Home » Eclipse Projects » Eclipse Platform » Question on IWorkbench restart
Question on IWorkbench restart [message #327282] Tue, 15 April 2008 04:02
Originally posted by: mtp.iki.fi
Does someone know if the calling restart() method
of IWorkbench corresponds either to
1) Normal Eclipse restart without -clean parameter
or
2) Eclipse restart with -clean parameter?
I.e. can the restart() method be used in the situation
when we know there are some plugin updates which are not
loaded by currently running Eclipse? There is need to programmatically
restart Eclipse with samestart-up sequence which happens when
using -clean parameter command-line.
After restart we must be sure that all plugin version changes are detected
and cached information from earlier plugin versions is really removed
and the latest information is in use.
Br,
- Mika -
Previous Topic:Composite preferred size
Next Topic:Set "Always run in background" preference to true and another question.
Current Time: Fri Jul 18 09:56:08 EDT 2025
Powered by FUDForum. Page generated in 0.03483 seconds
