Home » Archived » Visual Editor (VE) » VE M1 RC1 out and posted
VE M1 RC1 out and posted [message #33038] Mon, 26 April 2004 15:47 Go to next message
Originally posted by: spam.idan.fastmail.fm
If you are using 3.0m8, then you should check this build out. It seems
much better than the last couple of integration builds, furthermore it's
a candidate for a "stable" build, which means the devs punted this one
around a bit more than usual, I guess...
http://download.eclipse.org/tools/ve/downloads/drops/S-M1RC1 -200404261021/index.html
It seems to feature new widget/bean placement UI for GridBagLayouts,
take a look and you'll see (placement no longer defaults to (-1, -1)).
At least, this was the most visible UI difference I saw (there are
probably many more I have missed). It also seems faster.
Hats off,
Idan
Re: VE M1 RC1 out and posted [message #33143 is a reply to message #33038] Mon, 26 April 2004 18:37 Go to previous messageGo to next message
I followed your tip and now VE can produce the java class and close the
wizard window. But upon loading the Visual Java class it gives out an
error:
Error trying to set new file into editor.
Reason:
Plug-in org.eclipse.jem.beaninfo was unable to load class
org.eclipse.jem.internal.beaninfo.core.BeaninfoNature.
I am a newbie. Could this be something I am missing? Some kind of
configuration?
I installed by unziping the three projects (EMF, GEF and VE) to the
eclipse folder.
I searched through documentation but couldn't find anything else!
Thanks for the help.
JOEL
Re: VE M1 RC1 out and posted [message #33323 is a reply to message #33143] Tue, 27 April 2004 10:10 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Could you please attach the .log file? That may give me more info.
Thanks, Rich Kulp
Re: VE M1 RC1 out and posted [message #33392 is a reply to message #33038] Tue, 27 April 2004 11:43 Go to previous messageGo to next message
Hey devs,
Might be a good idea to post a newsbit about M1RC1 on the front page of
the project (http://www.eclipse.org/vep) -- the last info there is
pretty stale. (december 2003)
I bet the eclipse homepage would post a blurb about it too...
Idan
Re: VE M1 RC1 out and posted [message #33426 is a reply to message #33392] Tue, 27 April 2004 13:43 Go to previous messageGo to next message
This build is a Release Canidate for the Milestone 1 build (meaning it's
not the official M1 build yet). We'll be a bit more vocal when the
actual M1 is available.
Glad our users are so eager :)
- Jeff Myers
Idan Gazit wrote:
> Hey devs,
> Idan
Re: VE M1 RC1 out and posted [message #33443 is a reply to message #33143] Tue, 27 April 2004 18:23 Go to previous messageGo to next message
Originally posted by: mylastname.mycompany.com
On Mon, 26 Apr 2004
> Reason:
I had something like this happen to me using the eclipse 0420 build - I
found that removing my ~/.eclipse directory (unix, not sure of
windows equivalent) fixed it
Matt
Re: VE M1 RC1 out and posted [message #33546 is a reply to message #33323] Wed, 28 April 2004 13:57 Go to previous messageGo to next message
Originally posted by: witthawa.uiuc.edu
I have the same problem.
Eclipse M8
VEP M1RC1
EMF build I200403250631
GEF Build I20040330
Windows XP
Below is my log file.
!ENTRY org.eclipse.jem.beaninfo 2 0 Apr 28, 2004 12:46:52.209
!MESSAGE Introspection failed on class "javax.swing.JLabel." msg="."
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/ui/PlatformUI
org.eclipse.jem.internal.beaninfo.adapters.UICreateRegistryJ obHandler.proces
sCreateRegistry(UICreateRegistryJobHandler.java:42)
org.eclipse.jem.internal.beaninfo.adapters.CreateRegistryJob Handler.createRe
gistry(CreateRegistryJobHandler.java:51)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature.ge tRegistry(Beanin
foNature.java:354)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature$6. getRegistry(Bean
infoNature.java:292)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoAdapterFa ctory.getRegistr
y(BeaninfoAdapterFactory.java:77)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getRegistry(
BeaninfoClassAdapter.java:276)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(B
eaninfoClassAdapter.java:440)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIf
Necessary(BeaninfoClassAdapter.java:395)
org.eclipse.jem.java.impl.JavaClassImpl.getEAnnotations(Java ClassImpl.java:3
66)
org.eclipse.jem.internal.beaninfo.core.Utilities.getDecorato r(Utilities.java
:159)
org.eclipse.jem.internal.beaninfo.core.Utilities.getBeanDeco rator(Utilities.
java:153)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.reflectPrope
rties(BeaninfoClassAdapter.java:959)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectPr
operties(BeaninfoClassAdapter.java:690)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getEStructur
alFeatures(BeaninfoClassAdapter.java:594)
org.eclipse.jem.java.impl.JavaClassImpl.getEStructuralFeatur es(JavaClassImpl
..java:373)
org.eclipse.jem.java.impl.JavaClassImpl.getProperties(JavaCl assImpl.java:115
7)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.allPropertie
s(BeaninfoClassAdapter.java:757)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getAllProper
ties(BeaninfoClassAdapter.java:602)
org.eclipse.jem.java.impl.JavaClassImpl.getAllProperties(Jav aClassImpl.java:
1196)
org.eclipse.ve.internal.java.codegen.java.ExpressionDecoderF actory.reSetCach
eIfNeeded(ExpressionDecoderFactory.java:134)
org.eclipse.ve.internal.java.codegen.java.ExpressionDecoderF actory.getExpDec
oder(ExpressionDecoderFactory.java:92)
org.eclipse.ve.internal.java.codegen.model.BeanPart.setEObje ct(BeanPart.java
:475)
org.eclipse.ve.internal.java.codegen.model.BeanPart.createEO bject(BeanPart.j
ava:798)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.createJavaIns
tances(JavaSourceTranslator.java:626)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.buildComposit
ionModel(JavaSourceTranslator.java:707)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocumen
t(JavaSourceTranslator.java:816)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(Jav
aSourceTranslator.java:589)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.r
un(JavaVisualEditorPart.java:1224)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:62)
!ENTRY org.eclipse.ve.java.core 4 0 Apr 28, 2004 12:46:52.219
!MESSAGE Exception thrown.
!STACK 0
rties(BeaninfoClassAdapter.java:960)
..java:373)
7)
1196)
:475)
ava:798)
Wee
Re: VE M1 RC1 out and posted [message #33612 is a reply to message #33546] Wed, 28 April 2004 17:43 Go to previous messageGo to next message
You are putting the latest VE over an existing one. We changed one
pre-req for a plugin and Eclipse had cached the old configuration and
didn't see that there was a new one. Go to the eclipse directory and
delete the configuration directory. That will cause a recache with the
current list of plugins.
Thanks, Rich Kulp
Re: VE M1 RC1 out and posted [message #34146 is a reply to message #33612] Fri, 30 April 2004 15:38 Go to previous message
I deleted the c:\eclipse\configuration and re-ran eclipse. Now it works
nicely. Thanks.
Wee
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:c6p85n$9fa$1@eclipse.org...
> Thanks, Rich Kulp
Re: VE M1 RC1 out and posted [message #587196 is a reply to message #33038] Mon, 26 April 2004 18:37 Go to previous message
error:
Reason:
configuration?
eclipse folder.
JOEL
Re: VE M1 RC1 out and posted [message #587276 is a reply to message #33143] Tue, 27 April 2004 10:10 Go to previous message
Thanks, Rich Kulp
Re: VE M1 RC1 out and posted [message #587311 is a reply to message #33038] Tue, 27 April 2004 11:43 Go to previous message
Hey devs,
Idan
Re: VE M1 RC1 out and posted [message #587324 is a reply to message #33392] Tue, 27 April 2004 13:43 Go to previous message
- Jeff Myers
Idan Gazit wrote:
> Hey devs,
> Idan
Re: VE M1 RC1 out and posted [message #587337 is a reply to message #33143] Tue, 27 April 2004 18:23 Go to previous message
On Mon, 26 Apr 2004
> Reason:
Matt
Re: VE M1 RC1 out and posted [message #587384 is a reply to message #33323] Wed, 28 April 2004 13:57 Go to previous message
Eclipse M8
VEP M1RC1
GEF Build I20040330
Windows XP
!STACK 0
foNature.java:354)
66)
:159)
java:153)
..java:373)
7)
1196)
:475)
ava:798)
!STACK 0
..java:373)
7)
1196)
:475)
ava:798)
Wee
Re: VE M1 RC1 out and posted [message #587413 is a reply to message #33546] Wed, 28 April 2004 17:43 Go to previous message
Thanks, Rich Kulp
Re: VE M1 RC1 out and posted [message #587597 is a reply to message #33612] Fri, 30 April 2004 15:38 Go to previous message
nicely. Thanks.
Wee
> Thanks, Rich Kulp
Previous Topic:Not able to Add JButton or JLabel to any container
Next Topic:Accelerating Eclipse VE
Current Time: Wed Jul 16 04:02:53 EDT 2025
Powered by FUDForum. Page generated in 0.11709 seconds
