Home » Eclipse Projects » Eclipse Platform » Plugin Required-Bundle
Plugin Required-Bundle [message #326684] Fri, 28 March 2008 09:50 Go to next message
Originally posted by: douglas.wieland.osv.fedex.com
Is there a way that 2 plugins “A” and “B” requiring different conflicting
versions of a common plugin can work in the same RCP plugin environment?
Plugin “A” has a requirement:
Require-Bundle: com.common.plugin;bundle-version="[1.0.0,2.0.0)”
Plugin “B” has a requirement:
Require-Bundle: com.common.plugin;bundle-version="[2.0.0,3.0.0)”
When plugin “B” is installed plugin “A” quits working. Is there a way
plugin “A” can use one version of the common plugin and “B” can use
another version?
Doug
Re: Plugin Required-Bundle [message #326688 is a reply to message #326684] Fri, 28 March 2008 10:27 Go to previous messageGo to next message
Doug,
I think this can only work if the common plugin isn't a singleton (which
means it can't use or introduce extension points).
Doug wrote:
> Hello,
> Is there a way that 2 plugins �A� and �B� requiring different
> conflicting versions of a common plugin can work in the same RCP
> plugin environment?
> Plugin �A� has a requirement:
> Require-Bundle: com.common.plugin;bundle-version="[1.0.0,2.0.0)�
> Plugin �B� has a requirement:
> Require-Bundle: com.common.plugin;bundle-version="[2.0.0,3.0.0)�
> When plugin �B� is installed plugin �A� quits working. Is there a way
> plugin �A� can use one version of the common plugin and �B� can use
> another version?
> Doug
Re: Plugin Required-Bundle [message #326689 is a reply to message #326684] Fri, 28 March 2008 10:32 Go to previous message
Bundles can do that ... plugins with plugin.xml cannot (since they have
the singleton:=true directive).
if your com.common.plugin doesn't have a plugin.xml it might be do-able.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Implementing A custom content compare/merge viewer
Next Topic:[Databinding] databinding arrays and lists of strings
Current Time: Sun Aug 31 23:41:36 EDT 2025
Powered by FUDForum. Page generated in 0.03430 seconds
