Home » Eclipse Projects » Eclipse Platform » possible to store preferences in database?
possible to store preferences in database? [message #327491] Tue, 22 April 2008 05:54 Go to next message
Originally posted by: jacek.pospychala.pl.ibm.com
I'd like to store my plug-ins preferences (located in
workspace/.metadata/plugins) in some remote location, e.g. database.
Is it possible?
My users could then use their settings from any of their RCP installations.
thanks
Jacek
Re: possible to store preferences in database? [message #327521 is a reply to message #327491] Wed, 23 April 2008 08:34 Go to previous message
There are two different answers to this question.
You can store the values for preferences you control (i.e. defined in
bundles that you've created) anywhere you'd like.
If you want to change where *all* preferences are stored, I believe that
the answer is yes. Look at the IPreferencesService class. An instance of
this class, PreferencesService, is registered as an Equinox service. The
instance is accessed via the InternalPlatform#getPreferencesService()
method.
At least theoretically, you can create your own IPreferencesService
implementation and register it as an Equinox Service with a higher
Constants.SERVICE_RANKING than the existing service.
It looks like a lot of work to me. It's complicated by a comment on the
IPreferencesService interface that suggests that the interface is "not
intended to be implemented by clients"
HTH,
Wayne
On Tue, 2008-04-22 at 11:54 +0200, Jacek Pospychala wrote:
> Is it possible?
> thanks
> Jacek
Previous Topic:CRUD editors
Next Topic:solaris 10 x86
Current Time: Sat May 10 03:30:04 EDT 2025
Powered by FUDForum. Page generated in 0.03033 seconds
