Home » Eclipse Projects » Eclipse Platform » Activator for plugin is invalid
Activator for plugin is invalid [message #327305] Tue, 15 April 2008 08:18 Go to next message
Originally posted by: victor.osullivan.gmail.com
I have exported my RCP product. when i launch it, i get the following
exception.
I know there have been previous posts with similar problems, but i have
been unable to find a solution.
Exception:
!ENTRY org.eclipse.osgi 2 0 2008-04-15 12:50:51.546
!MESSAGE The activator com.orderingsystem.desktop.gui.Activator for bundle
com.orderingsystem.desktop is invalid
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:234)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:165)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Caused by: java.lang.ClassNotFoundException:
at java.lang.ClassLoader.findClass(Unknown Source)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:429)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
... 22 more
Root exception:
java.lang.ClassNotFoundException: com.orderingsystem.desktop.gui.Activator
Re: Activator for plugin is invalid [message #327309 is a reply to message #327305] Tue, 15 April 2008 09:05 Go to previous messageGo to next message
Victor,
Typically if exported plugins don't function it's because the
build.properties doesn't properly specify what's supposed to be in the
final binary result. You have look in the exported result to verify the
..class files are where the MANIFEST.MF says they will be?
> exception.
> have been unable to find a solution.
> Exception:
> bundle com.orderingsystem.desktop is invalid
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> ... 22 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Activator for plugin is invalid [message #327317 is a reply to message #327309] Tue, 15 April 2008 09:43 Go to previous message
Thanks for you're help Ed. I solved the problem, like you said the problem
was in the build.properties section of the Manifest file.
Victor
Previous Topic:Expanded IGotoMarker
Next Topic:how to get an Action created in another view?
Current Time: Fri Jul 18 01:37:30 EDT 2025
Powered by FUDForum. Page generated in 0.08372 seconds
