Home » Eclipse Projects » Eclipse Platform » Eclipse classpath variables programmatically
Eclipse classpath variables programmatically [message #326353] Mon, 17 March 2008 10:21 Go to next message
How do it get classpath variables programmatically? I defined a new
classpath variable MY_HOME to point to a directory and tried to use the
following code to access it in my eclipse plug-in:
IPath bootstrapPath = new Path("MY_HOME").append("jlibs.jar");
IRuntimeClasspathEntry bootstrapEntry =
JavaRuntime.newVariableRuntimeClasspathEntry(bootstrapPath);
bootstrapEntry.setClasspathProperty(IRuntimeClasspathEntry.U SER_CLASSES);
Doen't seem to work.. can anyone help me ?
Re: Eclipse classpath variables programmatically [message #327525 is a reply to message #326353] Wed, 23 April 2008 10:17 Go to previous message
Originally posted by: automatic.javalobby.org
Ok, I found the answer myself..
I could use JavaCore.getClasspathVariable(String variablename). But i
cannot use it in a headless plug-in.
The specific scenario I had in mind was to use the path pointed to by a
classpath variable in a launch configuration. I was trying to build a launch
configuration programmatically. For that purpose, there is a simple method
call in the JavaRuntime class which acheives this:
Here's an example:
JavaRuntime.newVariableRuntimeClasspathEntry(new Path("JRE_LIB"));
And, if you look at the lauch configuration, you can add entries to the
bootstrap classpath or the user-defined classes. To add this environment
variable entry to the bootstrap classpath, you just need to say:
bootstrapEntry.setClasspathProperty(IRuntimeClasspathEntry.B OOTSTRAP_CLASSES);
OR if you need to add it to the user-defined entries, you would say:
IRuntimeClasspathEntry userEntry =
userEntry.setClasspathProperty(IRuntimeClasspathEntry.USER_C LASSES);
Or if you want to make another entry, and still add it to classpath , but
not display it in the "classpath" tab al all (kinda hiding it), you would
say:
IRuntimeClasspathEntry hiddenOrDefaultEntry =
setClasspathProperty(IRuntimeClasspathEntry.STANDARD_CLASSES );
This would add the entry to the classpath, but the entry would not be
displayed in the launch configuration's classpath tab.
Another example: If you wanted to add an external jar file to the
user-defined classes section of the classpath, you would do that with the
following couple of lines:
IRuntimeClasspathEntry myJarEntry =JavaRuntime.
newArchiveRuntimeClasspathEntry(new Path("/usr/lib/myjarfile.jar"));
myJarEntry.setClasspathProperty(IRuntimeClasspathEntry.USER_ CLASSES);
Hope this helps anyone who tries to build a launch config programmatically.
It aslo helps to read the article at:
http://www.eclipse.org/articles/Article-Java-launch/launchin g-java.html
Previous Topic:Recover from update
Next Topic:programming for eclipse -debug console option
Current Time: Sat Aug 30 02:22:54 EDT 2025
Powered by FUDForum. Page generated in 0.02880 seconds
