Home » Eclipse Projects » Eclipse Platform » LinkageError when executing an Ant task that implement BuildListener
LinkageError when executing an Ant task that implement BuildListener [message #326781] Tue, 01 April 2008 08:47 Go to next message
Originally posted by: patrick.laplante.cmcelectronics.ca
I have a plugin that contains ANT tasks. One of these task implement
org.apache.tools.ant.BuildListener
All the tasks are working fine except the one implementing BuildListener.
I receive:
BUILD FAILED
Test.xml:18: The following error occurred while executing this line:
java.lang.LinkageError: org/apache/tools/ant/BuildEvent
when launching the target inside eclipse. Some interesting observation:
1- This task works when the target is launched from outside eclipse.
2- Also, it works inside eclipse but when I launch the build in the same
JVM and this is not exactly what I want.
Hope someone can help
thanks
Re: LinkageError when executing an Ant task that implement BuildListener [message #326900 is a reply to message #326781] Wed, 02 April 2008 18:58 Go to previous message
I would take an educated guess that your Ant tasks were compiled against an
incompatible version of BuildEvent.
Are you using the same Ant home entries for all runs?
HTH
Darins
http://runnerwhocodes.blogspot.com
"Patrick laplante" <patrick.laplante@cmcelectronics.ca> wrote in message
news:920b5d85edcf5f6eab5e5b023d03adff$1@www.eclipse.org...
> I receive:
> BUILD FAILED
> thanks
Previous Topic:PDE Build fails with "Java returned 13"
Next Topic:CommonNavigator, LinkHelper
Current Time: Sat Aug 30 23:29:23 EDT 2025
Powered by FUDForum. Page generated in 0.03416 seconds
