Home » Eclipse Projects » Eclipse Platform » Recommendations on Bundle-RequiredExecutionEnvironment manifest header?
Recommendations on Bundle-RequiredExecutionEnvironment manifest header? [message #327251] |
Mon, 14 April 2008 11:51  |
Hi Everyone,
What is the recommendation in general for the
"Bundle-RequiredExecutionEnvironment" manifest header? In Eclipse 3.4, I
get warnings from the PDE on all of my legacy plug-ins when it is not
set. However, it always recommends a value from my target environment
which will undoubtedly match my installed product's configuration. So, I
guess what I am asking is, should I:
1) Set Bundle-RequiredExecutionEnvironment for *all* of my plug-ins to a
minimum required value such as "J2SE-1.5" (which is what we install with
our product).
2) Individually keep track of the minimum
Bundle-RequiredExecutionEnvironment value for each plug-in, and track
minimum required values for each plug-in (prone to error and a bit of a
pain).
3) Just avoid setting Bundle-RequiredExecutionEnvironment entirely, and
live with the warning.
I also noticed that when I specify a minimum value such as "J2SE-1.5", I
still get a warning about the JRE container on my classpath (currently JRE
1.6) not being a perfect match, so either way I get a warning that I must
ignore. I just am unsure of which warning is more "acceptable". Is there
an Eclipse standard related to this?
Mark.
Re: Recommendations on Bundle-RequiredExecutionEnvironment manifest header? [message #327327 is a reply to message #327256] |
Tue, 15 April 2008 11:06   |
On Mon, 14 Apr 2008 14:21:43 -0400, Chris Aniszczyk <zx@us.ibm.com> wrote:
>> a minimum required value such as "J2SE-1.5" (which is what we install
>> with our product).
> This may be the easiest way to start off with... and probably makes
> sense for your product if you don't care and state that the minimum JVM
> should be 1.5
>> pain).
> This is the approach that the Eclipse SDK takes as it's beneficial to
> our consumers who use Eclipse plug-ins in various runtime environments.
> In your case, it may be too much overhead if your product is only
> "tooling based" and not really meant to run on other types of
> environments.
I guess there is one more question I have on this. You can currently
specify a list of execution environments. Is this recommended at all?
For instance, if a plug-in is compatible with Java 1.4, should I add
J2SE-1.4, J2SE-1.5, and JavaSE-1.6? If not, what is the use case for
allowing multiple values here?
Mark.
Re: Recommendations on Bundle-RequiredExecutionEnvironment manifest header? [message #327336 is a reply to message #327327] |
Tue, 15 April 2008 13:45   |
J2SE-1.4 implies it will work on >=J2SE-1.4
The use case of multiple values is that EE's like Foundation aren't
directly related to J2SE... for example, Foundation 1.1 is a subset of
J2SE 1.3 so you may have a bundle that could run on both of those
environments so you would list them both.
If you look at the OSGi spec, you see this in more detail in the EE
section. The Eclipse project makes heavy use of BREEs, I recommend
checking this link out:
http://www.eclipsecon.com/eclipse/development/eclipse_projec t_plan_3_4.html#Appendix1
Hopefully that wasn't too confusing.
~ Chris
Re: Recommendations on Bundle-RequiredExecutionEnvironment manifest header? [message #327338 is a reply to message #327336] |
Tue, 15 April 2008 15:05  |
On Tue, 15 Apr 2008 13:45:42 -0400, Chris Aniszczyk <zx@us.ibm.com> wrot=
e:
>> I guess there is one more question I have on this. You can currently=
>> specify a list of execution environments. Is this recommended at all=
>> For instance, if a plug-in is compatible with Java 1.4, should I add =
>> J2SE-1.4, J2SE-1.5, and JavaSE-1.6? If not, what is the use case for=
> J2SE-1.4 implies it will work on >=3DJ2SE-1.4
> The use case of multiple values is that EE's like Foundation aren't =
> directly related to J2SE... for example, Foundation 1.1 is a subset of=
> J2SE 1.3 so you may have a bundle that could run on both of those =
> If you look at the OSGi spec, you see this in more detail in the EE =
> section. The Eclipse project makes heavy use of BREEs, I recommend =
> http://www.eclipsecon.com/eclipse/development/eclipse_projec t_plan_3_4=
..html#Appendix1
> Cheers,
> ~ Chris
Thanks again.
M.
Current Time: Tue Jul 22 14:45:35 EDT 2025
Powered by FUDForum. Page generated in 0.06591 seconds
