Home » Eclipse Projects » Eclipse Platform » selectionchanged on CommonNavigator
selectionchanged on CommonNavigator [message #326802] Tue, 01 April 2008 10:26 Go to next message
Originally posted by: colin.ninian-owen.com
I need to call my own action every time a project is selected in the navigator view - in-fact my own view extended from CommonNavigator. Can someone please suggest the best approach?
Re: selectionchanged on CommonNavigator [message #326813 is a reply to message #326802] Tue, 01 April 2008 12:03 Go to previous messageGo to next message
You can register a selection changed listener on the CommonViewer that's
associated with the CommonNavigator.
Just call getCommonViewer() on the CN.
Re: selectionchanged on CommonNavigator [message #326859 is a reply to message #326813] Wed, 02 April 2008 05:16 Go to previous messageGo to next message
I suppose then I would need to sub-class CommonNavigator (myNavigator->CommonNavigator) and reference that from my viewer extension instead...
<extension
point="org.eclipse.ui.views">
<view
class="myNavigator"
etc../>
</extension>
then I can register the selection changed listener in the constructor? The Eclipse documentation says CommonNavigator is not intended to be sub-classed!
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/api/org/eclipse/ui/navigator/Comm onNavigator.html
Re: selectionchanged on CommonNavigator [message #326861 is a reply to message #326802] Wed, 02 April 2008 05:19 Go to previous messageGo to next message
Sorry, I notice the syntax of the xml and url to CommonNavigator didnt post correctly - but you get my drift!
Re: selectionchanged on CommonNavigator [message #326883 is a reply to message #326859] Wed, 02 April 2008 11:20 Go to previous messageGo to next message
no you don't need to subclass the CN, just get the viewer by calling
getCommonViewer() on the CN once it has been created.
(no worries with your XML, I get the idea)
> <extension
> <view
> class="myNavigator"
> etc../>
> </extension>
Re: selectionchanged on CommonNavigator [message #326997 is a reply to message #326883] Fri, 04 April 2008 06:07 Go to previous messageGo to next message
Thanks for the info. but how do I get the CommonNavigator instance?
Re: selectionchanged on CommonNavigator [message #327027 is a reply to message #326997] Sun, 06 April 2008 10:44 Go to previous message
You can obtain it by looking into the workbench the workbench window and
obtain the view by the name you gave it or its default name. The CN is
actually a view part. Once you obtain the view, cast it to get the the
getCommonViewer method.
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().findView( "yourCNFViewName")
This works from nearly anywhere in the application. If the CN is always
around, stick it into a singleton that you know where to find easily but
I always dynamically get it.
Previous Topic:Common Navigator for Workbench Resources - Refreshing View
Next Topic:Terminate paused console output of a batch file called as external tool
Current Time: Tue Jul 22 07:33:18 EDT 2025
Powered by FUDForum. Page generated in 0.04547 seconds
