Home » Eclipse Projects » Eclipse Platform » Dynamic menus
Dynamic menus [message #327060] Tue, 08 April 2008 03:09 Go to next message
Originally posted by: matthieucguard-ikariam.yahoo.fr
I'm developping an RCP application and I don't understand the
commandParameter item under the org.eclipse.ui.commands extension point.
I tried to follow the problem view example but my dynamic menu remains
grayed.
Can someone help me?
Re: Dynamic menus [message #327076 is a reply to message #327060] Tue, 08 April 2008 12:51 Go to previous messageGo to next message
A command definition can specify the command takes a parameter.
showView is like that, you can execute the showView command with an ID.
A keybinding or org.eclipse.ui.menus command can specify a parameter to
execute with ... for example ALT+SHIFT+Q C is showView(id=Console)
(pseudo-code).
parameters have no impact on the enabled/disable state of the command,
however.
How are you creating your "dynamic menu"? How are you instantiating a
command with a parameter?
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Dynamic menus [message #327133 is a reply to message #327076] Fri, 11 April 2008 05:17 Go to previous message
Thanks a lot for your help.
The problem came from the name of the parameter that was false.
> (pseudo-code).
> however.
> PW
Previous Topic:Delegating Drag and Drop, bug 10146
Next Topic:org.apache.tools.ant.Task#getProject() returns null in custom ant task when called from within JUnit
Current Time: Thu Jul 17 20:03:49 EDT 2025
Powered by FUDForum. Page generated in 0.06190 seconds
