Home » Eclipse Projects » Eclipse Platform » External Tool Builders isn't executed "During manual builds and auto build
External Tool Builders isn't executed "During manual builds and auto build [message #326604] Wed, 26 March 2008 06:18
Hello!
We are using the "External Tool Builders" to generate Java-Sources from
IDL files.
One Project (test_idl) contains the IDL files and another project contains
the generated sources (test_java).
In "test_java" we added an External Tool Builder who calls the
idl-compiler and we added the complete "test_idl" project in the "working
set of relevant resources" (with options "during clean", "during manual
builds" and "during auto builds" activated).
If we change the IDL-Files in "test_idl" with Eclipse 3.2 the Builder from
"test_java" is executed.
If we do the same with Eclipse 3.3.1.1 and 3.3.2 the External Builder
isn't executed. The only option which works is "during a clean".
Has anyone the same problems or any hints?
Alexander
Previous Topic:What is a content type??
Next Topic:How to create a directory
Current Time: Mon Jul 21 23:59:55 EDT 2025
Powered by FUDForum. Page generated in 0.03360 seconds
