Home » Eclipse Projects » Eclipse Platform » .JETEmitters Project
.JETEmitters Project [message #327125] Thu, 10 April 2008 14:17 Go to next message
Originally posted by: tim.visher.gmail.com
Does anyone know what this project is? I didn't create it and it's
been giving me path errors in the Problems view for a while. I can't
even access it from within the project browser.
Thanks in advance!
- Timmy V.
Re: .JETEmitters Project [message #327127 is a reply to message #327125] Thu, 10 April 2008 15:22 Go to previous message
Tim,
It's a hidden project created when you use dynamic templates with EMF's
generator (we don't use dynamic templates by default though) or created
by default by clients using EMF's JETEmitter class, again for
dynamically compiling JET templates. The navigators and explorer filter
..* resource by default so will not show this project (which is why we
use that name for it). You can unfilter .* resources to get access to
it. You should be able to delete it without adverse affects; whatever
tool is creating it will create a new one when it needs it and that will
help you find out what's causing it to be created. UML's generator, I
believe, creates one, but the one they create shouldn't have errors in
it...
> Thanks in advance!
Previous Topic:document.get() has more than I taped
Next Topic:Delegating Drag and Drop, bug 10146
Current Time: Mon Jul 14 05:38:55 EDT 2025
Powered by FUDForum. Page generated in 0.07339 seconds
