Home » Eclipse Projects » Eclipse Platform » Embedding Swing toolbar using SWT_AWT Bridge?
Embedding Swing toolbar using SWT_AWT Bridge? [message #327230] Mon, 14 April 2008 08:58 Go to next message
A part of what I am doing involves moving an already existing Swing toolbar
to Eclipse (native). Instead of defining a new action for each action within
the toolbar, is it possible for me to bring the existing Swing toolbar into
Eclipse using the SWT_AWT Bridge?
Rahul
Re: Embedding Swing toolbar using SWT_AWT Bridge? [message #327232 is a reply to message #327230] Mon, 14 April 2008 09:08 Go to previous messageGo to next message
You should ask this in eclipse.platform.swt, they'll have a better
understanding of the SWT_AWT bridge.
Off the top of my head, I would say: 1) you can probably use a Swing
toolbar in a Swing JFrame embedded in an SWT Composite using SWT_AWT and
2) you can't place your Swing toolbar in the eclipse main
toolbar/coolbar, SWT_AWT can't bridge a Swing toolbar into an SWT toolbar.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Embedding Swing toolbar using SWT_AWT Bridge? [message #327234 is a reply to message #327232] Mon, 14 April 2008 09:05 Go to previous messageGo to next message
SWT Composite means basically I am looking at a view placeholder? I'll put
the query in that group as well.
Thanks Paul for the quick reply!
Rahul
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:ftvkl8$qjo$1@build.eclipse.org...
> 2) you can't place your Swing toolbar in the eclipse main toolbar/coolbar,
> PW
> Paul Webster
Re: Embedding Swing toolbar using SWT_AWT Bridge? [message #327339 is a reply to message #327230] Tue, 15 April 2008 15:35 Go to previous messageGo to next message
Rahul,
There is an excellent article on Swing/SWT integration at the following link
http://www.eclipse.org/articles/article.php?file=Article-Swi ng-SWT-Integration/index.html
One of the suggestions is to use a JApplet underneath your AWT Frame you get
from the SWT_AWT Bridge. You may even setJMenuBar() on the applet object.
I hope this helps.
-Stu Pond
"Rahul Kamdar" <rtkamdar@kamdars-india.com> wrote in message
news:ftvkd2$rvn$1@build.eclipse.org...
> toolbar to Eclipse (native). Instead of defining a new action for each
> action within the toolbar, is it possible for me to bring the existing
> Swing toolbar into Eclipse using the SWT_AWT Bridge?
> Rahul
Re: Embedding Swing toolbar using SWT_AWT Bridge? [message #327441 is a reply to message #327339] Sun, 20 April 2008 08:35 Go to previous messageGo to next message
Hi Stuart,
Thanks for the help! I did check out the article but am still trying to
figure out what exactly will be right for my requirement. I am using a
JApplet underneath the AWT Frame returned by the SWT_AWT method call. I'll
also check out setJMenuBar() and see how it works for me.
Thanks again,
Rahul
"Stuart Pond" <Stuart.Pond@ugs.com> wrote in message
news:fu301o$40h$1@build.eclipse.org...
> Rahul,
> link
> get from the SWT_AWT Bridge. You may even setJMenuBar() on the applet
> object.
> I hope this helps.
> -Stu Pond
>> Thanks,
>> Rahul
Re: Embedding Swing toolbar using SWT_AWT Bridge? [message #327443 is a reply to message #327230] Sun, 20 April 2008 10:05 Go to previous message
Originally posted by: automatic.javalobby.org
As an alternative have a look at the Albireo project
which adresses a lot of problems with the swt_awt bridge
and offers an easy to use API to integrate Swing components.
http://wiki.eclipse.org/Albireo_Project
Previous Topic:Issue with deletion of a file and refresh
Next Topic:eclipse freezes after field retrieving
Current Time: Sat Jul 26 07:44:19 EDT 2025
Powered by FUDForum. Page generated in 0.26049 seconds
