Home » Eclipse Projects » Eclipse Platform » menu/toolbar items based on open editor
menu/toolbar items based on open editor [message #326767] Tue, 01 April 2008 00:23 Go to next message
I've tried using org.eclipse.ui.menus extension point, but struggling since
this is newer than any books I have.
First issue - I have a menu and toolbar buttons that I only want to be
displayed when certain editors are chosen. How would I control that?
Once those options conditionally appear, I want them disabled until focus is
on certain widgets. How would I control that?
My actions will change the data in the widget with focus. How do I get to
the widget to contol it?
Re: menu/toolbar items based on open editor [message #326798 is a reply to message #326767] Tue, 01 April 2008 10:14 Go to previous messageGo to next message
You want a visibleWhen element, similar in content to this example:
http://wiki.eclipse.org/Command_Core_Expressions#Active_edit or_type
You can declaratively work through the enabledWhen core expression
(although it seems to me you would have to use a property tester).
The other alternative is to activate you handler in your
createPartControl(*). That way it would have access to all of your
editors widgets and you could update your enabled State (and fire the
appropriate HandlerChangeEvent) to make it enabled/disabled.
With code? You created the widget, didn't you? What are you asking to
control what, exactly?
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: menu/toolbar items based on open editor [message #326810 is a reply to message #326798] Tue, 01 April 2008 11:20 Go to previous messageGo to next message
One problem I had was I had the enabledWhen on the command and not the
handler...
Is there a way to know what page of a multi-page editor is active, and not
which editor is active? I want to make visible the toolbar only when a
certain page is selected, and that page might belong to several editors.
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:fstfmd$fh2$1@build.eclipse.org...
>> is on certain widgets. How would I control that?
>> to the widget to contol it?
> PW
> Paul Webster
Re: menu/toolbar items based on open editor [message #326828 is a reply to message #326810] Tue, 01 April 2008 14:16 Go to previous message
> handler...
You could write your own property tester for activeEditor (IEditorPart)
.... if you find your multi-page editor part, you can check your information.
But you need to request the IEvaluationService update that property
tester property when your MPEP changes pages (re-evaluation available in
3.4M6)
PW
Paul Webster
Previous Topic:executing org.eclipse.ant.core.antRunner with or without shell
Next Topic:Plugin.start(final BundleContext context) is not called from UI thread
Current Time: Mon Jul 21 21:18:04 EDT 2025
Powered by FUDForum. Page generated in 0.44052 seconds
