Home » Eclipse Projects » Eclipse Platform » Plugin.getDefault().getDescriptor().getInstallURL() is deprecated
Plugin.getDefault().getDescriptor().getInstallURL() is deprecated [message #326371] Tue, 18 March 2008 05:09 Go to next message
Originally posted by: alexjaquet.gmail.com
In one action I load an image by doing the following code
private static ImageDescriptor image;
static {
URL url = null;
try {
url = new
URL(PageUIPlugin.getDefault().getDescriptor().getInstallURL( ),
"icons/obj16/saveAsImage.png");
} catch (MalformedURLException e) {
image = ImageDescriptor.createFromURL(url);
but .getDescriptor().getInstallURL() is deprecated what do I need to use
in place of it ?
Alexandre
Re: Plugin.getDefault().getDescriptor().getInstallURL() is deprecated [message #326377 is a reply to message #326371] Tue, 18 March 2008 09:46 Go to previous message
Originally posted by: angelo.tata.gmail.com
Alexandre Jaquet ha scritto:
Hi, Alexandre.
If you take a look at the Javadoc for IPluginDescriptor you'll find the
information you need (for this and other deprecated methods).
In your case, anyway, you should use:
getDefault().getBundle().getEntry("/")
instead of
And here's the JavaDoc for 3.2:
http://help.eclipse.org/help32/topic/org.eclipse.platform.do c.isv/reference/api/org/eclipse/core/runtime/IPluginDescript or.html
Have a nice reading... ;-)
A.
> static {
> URL url = null;
> try {
> url = new
> use in place of it ?
> Thanks
> Alexandre
Previous Topic:elipse - problem with closing and relaunching
Next Topic:Table Viewer Vs Nebula Grid Viewer
Current Time: Fri Jul 25 02:39:51 EDT 2025
Powered by FUDForum. Page generated in 1.27309 seconds
