Home » Eclipse Projects » Eclipse Platform » PopupMenu objectContribution
PopupMenu objectContribution [message #327353] Wed, 16 April 2008 05:40 Go to next message
Originally posted by: jefftymc.yahoo.com
I currently have a popupMenu in an objectContribution for
IResource. The plugin.xml is:
<?eclipse version="3.2"?>
<plugin>
<extension point="org.eclipse.ui.popupMenus">
<objectContribution
adaptable="true"
id="test.ResourceMapperContributions"
objectClass="org.eclipse.core.resources.mapping.ResourceMapping ">
<action
class="com.test.TestAction"
enablesFor="+"
id="test.action"
label="test">
</action>
</objectContribution>
</extension>
</plugin>
While right clicking on file, folder or project in the Package
Explorer, the action will display in the popupMenu. But it disappears
when I click on a file in "Synchronize" viewer of "Team Synchronizing"
perspective.
When created the plug-in project I choosed "Eclipse 3.4" in the
field of "Target Platform". Does it matter?
Would you please help about this?
Thanks in advance.
Re: PopupMenu objectContribution [message #327366 is a reply to message #327353] Wed, 16 April 2008 12:09 Go to previous messageGo to next message
Thanks, seems reasonable, add a SWT.PaintItem listener... do you know if this is likely to work in combination with a label provider (who's getColumnImage returns null)?
I'm trying it and having problems...
The getColumnImage gets called first it seems, then the event listener for SWT.PaintItem, so I'll keep playing, just wondered if you knew in principle if it was likely to work.
Cheers ears
http://www.eclipsezone.com/eclipse/forums/m92233118.html
Re: PopupMenu objectContribution [message #327385 is a reply to message #327353] Thu, 17 April 2008 03:32 Go to previous messageGo to next message
I modified the contribution like this:
<viewerContribution
id="com.test"
targetID="org.eclipse.team.ccvs.ui.RepositoriesView">
<action
definitionId="org.eclipse.ui.edit.paste1"
enablesFor="*"
menubarPath="miscGroup"
label="testLabel">
</action>
</viewerContribution>
TestAction extends ActionDelegate and implements IViewActionDelegate,
the action display in "CVS Repositories" (the id is
"org.eclipse.team.ccvs.ui.RepositoriesView") View.
So I think if I change the targetID to "Synchronize" View's ---
"org.eclipse.team.sync.views.SynchronizeView" the action will display in
the context menu of Synchronize View.
But it didn't. What's wrong with that?
Thanks a lot!
jeffty wrote:
> I currently have a popupMenu in an objectContribution for IResource.
> The plugin.xml is:
> <plugin>
> <objectContribution
> adaptable="true"
> <action
> enablesFor="+"
> id="test.action"
> label="test">
> </action>
> </extension>
> </plugin>
> perspective.
> Thanks in advance.
Re: PopupMenu objectContribution [message #327396 is a reply to message #327385] Thu, 17 April 2008 10:33 Go to previous messageGo to next message
The Sync view doesn't register a context menu with the system (at least
it doesn't look like it does, from ALT+SHIFT+F1) so there's nothing to
add to.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: PopupMenu objectContribution [message #327411 is a reply to message #327396] Thu, 17 April 2008 20:58 Go to previous messageGo to next message
Then we cann't add a menuItem to this View manually?
Paul Webster wrote:
>> IViewActionDelegate, the action display in "CVS Repositories" (the id
>> is "org.eclipse.team.ccvs.ui.RepositoriesView") View.
>> in the context menu of Synchronize View.
> add to.
> PW
Re: PopupMenu objectContribution [message #327428 is a reply to message #327411] Fri, 18 April 2008 10:26 Go to previous messageGo to next message
Not to the popup menu, only to the view dropdown menu.
PW
Paul Webster
Re: PopupMenu objectContribution [message #327430 is a reply to message #327428] Fri, 18 April 2008 10:59 Go to previous message
Thanks Paul, I won't waste time on the popupmenu then. :)
Paul Webster 写道:
> PW
Previous Topic:PDE Build with Packager
Next Topic:Fullscreen view
Current Time: Tue Jul 15 13:10:34 EDT 2025
Powered by FUDForum. Page generated in 0.25369 seconds
