Problems with new Update Mechanism of 3.4M6 [message #327493] |
Tue, 22 April 2008 07:24  |
Hi there,
I installed the Eclipse Platform Version 3.4M6a for Linux-32. It showed
this new Software Update Mechanism.
I used it to install some stuff (CDT, subclipse and texlipse). After
that CDT is available, the others are not.
Starting Eclipse now only shows the old "Sftware Update -> find and
install" dialog where I cannot install anything ("no platform available").
Starting Eclipse brings now the error message below. What does this mean?
Hauke
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing C onstraint:
Require-Bundle: org.eclipse.equinox.p2.touchpoint.eclipse;
bundle-version="0.1.0"
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:257)
org.eclipse.equinox.internal.simpleconfigurator.ConfigApplie r.startBundles(ConfigApplier.java:289)
org.eclipse.equinox.internal.simpleconfigurator.ConfigApplie r.install(ConfigApplier.java:85)
org.eclipse.equinox.internal.simpleconfigurator.SimpleConfig uratorImpl.applyConfiguration(SimpleCon
figuratorImpl.java:115)
figuratorImpl.java:131)
org.eclipse.equinox.internal.simpleconfigurator.Activator.st art(Activator.java:48)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:10
03)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1074)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:632
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:495)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:2
80)
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:248)
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:152)
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:644)
org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:288)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:171)
Re: Problems with new Update Mechanism of 3.4M6 [message #327819 is a reply to message #327493] |
Sun, 04 May 2008 11:30  |
Originally posted by: totolaricot.mac.com
Had the same issue with some other features. there is a problem with the
ECF plugin used by P2 and some other plugins. the result is that your
machine ends up with two versions and the error you see. I tried to
manually erase one of them, making updates to the checkpoint files..
nothing did it. I ended-up deleting P2 from my M6a setup (the remover
script on the download page did not work for me, so I had to do the
cleanup manually) because the install was so messed up I could not add
or remove anything. I hope they manage to stabilize P2 on time for the
release... based on my experience with it so far, I vote it out.
Hauke Fuhrmann wrote:
> Hi there,
> Hauke
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> 03)
> at
> at
> at
> at
> at
> at
> at
> 80)
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
Laurent Mihalkovic, co-author SWT/JFace in Action (www.manning.com/scarpino)
FUDForum. Page generated in 0.03677 seconds
