Home » Eclipse Projects » DTP » Reverse engineering
Reverse engineering [message #272] Mon, 09 May 2005 12:01 Go to next message
Hi for everyone.
I work a lot of time in database reverse engineering, I can help in this
subject if anybody thing this is useful (I think there is a lot).
We can make reverse engineering direct from the catalog of the database or
from a SQL Script.
Re: Reverse engineering, WTP [message #282 is a reply to message #272] Tue, 10 May 2005 13:45 Go to previous messageGo to next message
Originally posted by: christian.sell.netcologne.de
Hi Alejandro (and others),
have you looked at the database tooling in the WTP project? It is quite
extensive, also covering reverse engineering (via JDBC and, I think,
from an SQL script). I think it will be unified with this project.
I must say, however, that I dont like the design very much. I tried to
add an extension for Postgresql, and it was quite a mess. I also really
wonder what the benefit of modeling the base layer with EMF is..
Alejandro Narancio wrote:
> Hi for everyone.
> or from a SQL Script.
Re: Reverse engineering, WTP [message #290 is a reply to message #282] Tue, 10 May 2005 20:58 Go to previous messageGo to next message
Originally posted by: john.graham.sybase.com
Hi Alejandro and Christian,
Yes, the rdb tools currently in WTP will be consolidated into DTP. I don't
know the particulars about the reverse engineering case discussed below, but
I will pass this information along. Perhaps we can get a discussion about
reverse engineering requirements and contributions going in this thread,
since I think DTP would benefit greatly from solid functionality in this
area.
John Graham
john.graham@sybase.com
Eclipse DTP
"Christian Sell" <christian.sell@netcologne.de> wrote in message
news:d5qsf0$rkp$1@news.eclipse.org...
> extensive, also covering reverse engineering (via JDBC and, I think, from
> I must say, however, that I dont like the design very much. I tried to add
> an extension for Postgresql, and it was quite a mess. I also really wonder
>> Hi for everyone.
Re: Reverse engineering, WTP [message #299 is a reply to message #282] Tue, 10 May 2005 22:05 Go to previous messageGo to next message
Originally posted by: rgreene.versant.com
Hi Guys,
In the DTP consolidation meetings, there were several contributions from
different groups in this area. Ultimately, it was collectively decided that
we would use the model driven approach taken by the WTP. This gives an
abstracted way of dealing with the underlying database through a logical
model allowing consistent access/extension points independent of the chosen
physical model. It was recognized that we need to extend support for more
physical models (databases). Several committers from the ORM project, which
currently supports 15 different databases, will be collaborating with IBM
and others to extend this area.
-Robert
> > Hi for everyone.
Re: Reverse engineering, WTP [message #313 is a reply to message #299] Wed, 11 May 2005 06:01 Go to previous messageGo to next message
> physical model.
hmm - any development is model-driven, IMO. What EMF introduces is another
intermediate notation/language, and a generation step, of which I dont see
the benefit. I would count it much easier to code the model directly in
Java, and go from there. You can abstract as much in Java as you can in
any other language. To understand the WTP stuff at the model level, you
have to first learn EMF. But I guess this is a vain discussion, so we can
leave it here..
what ORM project are you referring to? When I look at the newsgroups, I
see jsr220-orm and ejb-orm.
regards,
christian
> Cheers,
> -Robert
>> > Hi for everyone.
Re: Reverse engineering, WTP [message #331 is a reply to message #313] Wed, 11 May 2005 18:35 Go to previous messageGo to next message
Hi Christian,
It is the jsr220-orm project.
-Robert
Re: Reverse engineering, WTP [message #336 is a reply to message #313] Thu, 12 May 2005 18:19 Go to previous messageGo to next message
I fully support the EMF driven approach because of the following reasons:
We have a domain specifc model, which we map to a relational model. Because
the WTP RDB model has been done by using EMF, defining this mapping is
relatively easy:
1. We define a Rose "mapping model" that connects the related classes from
our domain model to the RDB model.
2. EMF not only generates the Java API, but also the XML/XMI serialisation,
with support for cross file references. Note that support for cross file
references is not trivial to get out-of-the-box with standard XML or JAXB
tools, AFAIK.
So I don't see a (big) disadvantage of using EMF, only an advantage.
Yes, there is a learning curve (as the EMF book has some pages), but JAXB
tools and code conventions to deal with notifications, bidirectional
references, proxies and meta-data also have a learning curve.
* Stefan
PS: I'm not involved in the DTP / WTP project, we are just using EMF and
plan to use DTP once it is stable.
news:4e685fd370c797b6a7bf041dd0602fdf$1@www.eclipse.org...
that
chosen
> > physical model.
> leave it here..
which
IBM
> regards,
> christian
> > Cheers,
> > -Robert
> >> > Hi for everyone.
this
database
Re: Reverse engineering, WTP [message #341 is a reply to message #336] Thu, 12 May 2005 18:45 Go to previous message
a few things I dont understand:
- What role does Rose (proprietary UML tool) play here? Or will rose
also be donated as OSS ;-)?
- How do you envision the "connect" part? I dont think Rose (if used)
will support stuff like schema updates and other advanced requirements,
so the benefit of an automated toolset may quickly become questionable.
You may even end up battling the tool to accomodate your requirements.
- what use do you see for "cross file references"? All we are talking
about at the moment is serialization/persisting of a model definition..
regards,
Christian
> tools, AFAIK.
> * Stefan
> that
> chosen
>>>physical model.
>>leave it here..
> which
> IBM
>>regards,
>>christian
>>>Cheers,
>>>-Robert
>>>>>Hi for everyone.
> this
> database
Re: Reverse engineering, WTP [message #565123 is a reply to message #272] Tue, 10 May 2005 13:45 Go to previous message
> Hi for everyone.
Re: Reverse engineering, WTP [message #565148 is a reply to message #282] Tue, 10 May 2005 20:58 Go to previous message
area.
John Graham
Eclipse DTP
>> Hi for everyone.
Re: Reverse engineering, WTP [message #565175 is a reply to message #282] Tue, 10 May 2005 22:05 Go to previous message
Hi Guys,
-Robert
> > Hi for everyone.
Re: Reverse engineering, WTP [message #565232 is a reply to message #299] Wed, 11 May 2005 06:01 Go to previous message
> physical model.
leave it here..
regards,
christian
> Cheers,
> -Robert
>> > Hi for everyone.
Re: Reverse engineering, WTP [message #565274 is a reply to message #313] Wed, 11 May 2005 18:35 Go to previous message
Hi Christian,
-Robert
Re: Reverse engineering, WTP [message #565300 is a reply to message #313] Thu, 12 May 2005 18:19 Go to previous message
relatively easy:
tools, AFAIK.
* Stefan
that
chosen
> > physical model.
> leave it here..
which
IBM
> regards,
> christian
> > Cheers,
> > -Robert
> >> > Hi for everyone.
this
database
Re: Reverse engineering, WTP [message #565348 is a reply to message #336] Thu, 12 May 2005 18:45 Go to previous message
regards,
Christian
> tools, AFAIK.
> * Stefan
> that
> chosen
>>>physical model.
>>leave it here..
> which
> IBM
>>regards,
>>christian
>>>Cheers,
>>>-Robert
>>>>>Hi for everyone.
> this
> database
Previous Topic:Package/plug-in naming and CVS organization suggestion
Next Topic:Using DTP components as runtime "Schema Container"?
Current Time: Tue Jul 08 02:46:39 EDT 2025
Powered by FUDForum. Page generated in 0.14337 seconds
