Display Stereotypes in Sequence Diagrams [message #1710807] |
Fri, 09 October 2015 12:41 |
is it possible to display Stereotypes of Message Edges in Sequence
Diagrams like in Class Diagram. I already tried to enable all
visibilities of stereotypes via the project Style Sheets settings, but
this seems to only affect the Class Diagram.
How can I display Stereotype properties in a Sequence Diagram?
Thank you very much for every hint.
Best wishes,
Joachim
Re: Display Stereotypes in Sequence Diagrams [message #1711704 is a reply to message #1710807] |
Mon, 19 October 2015 11:53 |
Does nobody have an idea about this?
I will be already satisfied with a short hint, if it is possible in
general or will need some complex configuration or even code based
extensions.
We already deal with customizations like Diagram Palettes and Custom
Views so we are also familiar with the eclipse plugin development if
this knowledge is needed to address the question of the first post.
Thanks for any answer in advance,
Joachim
FUDForum. Page generated in 0.03238 seconds
