST is
not a dedicated year round server for testing .. they are primerily used
for pre-Connectathon testing in the fall. The IBM test environment is a
year round environment for testing and is compliant with 2006-2007 IHE
specifications. I'll look into this more when I am able. Note - that the
current development branch in OHF is not stable as we are updating the
code for Connectathon 2008.
2. This behavior is correct - as the patient ID in the document is not
necessarily the patient ID in the XDS Affinity Domain. Reason being -
the document may or may not have been created for sharing purposes - but
rather enterprise internal purposes. So, since the OHF code cannot
determine this fact from the document itself - it takes a conservative
approach and puts the patient Id it finds in the sourcePatientId
metadata, which is correct in either case. I don't recommend that you
feed your id to the affinity domain just to get things to work. You
should be doing a query to see if the patient in question already has an
affinity domain patient ID. For NIST - you cannot feed id's to it. They
have a service that will assign you a test id. Follow the link here:
http://wiki.eclipse.org/IHE_Connectathon_2008#OHF_at_Past_Co nnectathons
to our page for connectathon last year. There is a link there to the
patient Id allocation service on NIST.
3. For now - I'm not sure how this will be accomplished. When
pre-testing for connectathon begins - test certificates will be distributed.
4. Can you open a bug on this issue, attach the debug log and I can
better determine what is going on.
5. These are codes that will be determined by the affinity domain
installation environment. For connectathon - these will be determined by
connectathon officials. To see/use the codes from the last connectathon
- follow the links above to the OHF 2007 Connectathon wiki page. We have
a link there (right by the NIST patient id allocation service) to the
codes used for 2007. These are subject to change for Connectathon 2008.
regards,
Sarah
Venkat wrote:
> Hi all
> I�m using OHF plugins to implement the IHE functionality into our
> 1. Is the NIST down? I�m not able to submit documents to the NIST
> at
> our application. The submission fails stating that the patient id should
> be in the affinity domain. Should I then perform a Patient Identity Feed
> which NIST specific MLLP destination should I send the Patient Feed to?
> source actor to the NIST? 4. While performing a XDS-MS document
> submission transaction, I had set the MIME default type �text/xml� and
> the format code to "CDAR2/IHE 1.0" and DocumentDescriptor to CDA_R2. If
> I set the MIME type to "text/x-cda-r2+xml" I�m getting a SOAP error. I
> also notice that there is a XDS_MS DocumentDescriptor. When I tried to
> use this too I�m getting an error? 5. There some DocumentEntry
> and SubmissionSet meta data such as the HealthCareFacilityCode,
> ClassCode, PracticeSetting Code, ContentTypeCode which are not part of
> the generated CCD document. Can u tell me how and from whom these values
> I would greatly appreciate any help. Thanks Venkat
Re: OHF - IHE Plugin question [message #581077 is a reply to message #33160] |
Hi Venkat,
regards,
Sarah
Venkat wrote:
> Hi all
> at
FUDForum. Page generated in 0.06390 seconds
