Home » Eclipse Projects » Eclipse Platform » Dialogs in org.eclipse.ui.workbench JAR
Dialogs in org.eclipse.ui.workbench JAR [message #326844] Wed, 02 April 2008 01:09 Go to next message
Hi. I'm not sure if this is the right forum to post this. If not, please
let me know what is.
There was a recent article by Suresh Krishna in Eclipse Zone called
"Discover Eclipse's JFace Dialogs"
( http://eclipse.dzone.com/news/discover-eclipses-jface-dialog ?page=0%2C2),
about some very handy JFace Dialog classes.
Several of these (CheckedTreeSelectionDialog,
ElementListSelectionDialog, ElementTreeSelectionDialog, ListDialog,
ListSelectionDialog, and TwoPaneElementSelector) appear to be found in
the org.eclipse.ui.dialogs package of the org.eclipse.ui.workbench*.jar
file (including in 3.4M6).
I would have thought they would be in the JFace JAR file. Because they
are not, in order to use these in a stand-alone package, one has to
include this extra JAR file, which isn't too bad (once you have figured
out where they are!).
However, to further complicate matters, if you look at the plug-in
dependencies of the org.eclipse.ui.workbench, you get a long list of
over 25. Yet, at least based on some quick tests, it appears you can use
these Dialog classes without all of these other JAR files.
I find this confusing. Are these dialogs intended to be able to be used
in a non-plug-in Java project? If so, would it make sense to move them
either into the JFace JAR or somewhere that didn't have all of these
other org.eclipse.ui.workbench depencencies?
I apologize if I'm missing something basic here. Thanks.
Re: Dialogs in org.eclipse.ui.workbench JAR [message #326943 is a reply to message #326844] Thu, 03 April 2008 09:46 Go to previous message
> [...snip...]
They ended up in the org.eclipse.ui.workbench project as part of the
org.eclipse.ui split. Maybe they weren't considered general enough to
be added to JFace ... also, they're API, which means that their package
can't change (but jface dialogs are org.eclipse.jface, not org.eclipse.ui).
It's not that some of them couldn't be pushed down to JFace. But they
would need to have workbench level classes/dependencies removed, and it
would probably be for the most general dialog support (distilled to
their most useful essence). Patches are always welcome :-) but would
not be considered now until 3.5.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Questions about Sections and Forms and how to delegate actions to them
Next Topic:"Enum cannot be resolved", "Enum is not generic" compiler errors
Current Time: Sun Jul 27 07:17:43 EDT 2025
Powered by FUDForum. Page generated in 0.03588 seconds
