Home » Eclipse Projects » Eclipse Platform » How to use CVS to get org.eclipse.releng.*
How to use CVS to get org.eclipse.releng.* [message #327351] Wed, 16 April 2008 00:45
How do I use WinCVS to get the org.eclipse.releng.* code? I used the
login command to get into /cvsroot/eclipse:
cvs -d ":pserver;username=anonymous;hostname=dev.eclipse.org
:/cvsroot/eclipse" login
Logging in to :pserver:anonymous@dev.eclipse.org:2401:/cvsroot/eclipse
Next I click on remote -> checkout module...
Next I click on the "..." button in the Module names(s) and path on the
server button. I lists jdt, jdt-core, ..., platform, etc. On the third
column title "Directories/ files", I sorted it. It says
org.eclipse.jdt.core, etc. There's none that says org.eclipse.releng.
The closest module I found was platform-core. However none of the
checkouts pertaining to org.eclipse.releng.*
-Derek Lac
dlac23@yahoo.com
Previous Topic:IProgressMonitor usage
Next Topic:Ganymede M6 startup slow?
Current Time: Fri Oct 24 17:33:06 EDT 2025
Powered by FUDForum. Page generated in 0.02626 seconds
