Home » Eclipse Projects » Eclipse Platform » Cannot Install Any Plugins, Weird Dependency Error
Cannot Install Any Plugins, Weird Dependency Error [message #326710] Sun, 30 March 2008 11:41 Go to next message
Originally posted by: tim.visher.gmail.com
Hello Everyone,
I'm running the latest Eclipse Europa version on Mac OS 10.5.2. I have
never run into this issue before. I went to install Findbugs
(something I've done on Windows many times) today and I got the
following error.
Data Tools Platform Enablement for ODA Runtime (1.5.2.2000802201)
requires feature "org.eclipse.datatools.connectivity.oda.feature
(1.5.2)", or compatible.
I tried hitting Select Required to no effect.
I then selected every available update site in the "Find and Install
Updates..." Dialog and brought them all up. Any feature I select in
the dialog comes up with the exact same error, which is even more
bizarre. I can’t even install the DTP.
Any thoughts as to what I could do to fix this problem? If there's a
better place I can post, just let me know.
Thanks in advance!
- Timmy V.
Re: Cannot Install Any Plugins, Weird Dependency Error [message #326711 is a reply to message #326710] Sun, 30 March 2008 13:15 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Tim Visher" <tim.visher@gmail.com> wrote in message
news:fsocba$1ve$2@build.eclipse.org...
> Hello Everyone,
> never run into this issue before. I went to install Findbugs (something
> I've done on Windows many times) today and I got the following error.
> Data Tools Platform Enablement for ODA Runtime (1.5.2.2000802201) requires
> feature "org.eclipse.datatools.connectivity.oda.feature (1.5.2)", or
> compatible.
> Updates..." Dialog and brought them all up. Any feature I select in the
> dialog comes up with the exact same error, which is even more bizarre. I
> can't even install the DTP.
You might also want to try posting in eclipse.webtools, in case someone more
familiar with DTP recognizes the problem.
What JRE are you running on? (Are you sure? Check in Help -> About ->
Configuration Details to be sure.)
You say that the problem hasn't happened before. Any clues about what might
have changed? Firewall settings, other software installed in the interim,
Have you tried searching Bugzilla to see if anything similar pops up? The
problem sounds familiar to me but not familiar enough to point me in a
specific direction. I'd probably first try searching for bugs with that
feature name in the comments.
Re: Cannot Install Any Plugins, Weird Dependency Error [message #326736 is a reply to message #326710] Mon, 31 March 2008 08:52 Go to previous messageGo to next message
Tim Visher wrote:
> Hello Everyone,
The first thing I'll mention is that the Update Manager will not install
any new features until the current configuration is error-free - that is
why you get the message for whatever feature you try to install.
The missing feature *shuould* be available on the Europa Discovery Site;
keep in mind that the Select Required button only works well if you have
expanded all the root nodes in the list of update sites - it does not
search the site contents until its nodes are expanded and Select
Required can't see features that have not been "loaded" yet. There is a
bugzilla report to correct this, but I don't have it handy. Anyway,
Update Manager is being replaced in Eclipse 3.4, so it seems unlikely
this bug will be fixed.
If you still can't locate that feature in the DTP, you can try disabling
the feature that is requiring it (Data Tools Platform Enablement for ODA
Runtime) via the Manage Configuration dialog.
Hope this helps,
Eric
Re: Cannot Install Any Plugins, Weird Dependency Error [message #327107 is a reply to message #326736] Wed, 09 April 2008 19:20 Go to previous messageGo to next message
On 2008-03-31 08:52:33 -0400, Eric Rizzo <eclipse-news@rizzoweb.com> said:
> Tim Visher wrote:
>> Hello Everyone,
> g
> e
> Hope this helps,
> Eric
Thanks for the thoughts, Eric. How can I find out if my configuration
is error-free? I understand that it looks like it is but I don't see
any place glaringly telling me that I have an error in my configuration.
Thanks in advance!
- Timmy V.
Re: Cannot Install Any Plugins, Weird Dependency Error [message #327123 is a reply to message #327107] Thu, 10 April 2008 13:00 Go to previous message
>> Tim Visher wrote:
>>> Hello Everyone,
>> g
>> e
>> a bugzilla report to correct this, but I don't have it handy. Anyway,
>> Hope this helps,
>> Eric
Well, the Update Manager told you ;-)
Other than that, I think you can go to the Manage Configuration dialog
(via Help > Software Updates) and see if any features in the list are
marked as error.
You can probably open the Error Log view (Window > Show View > Other)
and see if any plugs report that they can't load. If you don't have
Error Log view, you can open the file directly in <workspace>/.metadata/.log
Hope this helps,
Eric
Previous Topic:Include jre in pde build!
Next Topic:document.get() has more than I taped
Current Time: Sun Jul 27 08:43:14 EDT 2025
Powered by FUDForum. Page generated in 0.04925 seconds
