Home » Eclipse Projects » Eclipse Platform » PDE Build fails with "Java returned 13"
PDE Build fails with "Java returned 13" [message #326894] Wed, 02 April 2008 15:17 Go to next message
Originally posted by: kosta.bea.com
We are in the process of adopting 3.4 M6 into our product build. Our
existing build works fine with 3.4 M5, but is having issues with M6. My
guess it's an interaction between p2 and PDE build. I am hoping that
someone has seen this before and knows a workaround.
Our build basically takes the eclipse distros (eclipse platform sdk +
several others), unzips them all into a "target platform" location and
then does a basic invocation to PDE build. That worked with M5. With M6,
we are getting "Java returned: 13" when calling PDE build.
The log file has the following exception:
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:362)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
at org.eclipse.core.launcher.Main.main(Main.java:30)
What's weird is that if after the build fails, I go to the target
install directory, launch eclipse, let it sit for 10 minutes thinking,
and then cancel from the "pick the workspace dialog", the build will run
fine after that.
I tried adding a call to start target platform eclipse with -initialize
before calling PDE build, but that doesn't change the outcome.
Is this a known problem? Does anyone know of any workarounds?
- Konstantin
Re: PDE Build fails with "Java returned 13" [message #326898 is a reply to message #326894] Wed, 02 April 2008 17:11 Go to previous message
Opened bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=225410. Looks
like it's a known issue with M6. Removing p2 from the eclipse sdk
distribution (http://wiki.eclipse.org/Equinox_p2_Removal) works around
this problem.
- Konstantin
Previous Topic:Search step-by-step tutorial for writing web service (and deploy to AppServer)
Next Topic:LinkageError when executing an Ant task that implement BuildListener
Current Time: Wed Jul 16 01:02:02 EDT 2025
Powered by FUDForum. Page generated in 0.03986 seconds
