Home » Eclipse Projects » Eclipse Platform » Docs for getting started with org.eclipse.ui.menus / handlers ?
Docs for getting started with org.eclipse.ui.menus / handlers ? [message #326749] Mon, 31 March 2008 10:59 Go to next message
Hi all,
I'm wondering what the recommended doc is as starting point for
org.eclipse.ui.menus / handlers / core.expressions and the like.
I find the extension points reference a bit hard to consume, and I
haven't seen lots of examples either. No luck searching for Articels nor
for a webcast on live.eclipse.org -- where should I start looking?
The EclipseCon 2007 presentation looks quite OK but I had hoped for
something more article-style with examples...
http://www.eclipsecon.org/2007/index.php?page=sub/&id=36 92
should I go for the Wiki,
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Re: Docs for getting started with org.eclipse.ui.menus / handlers ? [message #326768 is a reply to message #326749] Tue, 01 April 2008 01:49 Go to previous messageGo to next message
Mostly the Wiki. From Paul Webster's signature:
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Martin Oberhuber wrote:
> Hi all,
> Cheers,
Re: Docs for getting started with org.eclipse.ui.menus / handlers ? [message #326794 is a reply to message #326768] Tue, 01 April 2008 10:08 Go to previous message
Other information:
is the starting place for 3.3, it walks through the
org.eclipse.ui.examples.contributions plugin. This plugin has been
updated with more examples in HEAD for 3.4 as per the eclipsecon talk,
http://www.eclipsecon.org/2008/?page=sub/&id=221
There is an article in the works as well, although it's not likely to be
finished until after 3.4.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=223445
Paul Webster
Previous Topic:mouse listener for the vertical bar
Next Topic:How to make one page on a Multi-Page read-only ?
Current Time: Mon Jul 14 07:46:49 EDT 2025
Powered by FUDForum. Page generated in 0.04764 seconds
