Home » Archived » Test and Performance Tools Platform (TPTP) » using TPTP Profiling tools
using TPTP Profiling tools [message #33124] |
Thu, 29 September 2005 03:46  |
I try to use TPTP profiling tools to trace and monitor
my application running in another Eclipse workbench just
like the demo. however, i encounter the following problem.
If I run my application without being monitored, it takes
about, let's say 10 sec to complete a method call. If it's
monitored, it takes much longer to execute. In this case,
it cannot show the exact performance of my application, so
how can I analyze the data collected, and what can I do
about it?
Lee.
Re: using TPTP Profiling tools [message #33196 is a reply to message #33124] |
Thu, 29 September 2005 09:57   |
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 004CABE78525708B_=
Content-Type: text/plain; charset="US-ASCII"
Profiling a run-time workbench can be quite slow if you don't filter out
the unwanted data.
To make things faster, you should filter out all the information you're
not interested in by modifying the filters specified in your profiling
set. Simply, click on the 'Profiling' tab, in the 'Overview' sub-tab,
select your profiling set, click on 'Edit', click on 'next', select only
the profiling options you're interested in (selecting the graphical
details option can also slow things down), click 'next', specify your
filter set.
Navid Mehregani
IBM Canada
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Profiling a run-time workbench can be
quite slow if you don't filter out the unwanted data.</font>
<br><font size=2 face="sans-serif">To make things faster, you should filter
out all the information you're not interested in by modifying the filters
specified in your profiling set. Simply, click on the 'Profiling'
tab, in the 'Overview' sub-tab, select your profiling set, click on 'Edit',
click on 'next', select only the profiling options you're interested in
(selecting the graphical details option can also slow things down), click
'next', specify your filter set.</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
<br><font size=2 face="sans-serif">IBM Canada</font>
--=_alternative 004CABE78525708B_=--
Re: using TPTP Profiling tools [message #33332 is a reply to message #33231] |
Thu, 29 September 2005 21:38   |
David, Marius, thanks for your quick response, i appreciate it.
in regarding to the filters, i do add my own filter set, which
actually contains one class since i am interested in monitoring
a method invocation of that class. and what does the method do
is retrieve some data from database and display them on the UI.
the problem is if i limited the row retrieved, it is ok. but if
i retrieved 5000 records as i did yesterday, the time that the
application displays the result on the UI are much slower when
it is monitored.
without monitoring, it takes about 10-15 sec to see the results.
with monitoring, it takes about 45-60 sec to see the results.
Lee.
Re: using TPTP Profiling tools [message #35000 is a reply to message #33332] |
Tue, 11 October 2005 19:35  |
Lee,
What's your jvm heap size? When your application retrieve more records
(5000 in your case), the jvm may allocate more phyical memory. And, if
it is bigger than the heap size, the jvm may spend too much time on
garbage collection. If you are using default setting, one thing you can
try is to increase the heap size by -Xmx argument.
BTW, did you try remote monitoring? Would it reduce the monitoring overhead?
Kelvin
Actuate
xiang li wrote:
> Hello,
> David, Marius, thanks for your quick response, i appreciate it. in
> regarding to the filters, i do add my own filter set, which actually
> contains one class since i am interested in monitoring a method
> invocation of that class. and what does the method do is retrieve some
> data from database and display them on the UI. the problem is if i
> limited the row retrieved, it is ok. but if i retrieved 5000 records as
> i did yesterday, the time that the application displays the result on
> the UI are much slower when it is monitored.
> Lee.
Current Time: Tue Jul 15 04:28:26 EDT 2025
Powered by FUDForum. Page generated in 0.04189 seconds
