Home » Eclipse Projects » Eclipse Platform » Switch off remembering last opened editor
Switch off remembering last opened editor [message #326964] Thu, 03 April 2008 13:42 Go to next message
I have a problem with the opening of editors. I have two editors. One just
on just an object while the other is basically an editor which shows the
differences between two selected objects.
The problem I have is when I select two objects and open it with the
Diffing editor, The diffing editor is associated with that object. The
next time I double click on a single object, It tries to open the diffing
editor since the last open the diffing editor. I will have to again open
the actual editor using "open with" context menu. But, I want the basic
editor to open every time I double click and the diffing editor should
open only when I seect two objects and use "Open with" context menu.
Can someone let me know if I can switch off Eclipse's feature of
remembering the lsat opened editor on the object.I guess this could solve
my problem.
Thanks in advance,
Wishwas.
Re: Switch off remembering last opened editor [message #326984 is a reply to message #326964] Thu, 03 April 2008 16:56 Go to previous messageGo to next message
Wishwas wrote:
> Hello,
> just on just an object while the other is basically an editor which
> shows the differences between two selected objects.
> diffing editor since the last open the diffing editor. I will have to
> again open the actual editor using "open with" context menu. But, I want
> the basic editor to open every time I double click and the diffing
> editor should open only when I seect two objects and use "Open with"
> context menu.
> solve my problem.
No, there is no way to do it right now. I requested such a feature
almost a year ago, but it has received no attention:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=184747
Perhaps if you add your own comments and/or vote for that bug, it might
get fixed in 3.4.x or 3.5...
Eric
Re: Switch off remembering last opened editor [message #327007 is a reply to message #326964] Fri, 04 April 2008 09:23 Go to previous messageGo to next message
What kind of editor input do you use for your diffing editor? A
CompareEditorInput returns null for getPersistable(), so if you are
already using that it won't help.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Switch off remembering last opened editor [message #327017 is a reply to message #327007] Fri, 04 April 2008 14:09 Go to previous messageGo to next message
It is a FileEditorInput.
> PW
Re: Switch off remembering last opened editor [message #327018 is a reply to message #326984] Fri, 04 April 2008 14:27 Go to previous message
Voted for. Let us wait and see.
Eric Rizzo wrote:
> Wishwas wrote:
>> Hello,
>> context menu.
>> solve my problem.
> Eric
Previous Topic:Putting the Eclipse platform to work
Next Topic:Re: Size information fdrom IFile
Current Time: Tue Jul 15 07:10:03 EDT 2025
Powered by FUDForum. Page generated in 0.04525 seconds
