Home » Language IDEs » AspectJ » AJDT-install problem: requires plug-in org.eclipse.pde.core etc...
AJDT-install problem: requires plug-in org.eclipse.pde.core etc... [message #33154] Thu, 15 April 2004 03:49 Go to next message
installing ajdt 1.1.4 via update manager in eclipse 2.1.2 gives following
remarks:
'''''Requested operation cannot be performed because it would invalidate
the current configuration. See details for more information.
Eclipse AspectJ Development Tools (1.1.4): Feature requires plug-in
"org.eclipse.pde.core".
"org.eclipse.pde.runtime".
"org.eclipse.pde".''''
I've also tried version 1.1.3, same problems
(this is the first time I've these installation problems: I've also got
jdt, cdt, omondo UML and pydev)
After reading the site of the pde plug-in I'm puzzled...
Isn't the Pde-plugin something you use if you want to make an eclipse
plug-in
This is not the case for me however, I simply want to start with learning
AOP?
Is there a way for installing ajdt without pde?
If not, hmmm perhaps a request, installing ajdt without the need for
installing pde would be nice :)
thx a lot for reading so far
Peter
Re: AJDT-install problem: requires plug-in org.eclipse.pde.core etc... [message #33434 is a reply to message #33154] Thu, 15 April 2004 15:37 Go to previous messageGo to next message
Originally posted by: clemas.uk.ibm.com
Hi Peter,
Can you confirm you are using a complete version of Eclipse 2.1.2 - or are
you using a cut down version of it?
1.1.4 should install easily into 2.1.2 via the update site mechanism.
Andy.
Re: AJDT-install problem: requires plug-in org.eclipse.pde.core etc... [message #34423 is a reply to message #33434] Mon, 19 April 2004 04:02 Go to previous messageGo to next message
Hello Andy,
Following your advice, I've found I had not installed eclipse 2.1.2 SDK,
instead (in a grey and distant paste) I had installed
eclipse platform 2.1.2 and other components seperately from an ftp
server...
probably some components were not installed as they should have been
(call me an amateur if you will, it's probably correct :) )
next week I'll install SDK to see if this solves my troubles (if not for
network problems, I would to it today)
thx a lot
Peter
Andy Clement wrote:
> Hi Peter,
> Andy.
Re: AJDT-install problem: requires plug-in org.eclipse.pde.core etc... [message #35275 is a reply to message #33434] Sat, 01 May 2004 21:53 Go to previous messageGo to next message
Andy Clement wrote:
> Hi Peter,
> Andy.
Does a "complete version" mean that AJDT requires the SDK version of
Eclipse?
Re: AJDT-install problem: requires plug-in org.eclipse.pde.core etc... [message #35482 is a reply to message #35275] Fri, 07 May 2004 11:36 Go to previous message
Hello
I have installed a complete version of eclipse 2.1.3 (SDK) and no more
problems
greetz
Peter
Peter Wilkins wrote:
> Andy Clement wrote:
> > Hi Peter,
> > Andy.
> Eclipse?
Re: AJDT-install problem: requires plug-in org.eclipse.pde.core etc... [message #577773 is a reply to message #33154] Thu, 15 April 2004 15:37 Go to previous message
Hi Peter,
Andy.
Re: AJDT-install problem: requires plug-in org.eclipse.pde.core etc... [message #578628 is a reply to message #33434] Mon, 19 April 2004 04:02 Go to previous message
Hello Andy,
server...
thx a lot
Peter
Andy Clement wrote:
> Hi Peter,
> Andy.
Re: AJDT-install problem: requires plug-in org.eclipse.pde.core etc... [message #579274 is a reply to message #33434] Sat, 01 May 2004 21:53 Go to previous message
Andy Clement wrote:
> Hi Peter,
> Andy.
Eclipse?
Re: AJDT-install problem: requires plug-in org.eclipse.pde.core etc... [message #579400 is a reply to message #35275] Fri, 07 May 2004 11:36 Go to previous message
Hello
problems
greetz
Peter
> Andy Clement wrote:
> > Hi Peter,
> > Andy.
> Eclipse?
Previous Topic:PDE plug-in error: does AJDT require SDK version?
Next Topic:Problems with HelloWorld example with eclipse 3.0M8
Current Time: Fri Jul 18 00:37:27 EDT 2025
Powered by FUDForum. Page generated in 0.24832 seconds
