Home » Eclipse Projects » Eclipse Platform » still learning the CVS for eclipse
still learning the CVS for eclipse [message #327447] Sun, 20 April 2008 16:56 Go to next message
I am still learning how to get files using WinCVS for Eclipse. I
managed to get the org.eclipse.releng.basebuilder and
orb.eclipse.releng.eclipsebuilder. However I need to get
.../plugins/org.eclipse.pde.build/scripts.
Here was my steps. I logged in to /cvsroot/eclipse. Next I used the co
command to get the eclipsebuilder and plugins.
FYI, I am reading the documentation here:
C:\dev\cvs2\CVSROOT\org.eclipse.releng.basebuilder\readme.ht ml
My job is to build a core CDT eclipse.exe by using WinCVS to check
out the sources.
-Derek Lac
Re: still learning the CVS for eclipse [message #327463 is a reply to message #327447] Mon, 21 April 2008 13:29 Go to previous message
Derek,
The org.eclipse.releng.basebuilder project contains a plugins directory that
holds all the plugins needed to run the builder (including
org.eclipse.pde.build). The basebuilder represents a set lineup of prebuilt
plugins that will run the build. It is better to use these versions to run the
build because they are known to work, using more recent versions are untested.
You should also look at the source builds (for example
http://download.eclipse.org/eclipse/downloads/drops/I2008041 5-1646/sourceBuilds.php)
-Andrew
Derek wrote:
> Hello,
> My job is to build a core CDT eclipse.exe by using WinCVS to check out
> the sources.
> -Derek Lac
Previous Topic:Using IPipelinedTreeContentProvider
Next Topic:Decorate editor tab
Current Time: Fri Jul 25 11:36:54 EDT 2025
Powered by FUDForum. Page generated in 0.26821 seconds
