Home » Eclipse Projects » Nebula » Invalid thread access
Invalid thread access [message #33141] Wed, 25 April 2007 02:34 Go to next message
Originally posted by: swetha.yahoo.co.in
I am developing a Gallery View using nebula gallery widget,
the createPartControl method is,
public void createPartControl(Composite parent)
gallery = new Gallery(parent, SWT.V_SCROLL);
noGroupRenderer = new NoGroupRenderer();
defaultGalleryItemRenderer = new DefaultGalleryItemRenderer();
(some other code)---------
the error is coming at the line
in DefaultGalleryItemRenderer class the error is at the line,
foregroundColor =
Display.getDefault().getSystemColor(SWT.COLOR_LIST_FOREGROUN D);
public DefaultGalleryItemRenderer() {
foregroundColor =
backgroundColor =
Display.getDefault().getSystemColor(SWT.COLOR_LIST_BACKGROUN D);
selectionForegroundColor = foregroundColor;
selectionBackgroundColor =
Display.getDefault().getSystemColor(SWT.COLOR_LIST_SELECTION );
// Create drop shadows
createColors();
The error is,
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:3374)
at org.eclipse.swt.SWT.error(SWT.java:3297)
at org.eclipse.swt.SWT.error(SWT.java:3268)
at org.eclipse.swt.widgets.Display.error(Display.java:978)
at org.eclipse.swt.widgets.Display.checkDevice(Display.java:638 )
at org.eclipse.swt.widgets.Display.getSystemColor(Display.java: 1931)
org.eclipse.nebula.widgets.gallery.DefaultGalleryItemRendere r. <init>(DefaultGalleryItemRenderer.java:63)
com.sequenom.everest.ui.project.GalleryView.createPartContro l(GalleryView.java:335)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:332)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:197)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
org.eclipse.ui.internal.WorkbenchPage$ActivationList.setActi ve(WorkbenchPage.java:3915)
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2929)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1936)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:2857)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1665)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1 650)
at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1529 )
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1473)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigur
Please help me in this,
Thanks in advance,
Swetha
Re: Invalid thread access [message #33176 is a reply to message #33141] Wed, 25 April 2007 03:40 Go to previous messageGo to next message
Well the root cause see seems to be that your createPartControl isn't
executed in the GUI-Thread or better said something is calling
createPartControl() in another thread than the GUI is running in. Could
you try simply calling:
public void createPartControl(Composite parent) {
If this also produces an exception please log a bug against platform-ui.
The nebula-code is not the culprit here I think although I have only
looked at the parts you presented here.
Tom
Swetha schrieb:
> the error is coming at the line defaultGalleryItemRenderer = new
> foregroundColor =
> foregroundColor =
> backgroundColor =
> createColors();
> The error is,
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks in advance,
> Swetha
Re: Invalid thread access [message #33211 is a reply to message #33176] Wed, 25 April 2007 04:42 Go to previous messageGo to next message
That didn't work.. Before it used to run perfectly.. Suddenly the
error is coming..
Swetha
Re: Invalid thread access [message #33241 is a reply to message #33211] Wed, 25 April 2007 05:46 Go to previous messageGo to next message
It's true that the createPart code should be run for the swt thread. I
think you should check your code that is calling this view, because the
problem should be fixed there.
But if you want fix it here, try something like this :
Display.getDefault().syncExec( new Runnable() {
void run( ) {
Nicolas
Swetha a écrit :
> error is coming..
> Swetha
Re: Invalid thread access [message #33276 is a reply to message #33211] Wed, 25 April 2007 05:52 Go to previous messageGo to next message
I consider this a bug in the Eclipse-Platform and file a bug against it.
It's really a major bug if eclipse is calling createPartControl() out of
the GUI-Thread and many other plugins will fail miserably. So please log
a bug against platform-ui and provide a step to step instruction how to
make this happen!
The work-around from Nicolas will put you on the safe side but please
once more LOG A BUG!
Did you see this behaviour with 3.3M6 or one of the latest I-builds?
Tom
Swetha schrieb:
> error is coming..
> Swetha
Re: Invalid thread access [message #33311 is a reply to message #33276] Wed, 25 April 2007 06:49 Go to previous messageGo to next message
This error is gone.. donno the reason.. I just copied my project in new
workspace and I opened that workspace and run .. working as usual...
In fact my friend also faced the same problem once.. he told to do like
this.. and this is working.. what could be the reason..
Swetha
Re: Invalid thread access [message #33346 is a reply to message #33311] Wed, 25 April 2007 06:55 Go to previous message
It seems the eclipse is starting a thread when starting up (because of
what ever reason but they forgot to sync the calls with to create part).
Please log a bug against Platform-UI attaching your stacktrace.
Tom
Swetha schrieb:
> Swetha
Re: Invalid thread access [message #581120 is a reply to message #33141] Wed, 25 April 2007 03:40 Go to previous message
Tom
Swetha schrieb:
> foregroundColor =
> foregroundColor =
> backgroundColor =
> createColors();
> The error is,
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks in advance,
> Swetha
Re: Invalid thread access [message #581144 is a reply to message #33176] Wed, 25 April 2007 04:42 Go to previous message
error is coming..
Swetha
Re: Invalid thread access [message #581160 is a reply to message #33211] Wed, 25 April 2007 05:46 Go to previous message
void run( ) {
Nicolas
Swetha a écrit :
> error is coming..
> Swetha
Re: Invalid thread access [message #581179 is a reply to message #33211] Wed, 25 April 2007 05:52 Go to previous message
make this happen!
Tom
Swetha schrieb:
> error is coming..
> Swetha
Re: Invalid thread access [message #581205 is a reply to message #33276] Wed, 25 April 2007 06:49 Go to previous message
Swetha
Re: Invalid thread access [message #581219 is a reply to message #33311] Wed, 25 April 2007 06:55 Go to previous message
Tom
Swetha schrieb:
> Swetha
Previous Topic:Invalid thread access
Next Topic:CDateTime uses a lot of Windows handles
Current Time: Tue Jul 15 03:17:28 EDT 2025
Powered by FUDForum. Page generated in 0.11533 seconds
