Home » Eclipse Projects » Eclipse Platform » How to have multicolored tree label
How to have multicolored tree label [message #327449] Sun, 20 April 2008 21:01 Go to next message
Hi in 3.4M6 the tree labels in the Package explorer, and Outline shows
examples where the label is multicolored. E.g. a method is rendered in
the Outline view with black method name, and then the type i gold.
How is this effect created? Greatful if someone can point me to an
example (or how/where to find code that does this).
- henrik
Re: How to have multicolored tree label [message #327453 is a reply to message #327449] Mon, 21 April 2008 01:40 Go to previous messageGo to next message
http://wiki.eclipse.org/JFaceSnippets#Snippet049SimpleStyled CellLabelProvider
Tom
> Regards
> - henrik
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: How to have multicolored tree label [message #327464 is a reply to message #327453] Mon, 21 April 2008 13:31 Go to previous messageGo to next message
Thanks Tom,
A couple of follow up questions - the SimpleStyledCellLabelProvider is
marked as deprecated and a different label provider is suggested
StyledCellLabelProvider, and it is quite different.
I have not worked with ViwerCell's before - so I don't get the info
in the JavaDoc for that class -
* For providing the label's styles, create a subclass and overwrite
* {@link StyledCellLabelProvider#update(ViewerCell)} to
* return set all information needed to render a element. Use
* {@link ViewerCell#setStyleRanges(StyleRange[])} to set style ranges
* on the label.
Any pointers to example use of SimpleStyledCellLabelProvider, or to
information about ViewerCell?
Basically, all I want to do is to have a multicolored label in a
TreeViewer (no need for columns, etc). Any Suggestions?
- henrik
> Tom
>> Regards
>> - henrik
Re: How to have multicolored tree label [message #327477 is a reply to message #327464] Mon, 21 April 2008 17:33 Go to previous messageGo to next message
Where do you read something about deprecate in the snippet? Running the
snippet does exactly what you want to it shows a table with a
multi-color label (black and blue).
ViewerCell is the widget independent representation of a Cell in your
viewer. It allows you to set an image, text, ... on the underlying
SWT-Item (TreeItem, TableItem, ...).
Tom
> Thanks Tom,
> * on the label.
> Regards
> - henrik
>> Tom
>>> shows examples where the label is multicolored. E.g. a method is
>>> rendered in the Outline view with black method name, and then the
>>> type i gold.
>>> Regards
>>> - henrik
Re: How to have multicolored tree label [message #327500 is a reply to message #327464] Tue, 22 April 2008 10:43 Go to previous messageGo to next message
Have a look at the wiki page again. We did update the snippets (they now use
StyledCellLabelProvider instead of SimpleStyledCellLabelProvider), but
because of a "feature" in ViewCVS, you were still seeing the old snippets.
Boris
"Henrik Lindberg" <henrik.lindberg@cloudsmith.com> wrote in message
news:fuij19$d3n$1@build.eclipse.org...
> Thanks Tom,
> * on the label.
> Regards
> - henrik
>> Tom
>>> Regards
>>> - henrik
Re: How to have multicolored tree label [message #327508 is a reply to message #327500] Tue, 22 April 2008 14:25 Go to previous message
Thanks!
Much better!
(The link is now
http://wiki.eclipse.org/JFaceSnippets#Snippet049StyledCellLa belProvider
since the name changed).
- henrik
> Boris
>> Thanks Tom,
Previous Topic:Re: Databinding and EFeatureMap (Re: AdapterFactoryContentProvider and notificat
Next Topic:Copy as RTF
Current Time: Sat Jul 26 14:46:33 EDT 2025
Powered by FUDForum. Page generated in 0.03660 seconds
