Home » Eclipse Projects » Eclipse Platform » Product extension with relative path in link files
Product extension with relative path in link files [message #326718] Mon, 31 March 2008 05:07 Go to next message
Hi all,
We use a lot the product extension mechanism through link files. We have
some extension locations installed somewhere and we have some link files
in the links directory with an absolute path to the extension.
It works fine when the path in link file is absolute. But it doesn't work
when specifying relative path in the link file.
Could you please tell me if there is something special to do to support
relative path in link files ? Otherwise, is it a bug or a known limitation
? If any, are there any plan for it ?
Jerome
Re: Product extension with relative path in link files [message #326727 is a reply to message #326718] Mon, 31 March 2008 07:38 Go to previous messageGo to next message
Jerome,
You and Manuel should coordinate your questions. If I recall correctly,
there was a bugzilla open about this and I seem to recall some
activities to support it in 2.4...
Jerome Correnoz wrote:
> Hi all,
> have some extension locations installed somewhere and we have some
> link files in the links directory with an absolute path to the extension.
> work when specifying relative path in the link file.
> support relative path in link files ? Otherwise, is it a bug or a
> known limitation ? If any, are there any plan for it ?
> Jerome
Re: Product extension with relative path in link files [message #326753 is a reply to message #326727] Mon, 31 March 2008 12:08 Go to previous message
Thanks Ed for your answer.
You're right, we didn't coordinate with Manuel on this topic, sorry about
that.
In fact, the relative path work correctly. Previously, we failed because
we specified a path relative to the .link file. We have to specify a path
relative to eclipse.exe to do it work properly.
Jerome
Previous Topic:Enhanced quickassist plugin
Next Topic:disabled action at startup
Current Time: Mon Jul 21 21:25:28 EDT 2025
Powered by FUDForum. Page generated in 0.03935 seconds
