Home » Eclipse Projects » Eclipse Platform » PDE build problems with enum
PDE build problems with enum [message #326347] Mon, 17 March 2008 04:17 Go to next message
--nextPart24128817.3K8mAqcnLh
Content-Type: text/plain; charset=utf-8
Content-Transfer-Encoding: 8Bit
Hi there!
I'm trying to build several features using a headless PDE build environment.
Unfortunately I have a problem with enums. I get the following error
message when running the org.eclipse.ant.core.antRunner application on my
builder environment:
@dot:
[mkdir] Created
dir: /tmp/java_compiler_enum_test/buildDirectory/plugins/org.acov eo.callcenter.masterData/temp.folder/@dot.bin
[javac] Compiling 2 source files
to /tmp/java_compiler_enum_test/buildDirectory/plugins/org.acov eo.callcenter.masterData/temp.folder/@dot.bin
[javac]
[parsing /tmp/java_compiler_enum_test/buildDirectory/plugins/org.acov eo.callcenter.masterData/src/org/acoveo/callcenter/masterdat a/MasterDataObject.java -
#1/2]
[javac]
[parsing /tmp/java_compiler_enum_test/buildDirectory/plugins/org.acov eo.callcenter.masterData/src/org/acoveo/callcenter/masterdat a/RingStrategy.java -
#2/2]
[javac] [reading org/eclipse/emf/ecore/EObject.class]
[javac] [reading org/eclipse/emf/common/notify/Notifier.class]
[javac] [2 units compiled]
[javac] ----------
[javac] 1. ERROR
in /tmp/java_compiler_enum_test/buildDirectory/plugins/org.acov eo.callcenter.masterData/src/org/acoveo/callcenter/masterdat a/RingStrategy.java
(at line 1)
[javac] /**
[javac] ^
[javac] The type java.lang.Enum cannot be resolved. It is indirectly
referenced from required .class files
[javac] ----------
[javac] 2. ERROR
(at line 1)
[javac] /**
[javac] ^
[javac] The type Enum is not generic; it cannot be parameterized with
arguments <RingStrategy>
[javac] ----------
[javac] 2 problems (2 errors)
[javac] Compilation failed. Compiler errors are available
in /tmp/java_compiler_enum_test/buildDirectory/plugins/org.acov eo.callcenter.masterData/temp.folder/@dot.bin.log
The build is invoked as follows:
java -jar /tmp/eclipse-builder/baseLocation/eclipse/plugins/org.eclips e.equinox.launcher_1.0.1.R33x_v20070828.jar -verbose -application
org.eclipse.ant.core.antRunner -buildfile /tmp/eclipse-builder/baseLocation/eclipse/plugins/org.eclips e.pde.build_3.3.2.R331_v20071019/scripts/build.xml -Dbuilder=/tmp/java_compiler_enum_test/buildConfiguration
&> antRunner.log
I have set
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
in my plugin manifest as well as:
JavaSE-1.6=/usr/lib/jvm/java-6-sun/lib/rt.jar:/usr/lib/jvm/j ava-6-sun/lib/jsse.jar
javacSource=1.6
javacTarget=1.6
in my build.properties file. The plugin compiles just fine within eclipse.
Other java 5 feature (like generics) work fine with my headless PDE build.
In order to reprocude my testcase (the real plugin contains a lot more) you
need the following plugins for eclipse:
http://ftp-stud.fht-esslingen.de/pub/Mirrors/eclipse/modelin g/emf/emf/downloads/drops/2.3.2/R200802051830/emf-sdo-xsd-SD K-2.3.2.zip&mirror_id=17
http://ftp-stud.fht-esslingen.de/pub/Mirrors/eclipse/modelin g/emft/teneo/downloads/drops/0.8.0/S200803051429/emft-teneo- SDK-incubation-S200803051429.zip&mirror_id=17
http://ftp-stud.fht-esslingen.de/pub/Mirrors/eclipse/modelin g/emf/validation/downloads/drops/1.1.1/R200708161055/emf-val idation-SDK-1.1.1.zip&mirror_id=17
http://ftp-stud.fht-esslingen.de/pub/Mirrors/eclipse/modelin g/mdt/ocl/downloads/drops/1.1.2/R200711281212/mdt-ocl-SDK-1. 1.2.zip&mirror_id=17
http://ftp-stud.fht-esslingen.de/pub/Mirrors/eclipse/modelin g/mdt/uml2/downloads/drops/2.1.1/R200708301304/mdt-uml2-SDK- 2.1.1.zip&mirror_id=17
Any ideas why it the source does not compile using a headless build as
opposed to building from within eclipse?
Florian
Florian Hackenberger
Content-Type: application/x-gzip; name="java_compiler_enum_test.tar.gz"
Content-Disposition: attachment; filename="java_compiler_enum_test.tar.gz"
H4sIAKEk0UcAA+29aVvcyJIo3F9dvyJffN5p7AHVAlVg2vQ0xvgMfb0wYPc8 c3t8uaIkCtkqqUZS
Yejz+Pz2G5GLlFJpK6gNHJo5bUqKzIzMjDUzMvKLeW2e9/3hyHHt4Nz2xsPz yA6j5k8zfFrw7HS7
+G97p9vS/1XPT+3WTm+702l3O1s/tTqtdnv7J9adJRJFzziMzICxny6vzP5X 27uwg4Ed5MBVfX+g
z5eC+Te96HTseXZguP7gnm3gBPe2t/Pnv9fubrXaav47bYTrdHrwirVm0sOK 5wef/4OR2b+y2YEX
sWs7CB3fY21jx2gxSRMWgzev7b49hJ6z9hbrwJQ1Xo0d17qEz3usGQ1HTbvv OqPQ3rzA93bQvDBD
+63fNyOoT31sjtzxwPHCph8MDPnOGFm2wQudbxlbRsc43dpqn19DGzvtVvtF M+wHzigKmxzEuBm6
jZEJSHoDdqEwWDAC7JsTXbFPp8dsn/EBWHD/TwL/i92PGLbALCdgoR2xyF/M PDT+BLHgOhd7WNTk
lGNEvu+GBrz/zA79sWsxz4+Y65sWs+xLx3Ow6ZBdBv6QBXboj4O+zaB4UxRv 8uIobZqiauykwY4j
oD9V2YXNLv2xZxmND0CigWPZzBl4fgC0eekHbBT4IzuIbtma7PVag/2pXn5m bwEVJBg+PkXSjpc8
9L1LZzAOxGiJIZf1ODb2/dp0XPPCtT+zN4jP3tR19kHY+MOPJoiQKOTTWdGj VIE1wXYw4/8ztr2+
zWEj/m09fMb+79B0vJ+ZE7I/8a/PjUPAybUjW/BKUkxBbLCRH0a8zg12aUf9 qw1sum+H4QYzwxBY
3rXxlS1h+q5tQqmBDWrBjPATiERzAH98bjSwxr0lkydjSKB903U/M/wvznsy QH+qnnxmjicHZQkS
hETYUmmkrgypB/faCaArfnBbr8BJLE7mJKQqkMCq+0KcVCIcfnVGr2DwKwHl BCDsp9O31QMBcH5Y
Cdb3XReGFkbljV9rRobmKDy8svtf/XH00RxUwkfOEEbVHI7qdrBO5/p8eqp7 9ztMxNnRZtvo1erX
qT3y61HYx9tR9Yzh1L6DamvNVSUQJ6ozrtnrdcb3q6kPW/5WjSDIr8iG16/t ke1ZoN5uOQnUwgOI
pA6d/OWAwK4xpWbQv3Ku7ZMAzJ6bSmj4yxr3q8eBD+4bMDw+eEdB4FezARpZ 7hilg2HZ1+98q3pS
OOEcW/Xg6ks8cByPbiLbQ6ei1nzjCNZD4q15Ybv1xu61fTEeHHuX1fyDXPEG zaBayCqdVC1nzKAW
/SgxWnMyeOf+sIMLvwaLBmPvRNhqQEDzNGRRiYGZde3441BzAJh/WWzVTmcD V0Bz49Tp1zSZlUUo
zObYPiw1nRN7uJb5LCztMtNZt1qPPBBnsSWwMJvMMIyHMFINVeMeDBoM2/Ar mI+f2Rkw7qie+RRL
L/Aq++YYDFAnYqYb2KZ1y+wbJwRyXroTw/vGPep8J+bMjsajXCfmXixc4Jfc p858V+NeWC53co6H
Iz9Ao/Rugw7TeeTaQ9uTw8OXRVZh5rKI3XfeMvWliDot4+7T8Vpii3NLLLYE 71SJLQ4FsinpBXtt
u/bABNFhKIll8FWwvn9t+wYyat/GjhlDM4R/XpuR+cY2o3FgG8DC4xtjEH01 bnZ7KWGIf8q28M83
UjbCn3+P5V8fDVqkYRc9LJSMEf6BPfA9RC2FZ4ymXhBtfb6Qc6JkKVQCL9/A mKeLi8YP9MWfBBOo
98oO3vqDsHBochG574B5/mv70hy7UawdsCtKgYzGF64TcpVia4hDNxKQwJZD i6QF/zUHSe85ZFrH
8CnZSxPtjRPNhmZXW71ohEEahjQMaZgqDaMxjFAyWbGrc1Sp3ikp+NBVka56 fgRtowZyGr2Tnv69
lJv+ycN/QQgBr3jWNH5OE1e6sCAKsdhNVguAjYZGZHsN7kiBS618oxj+Z1Xg Z6zHmJdmxDr7vgfC
9DN77wt/DKtWG4chMz3cE2Qe1Al4RvYNjKrlI4znR1fw72pr15jJSLeSbiXd Wum9KXaR7lvMPeX+
W6LJFqI1yWtbKT0aT/+KRyNMUATphBWMB9B4A+ltjXTIHXVIpReVZoasL1Ug Ret6VHWE8PL8KtIE
89AExftqc18RIFomWp7X6gDO+l7hJn6Zupxqkz4J/2pMkFrVSgFCxysFGhPO dKVgPgsQBdgubid+
tY1WvntP8bMUP0vxsxQ/S/GzFD9L8bMUP0vxsz9q/Cw3B4V7KyzDUhf2MvEX lUNZFAVa79DZg4ic
XfIYNXiNVR7bG4FkuctGTpBauRfjTH4Q+UHkB5EfRH4Q+UHkB5EfRH7Qj+oH KYtQmPmxfVhq6WvW
ev3TcRM2/0PzhlZipBqqxuWHCFWd9ft7ma9BwUEUMLqSwT5LPO7395SA0Tmo 6tBfbgzDAzxsMYtY
ix8tvEKb/h/z3J82naRqSNWQqqlSNRoeQtXoHFSqalJi9wdRNRTJF6sarTfL dz9K9znyxp2Uwwpu
NtAhhYUcUsjjhwnZn3BKXSWgy7QHog0onPthHk0gCiYKnr0ZE/dm+fZMRW4b MVlnHHwp0RvpbYVl
hnFMYrKceI6cEVlpW6vuznzhjnKxw7r4oa6/XyN4RugK3IxLos0kN5XqirwS KdGlpKAUKfG+Tvxb
F6/ibxEpEMYbOzEo3xnKFHzleGbgIDQXkvFXEGSI216yJSSQ45JMzqQ/jkbj 6NPIgq+/A7OusSsz
lDcT2B4SpwYsd+/DN34wNKNSUBjpPugkD7OY/MfYdJ1Lxw5KS4RAagDVB9r5 Q1zW8doZOFE5Rqpj
lizy1vYG0VVpkZFrRoDdUAszmgT/U1Efn28lU8/8IUw5kvUmUuomyFhLcQDU A9Vc21o9QNshdNsy
Cqp7NfYsl18YERP7TWgZtoVzll/kyQGmgrFBagBjAUH6XnyzSWhjKJBt7eVW eN4B5mkZyDe7rU6r
297datVHyx5ewt8gCICvnJnhlqqVI9i5P4IzHb10tRzF9v1R7F+Z3sCeA5Ki 4hlN9ezxu98UAyXP
kivuT2/gyAx9zxjPliHiWmdLbfPiC632GdDdzHFUaGUnunAXbAlmygM7RrzS XpDuKtNqLm31PZzV
2WWmIcuEleg8VJmMbOmBJZSMbJnJyJLAkmXrhdLdPj4upBBWcMmJtvcWsr3H GUDmauK8UJ6PSYiR
h7Lf8ePI90e9gUc0SjRaP2cYTv+KWx0Ud0q2x0rM9MqEFlE0KUWTrrwdQvRK 9ErRzyuhuMhEIROF
op8pdvThKIEVMFqIgomCf7DoZz3wkWKfKfaZYp9rLbZLjtEjn1OcVCPuOR1y PKeo52xwdXkUdBL3
rCMnUx/8afev/M9T3TJ5KcSzmJoacryCzufVah0ROb2Pd3eEqrN5zr3hO3gR M+nv8glgCtNzFj2e
anNPExy1JQy3vAyF4AYL7Ev4F+yZwPcjbscMAn88Otf+qwSD4XIR07+C+gMb avrLGRmWE0aBc8Fz
AG6Ito0vQKUbbMzPQqim1Df5FkDiai8czwDCRuNRwEC9oahdtCjehkqoyWLx 7xhzbvadg9l3zs0+
rCAGwl5LzSB+JN3IiDku3/60bBzMz+zQH7sWP4vAL9WdP8/VhDtvGy34PxhH vLdXYGs8JMxx1pF4
cLYfaBeAOh8w9mHQz2K/LHFbtcQaMyup3UesdivXZWIy0NVfWp2lxHxWA6Uo qYbCvGPV81Sqy1Wi
0oK48+LcYiwkopQVohRpWlWtBciFu8gejozLeinYVRkLyAtcVpEeuaHPxJ74 KaeiauWtJuXqywtl
hDt3N7IuIjPTY9M3eC/9dYf+LXaCZ5NUvuYNBUnK8uQEtufmnLiedYr3KfOa T5UpfKqk7dNk/p/m
6okLfoby9ylq10pM1cYrkJyHrhmGIxCpZeucc+OQqZYXkps+NljtpYaCQpNq JKXUdEX0m+VHecoq
VpWTmg1VjxiMCe21waSfo2tHnstV4bmndNSJNl0A+RF0kbwNZJLL5rFUUHs6 czy3peBRBTD/NYpZ
o1oyqriDx8NFLNX6fDDVTKD89ufdahMZkDMe8OayhyBGZtmI3PEU+L2EdaOR dh6kPas8gL07Hnif
iRd27/GYS9uPKuvAw6qWrlpfRvyp3AumSwbpkkG6ZJAuGaRLBumSQbpkkC4Z pEsG738U42FeMigN
wngFj1uHVSt2Msp54t68R3zh+gqMU0PWuOIh4UmsPB1so0RwD+eg2hKvFzxJ C5eYf6ouF4wPnDyU
I0L3PPL8AA8OzfNywROlD37EjKPaDJKeIT1Deoaya1B2DcquQdk1VkI5UHYN yq6xStrgMbsYlF2D
KJgo+DFm10if3Kf8GpRfg/Jr1NyoycmwkeGmGse0spkzyrJszC2rRtHdgmnk ZnRaadbJL8QOG4+h
p6O4j/co7kpnwEhoUJcGGmXWkAQJ9HwTYqxWEgwtA0hlLoxkhJYniigvAAkj ygvwgE57U14AohTK
C3CvvACzsbApOQAlB6DkAJQcYLbJAbKe1+Rh/7peWFnJWeYKkPpmUunVSRkw gzQBuhelR6l/8vBf
PGvOD75jP/AHiqSYMPDlwnVTqcuFGJFWIq20WK2E9XjVZ2OEGK116AcB/xCX 3s/+uNLK6ERFNwdB
9ZGweelPoOjzC9Bs/USzVc3OdNB5unNldPoS7IZyBY4CvEh1c+E+pdJO6d9q dT0vRZ22O+69CDEP
0+mHGPmUuVTn1KOhJmPtLtZV1YFUjjvWUO8IpgHjMXajuusM06xJCFQySxI4 hSLW/8/hVxCUn9lh
YMPoW2gHzMcAKEytw/7kUv0zgxqaooZmUkNT1GBhDe/iyj5coOViYEFmWhbg DRM0fXku7Jnl26H3
c8TsG8wJPR1Kp8DgZxHuwA5up0UnVbYSlUM+EyhPOkwwAzcSQ7TdlzNfn7h1 /Pvrj0y12rCA7Eb3
39PvAx0bwdjDrAKcT6HIBXQ+ugVGGeD64u057vW3Wy2Db/W3tto9jqQI10R9 hFPgROkRvQN+5yK2
QGFZhrU9vDTAQIIB/TLyb85bxq4h0NttbbW67e3OixVC0XUuAh4VcFc8J2mT I8VA74xlgLcO8vOm
5+N5op8zb1M2V+ZjcxwGTUC0+eV6yMl7s7cZjj3+KkDuD/bKQL6EIVcn2SYL m1sUF90zuEjnDh70
krBBd4vnvPvznyh8VB0I33QQMc90myPQvnaA6j1sYuha/7b5fK8EXjYEQP86 AZR8+7fnz5vPP9+z
Y344cESHMIrnRkTxtHY7u7xPqeYRtGlfw3BnEeNfLgNzaH/zg6+Apxf67gT6 GShe03AQVICBcZML
EdrBtdO3myjWXdXTUkD00UohbO/aCXxvWNRDBYfNuc5f1U2KAYfhuBbeZykw z3sBgOVAY48vJZUC
jQO3qk1gKHNgD00PMyrkgowjx1UfMlOiv1VtQoMWWD9D0xo6Xi6EDKMqAYDi Tog4F8OEYGNHLpCO
m/sZep56zzsB6r7/lfdykuUUN5mWOYIxKYWJ2XMqYMA4CrOgHDm+YJJf1cR3 4fyh8VEJeuX7X6sb
dH3TmhyTzESXYZdAKcYqg4mHgw9STVgwqCO/77tTw4vRAjYOJgRtzbLIjGjv TV08lvR1Swa26yBH
F86tJgrNsde/qpw1ybmTIHGbVZQXAw59a1yAlt71Qty1XsbCrQQKAJxLpwoK Grx2uJhIlZiJOgQv
3PH8GzSAh77HFaPS89udXpWeT3RzCRBaX4vQ7Nxk+eJfhJPqfaf1oqorWLAU SwkwO1Sn9j2UORaD
pEtWzZUsVWGJKShOgvVAw5FTMb/F36xbzxw6wOQuaMPyCRDNLG/8aXCnEyna SGat7VaHqHX6AdW8
qgx1djuVA6q7ZKUDpQPaN/0r0xuUD0q65hwzF77PVnKC7R2BsRPdjuwJNq0U 9LJwaZcSmHmLG3Mc
XWUnU3LHTGnHHI14Dvhqr1eWaEKJLKGoT4ljwGEmpxzeu07sos7Mbzdk/Uj+ baMTj1iv1b3fiOGC
zA2v3bWj846xHRtBvXa7vbO1e6fqp1wzs5FMoHGkBrFS1ml127tytSU9R8PL pi09i4IPznDkFn8V
OBR/19yBKojyhnSvevLrzdBtgkS1Q/CVS9pKg5U3mIatbh6FSA2I6kYFmOKM alCJ2pyJStr1talK
wOehL7/IpKklEPiP6VklEJ4fOZe31QBFgy6h7jiCJSJa0nSY8oN6re3ZyeN0 O2llME89YHoRbzsj
OZXhMLu+XZsBd++FiZL1JWfXjn0DdgVfPMvOVm+z1Wq3Ztwc3wa7DSN7CGq0 rbc2t4bkQfSb3V6q
ye323Zq8izYybobOtBoJipRJP6dSlDoLEo2ih6Hl8x626vcQihTjjx/Le4gQ ixT+X8r7KIFkrxYy
5sKpmHbY812Rie/lgy+BFjP+FRu1xeCG7QGefdvKHw8O2ETAvI5qX/sm+KoV MLYLfnEFzBAM+slt
k3wgMwz9vpO7V5RfQIWR1IB2vIkNrQxUmeGqgV2brmPd1T9ZGBXQ5D+Oyc+b 97LJLUTf9MAy5uhM
LD7lA1XNnQ6Loeh1YdGLKQTksQ/xflsBUKH7Kj+rMOBiEEUTFTSswEIZBTUF ZJEqEeDV1BZiBbbl
D4tBitxP8XWRaqo8WEdYCeGm6w+gjkFCveaIixn5vSm/qy4VfJUDu5B+aWQ7 LR+muWPoW3YJOeQB
lxNQXomiBYviEilpVqtc/GP6AtN0KCk1TaeSUosU00lb3NdqS19rt91rb293 82kkhd8/S75qi0K1
wOA936ye3BcuKuG2W7WRUGu0NcGL5k6DHZrB13xRrwMVcY8Gk7OTUACZdKIM qgbuQpEtxOuxLSfi
Pk87x+eZNwaq7TxH/s6LFyDWDecC/tcfn28ZvZhtXuSsiszhkuBszKW1rFjL LCLX4rhT5vVvc8EH
6zuU1RmGgRcXZdEBrbuskTEm2k79+Hhls58Z+OSB2YdqQmYGeL0Ri+C9fWP3 xxE/RmrCqzjkF/6y
U5XgmQk89IFXFmFBuf6cjmx/o8LYL2wVSW6lg4fxmRelNrktNPWxgxXCb+IM Qgq3P9Ux1tUbQ7bJ
nrabnc8riO/kuQ7AtTOBa2CLqybhyV/TOtJPmtQvnN5reY//ONCLvFo6bOw5 wHqKc9KfN+Mn9bpt
sKPT0w+neKB6lQZ53YyY63g2az9L4fuk+fx5+sX/mRBW6K4x/G24JnhBR9AH 1uc2KwoWGfRnGew4
wnNtjicu8HZvWWzZWOLIQ4B76XiQSh7K4cv+dUa181hHlY+lI47AyUSav+CJ kGR4gWnNoY0HHv+C
geMH2ROt8FJH6ddaI4kH2EC9DEO23mE2Hn4O07jrR04uTSR8gyldKwugNmJx 4oO5TUrJ/fX3uyL9
Lte2p3J3LKxNugr+8V4Ff5fxfRCXqzdefTp++5q9OTh+e/S6sdjW9zrdPS5e QW64/jfsPpdZzO/3
xwHqnm9XmHBEGNo8FcoVyF8U4nuLRnVn956o3odU9tqtxbWeuRFjr91Z8Uma FAR7L+6L89wF517n
xcqjOF+qu4+63Wtvz5Uf74dbG8SatMKkVfYLC21b+f6adcb8cTQaRzxZgWVH ABsajSdgqPLm+NaE
Efk+vMXwKJmq6N95cLdhWpbioo8+z31xdNO3R/h7PQ2JXd3rboPdW1h1ZIZf LfsyNA7ghxg0ex3/
5mW327t1yh7CwAgujKvQXvGa2q1uSU2fvK+e/03lZo8rybzmFXV2JUrh2DPA d3HRv1R3cVjv7OjK
tw76mM/dD7YNx7v2v8YVMZERZrK8vMYCyCVdwfFw5Ko6SmEEarKLiRem6hcl VE3yl5idFzsl42I5
eFK7f2W8ln98ipBS1Pik39YY548wYwZQBpDdcJ3/4IW2tsumOTOz+qxudcuw l5CyPWwuTJfeLcNV
krJq98wPYH6lrFd0Lvu81XlRvyJRRaaGzouyERCnKgx5ZcERr8cP0hWG69nP koOSepV6wyrVLoYI
rcM3R+JrRSMFUGI8O9OOQnYg27u10T2Wb0BWnI49YD88RrA++ZZX3OtszaXe 7RfdSWZ+D0x6bRcy
cmtdADABMXX59cLvYhJerKx40Qeej3d6jDNj2213ahXl58AnCr94MVlYnfiI J90cjRTZH4xG/27i
cV+OysRLQZ69nEpTJ1iSmsWRWq32t/LELsIeJIdA1nMgpCDtzaAxMThFbexU NZGp+Qxrk7OVeSVo
r5fDZvepsK0wJP6agr8UnatD4sY70/Fk6TfqbPg6fykqae3WrQRcKKcPjKaV 3t6ujUKQKojHh+qW
HMJ/UkXRYjg0xyEY3Be3i7meiZxycsrJKV9Jx5ec8pVxysmVJld6bq60dITP YOZcm19qWOSn5oFI
TKd0iGs0VgIp2mzN1DGeml/RiDYMg2112RB6N2E4kTVC1ghZI2SNPD5rhLYI yK4hu+ax2zXbu/e2
a8iyIMuCLAuyLGidg+wBsgceuD3Q6+TbA6STSSeTTiadTDqZdDLp5MXq5J27 7D2Qflu+DiH9tjL6
jVazSVOSpnzsmnL3LqvZpIZIDZGbRcqDlMePrTzarYK1TxLNP4JoJg+BhDwJ +Ucv5Nv3W0xbJUEa
9/l3wL1vyKrWxS/e7xcvykgpU16NmlZ+t1M2bSTnSM6RnFtROdd5IeTc5uYm ew+CDGRdbFhh8jpK
xkQnLSj2ghYFVxG3H8zzJDuK7Ciyo1bPjqKVIuL8B8z5lDztbrKCkqc90uRO OMyUPI2Sp1HyNEqe
VrNkreRptDJFK1O0MkUrU49vZYo8XfJ0H4CnS2tc99orpBwgZFmQZUGWBe15 kT1A9gDZA5QDhHQy
6WTSyaSTSSeTTl4NnUw5QEi/kX6j1WzSlKQpSVNSDhBSQw9WDZHyIOVBymM1 lQflAPmhRTN5CCTk
Scg/eiFPOUAoBwjJOZJzj13O1csBMkWYHx1foICGVUCRVtpWywohd47MHDJz yMxZmRQdxK/Er8Sv
D4dfSVMT5z8AzqeUOneTFZRS55Gm/MBhppQ6lFKHUupQSp2aJWedUodWhWlV mFaFaVWY4i/JQ1y+
h0hrQ/fasqaj56STSSeTTiadTDqZdPJq6GQ6ek76jfQbRSKRpiRNSZqSjp6T GnqwaoiUBykPUh6r
qTzo6PkPLZrJQyAhT0L+0Qt5OnpOR89JzpGce+xybuZHzynMj7ZcaK1rFe2A FXWoyDwg84DMg9Uz
D2gBhDifOJ84n/iV+JX49SHyK2lq4vwHwPmUrOFusoKSNTzSw+Q4zJSsgZI1 ULIGStZQs2StZA20
k0I7KbSTQjsp5KWRl0brM4sNtKDDmaTfSL9R6DVpStKUpCnpcCapoQerhkh5 kPIg5bGayoMOZ/7Q
opk8BBLyJOQfvZCnw5l0OJPkHMm5xy7n6h3OpG192vYgp+bxOjWkoklFk4pe PRVN/Er8Svz68PmV
Fg2J84nzf0TOJ34lfiV+fTj8SpqaOP8BcD4daL6brKADzY/0wCUOMx1opgPN dKCZDjTXLHn/2+dp
F3H5O3W0i7gyu4jkO5Hv9AB8J1o1uVfIEB2eIjW00mqIlAcpD1Ieq6k86PDU Dy2ayUMgIU9C/tEL
eTo8RYenSM6RnHvscm4GN9vRFsLyjXByEMhBIMVJipMUJwVKE78SvxK/Er8S vxK/Pip+JcuaOJ84
/0fkfOJX4lfi14fDr6SpifMfAOfTEcS7yQo6gvhIj0jhMNMRRDqCSEcQ6Qhi zZIrcgSRNudpc77G
5jy5E+RO0ELC6i0k0MGKH14005oRCXkS8o9eyNPBCjpYQXKO5Nxjl3OrcrCC FkZWS2msqPVNuoR0
CemS1dMl5C0T5xPnE+cTvxK/Er8SvxK/Er8Sv5JlTZxPnE+cT5qa+JX49Ufl V9LUxPkPgPPplNHd
ZAWdMnqkpyBwmOmUEZ0yolNGdMqoZslZnjKiSJUHHalCVj9Z/Q/A6id/n+LE KU6c5BzJOZJzC4sT
J9OWTFsS+STySeSvqMgnfiV+JX59+PxKmpo4nzj/R+R84lfiV+JX4lfiV+JX 4leyrInzifOJ80lT
E78Sv/5Y/Eqamjj/AXA+Hb+4m6yg4xePNDwch5mOX9DxCzp+QccvapZc9vEL iswlw5cMX3J5f6zI
XJJ6JPVI6pHUo4U+4nzifOJ82pIjfiV+JX4lTU2cT5xPnE/8SvxK/Er8SvxK /Er8SpY1cT5xPnE+
aWriV+LXH5dfSVMT5z8Azqew9LvJCgpLf6RhszjMFJZOYekUlk5h6TVL5oal Nz76kekyJKw9ts1C
u+97Vtj4iZ77PDjANcJc79VGC56dbhf/be90W/q/6vmp3drpbXc67e3e1k+t zla7tfUT686oj6XP
GIUmYz9dXpn9r7Z3YYOlEuTAVX1/oE/N+b90QPWciFjnP+wgBF0WGq7jjW/O B9HX85vdnjEKfDBb
I8cOs23gBPe2twvnv93rqPkHAoD539put1s/sdYiBuAHn/+nbwKHvYMRaO2w dgdU8F63yw6PPrJO
q7XbqIpqP28bLaO1z/9bCSzBlt1jevSnJv+rYw53aqO+/G9v7XR7IP+3uzsd kv+LeKac/8pjLnlt
TKH/pfzfanXaNP+LeGY9/1ifPNsUGIZhBoOwQv93dlo7Wf3fAwFA+n8Rz9OD 1wcnH49Onx4cHh6d
nT2Vjtkmn387aIILaKtLFJryY4oa8hz/8y1jy2i3WsY1WBE7re5WCxy54M9/ AnxcB8I31aJGcwTO
rx3YHnjJTfSc+7fN53sl8LIhAPrXCaDk2789f958/rkxsz764cARfTNOt7Zu zkX3dju7vHspTBC0
aV8Df2Rx5F8ulWMOKHuh7070JAPFaxoOggow1x/kQoR2cO307aYFLOqqnpYC 2hfj8qps79oJfG9Y
1EMFh825zl/VTYoBh+G4Fv5FKXBgw6ABYDnQ2PPMi4KxVUDjwK1qEySgObCH pgf/zW9xHDmu+pCZ
Ev2tahNXLsBXGprW0PFyIUYgbKC1EgAo7oSIczEMXw50gXTc3M/Q89R73oko QDEX5HKfYiy5rFcK
E3PqVMCAcRRmQTlyyKMFVU18vxjjKu6lw2e+HPTK979WN+j6pjU5JpmJLsMu gVKMVQYTDwcfpJqw
4H5Hft93p4YXowVsHEzI3JplkRlxp3Pq4rHQr1sysF0HObpwbjVRKFcUK8Ak 506CxG1WUV4MOPSt
cQFaetcLcdd6GQu3EigAcC6dKiho8NrhYiJVYtaaUa3jgiU59D2uI5X23+70 qrR/orFLgC58f0LT
zFnfc5vmi38RTir9ndaLql5hwVKEJcBcsFZbMGjaQ5ELx3WiWyOwB04IjA79 6WgG2la7p5A6j0HS
JatmUJaqsNoUFKfReqDhyKmY9eJv1q1nDp2+2FAvnwvRzEpMBY3zncWPNqhZ I73VIRq+19hqLlqG
ZrudyrHV/bvSMdMB7Zv+lekNyscnXXOOoQzfV0fK/mb5EdHg3QYbvKYIzNTo dmRPjGylMpaFS3FP
YBZILOY4usryk5RV8+JkczTiGzfVqxiyRBNKZMlMfUocPQ4zyYBmEv4ypyUZ QzaFcqltdOJx7LW6
MxtHXNe84Q25dnTeMbZj+7bXxtCG3fu2dM4/nqv2SudxeAl/A0kBHkg5iAfo t1a3vStX2tKTOLxs
2tKVLPjgDEdu8VeBQ/F3zf+rgihvSF9Gmfx6M3SbIIfscGSWtZUGK28wDVvd PMqeGhDVjQowxTrV
oBK1xdGXdORqE5iAz+uJ/GIG/SvnOnf0JAT+Y3pWCYTnR87lbTVA0fhLqPsP ZomQl5QepnzgXmt7
LhI93WRasyxIqagYzYzsVTbhXHp8bQZ8GUgYotmFhrk0ad+AIcnXW7Mz29ts tdqt+bWM60XhbRjZ
Q1Dabb3hRbQpgnyMm91eqvXt9r1bv4vCM26GzrRKD4qUCVinUlo7i5e+orOh 5fPOtup3FooUdwU/
lncWIZakar6Ud1cCyQ4ueiaEHzrtZOR7rxPfy6dEAi18VsATsn3jy8i/OW8Z u3G3t6Db250XwpGd
QJkXamKhvA5pX/t4XqQCxnbBc62AGYJ3Mbknlw9khqHfd3I3IvMLyIjGXIMj A+14E7ulGagyI1kD
uzZdx5qBszTb2S4GN2wPCLRvW/mMQATxwxEE0cGjo4M8Eiib58KemB54aByd iVXEfKCqadRhR2YQ
1oVFx7oQsO8CRcR7/gVAhSsq8vMN/JsXUpKAKPKoIGcFFkZ45nhQQnQTkEWW hQCvJrwQK7Atf1gM
UrQiIr4uyWpxnYsAXETwD8tNF3FsVS4LhBg9NdD4teCrHNTV6pNEclMimTDn Q+qixqDTSpy0HBj6
ll1C+HnA5aySV6JotbC4REqE1yoX/5i+wDQdSkpN06mk1JJ0U9IsX5toy7WJ 3Xavvb3dzSeXFKr/
LPmqLc7WAoP3PEpoMiCnqITbbtVGQm2m1AQvmkYNdmgGX/P1mw5UxEgaTM4G bAFk0okyqBq4C+29
6EUA23IivgTQzlkCWCAyCo28NbBZrAaCNjCcC/hff3y+ZfRivnqRXnFcduQ6 PbN4Zn3+493Rx4PN
4/dv9INA05z/7bR6/Pxnr0XnfxbxGE2j+dtb3xu8dbyvc2pDzXHBv632djdF C612u9vr/sTezgmf
1KPmP/D9qAyu6vsDfebG/+8O3h+/OTr7aLx7s+w+0lP8LGL+K87/t5Pzf+2d TqsD8r/ba2/R+b9F
PO9Mz7mECd+UWR32WNtoNV7xcx2b6mP8raO+vDcxC4uYd4YTrz6c3Q4vfNfp C4AqcvmFhTwVYQSV
70fB2FbV6Ngk+BziwtyJGV3tMUO9O8VAtMC2RHIyKHOUHEzbY78DeZ8dbbaN XuPoZuQH0eaJOFlV
jhuek2vImjdFQ3uFaY42GizXYfgFD16IWIy9/cC2eftFwLizXfgttPy6lSUL 8XVLJH5VbonGkfQd
3pp/3fJ0TXuMz9SyKZeeWTyrYf/1Ju2/Htl/i3gWof//uexO0lP4rIL9txXn f2pvbXWl/Uf5Hxby
3Mv++/8FWeCPpdl/f9ie5QeIC550texAx+atlnxgjwls5244ShurDATPsuAu reNFdaBxL6cOHC6d
k9kqS5DdWueZtfw3QjvCtKd6qrDa67+t1pbM/7eztU3rv4t4VsL+39ki+39J z/z4XxfYw1v31uM3
OITG2OFHiSeyhNKzjGcR819h/7c6W92M/O/tdLbJ/l/E8/Tj1Vjkf+2xdnev u7O39SLJ/6r4V4vx
MGSqrP12YyRvcwjskR86SCfGV8ez9i/Gg78c1zXzAMaBu38VRaPwv/eazW/f vsXU5A+b/YGzeeF4
zbj8sgfnB3hmzf+8nJYLGtd+Kvm/21P+/3Zne4fnf9zuEv8v4mk8ZS/7/ug2 cAZX0a/4q6n/hBd/
O7b+1mhc8DsF+u7YskO2z4yN/26w9BOv/Ex+EtSjUUXjixmI46pAdoYfgNuO lTZEQLJhwI8w6Dcb
/jgajSP+GwUDCYSZP7Pmf5y2bBu1/b8OJoBuY/7fXpvyPy/kmcf8Y+Sm3sY0 8y/jv7Z2ejT/i3jm
Nf8CSJDB9PPf7XWJ/xfyrMT6Tzdn/Web1n8W8cyZ/xOg+10hRM+cnkXM//Ty v9fr0v0PC3lWQv73
JuN/dlok/xfxLE7+J/vUpApW5yH5T/J/2fK/09oh+39Jz1Lk/6njDc5kkgp+ xeuyR+HHfRYl/4v3
f/C0/haX/1udbrsl5X+P7v9cyNN8/rzBnqf2gPBnM/UbX/FtIPa82ZBXE1VG I/7SaDhDDMUTV1xj
bKJxEATmbfjL5IdD38W7rzGzRM7Xt04YJdVlIwFF9hIBeQQEbINg8QOAV337 /zY32YUN9Ls5Du1g
0/L7bHOT9/OABTbm9QTceSgh8y9ZdGUz14FOmG6oftuyWgT5+aU9/PXlxa8o xJiSYi+bF7++bMKH
nzewXtOzGOLjRLdsyC/wDtmlHzC8cgaLfXOiK6x4aMQI2p41gd5voV09zsa7 +E8Zovp0YEe6iF1/
xivjyRz4XwPbw97YlpjQ8YXr9HkfmV6M8ew/GA4bsmRc2T8aT3Bgn0BFH2Fo 4uHwx54V+BeOl4yF
GkfmX/A4AF6oaDqeFI7EEzUUT08/fHr/+vTDq+P3538cvP10JD4l3eE/+Xai +NFsPEmKrLc22FoQ
o7mW/vVso1HQsWBoD0EGzrNbp++O3n04/a/6nZIF1tvYCYngmv53cXdghoGM 5tmb4/d/P3j7tn5n
BPx6B/EX2K1pfxb3BLjMH86zIwfvX394V78fHHx9C3HnqK0lfxV24q0N3Ata Frhsjj15e3Rw9vH0
6PDo/cfa3dHKrG9DT9wE07XMz8LevbG/gTGBYiucY+/eHP3n0dnHQ6Chs9q9 08qsd6E7lwmma5mf
z34pIsAykXdtumO7Rt9G4t9joWiGtumhggC9M4VgZU7o/RyxPsxJsMGrg7oC G5QbdOCWhVf+2LUA
Awaiwca6TWbZYT9wRlyjIaxhSFybo2lFsXjJtQvDZPr7ulitMRVS/+Ddf/AP v2meOV7EssKe7bNW
4VQUC+nZTUSVIljKNEhNkDMJShXcZwpSigkmoF04AYVqZXbjX6G5ljL8Qnfl jL7UXvcZfF2Pwth3
Cse+SBHObujLVe1SRp5r25yBFwr3PuOuqX0Y9q2iYS9X3TMb+zoWwjImQLMP JmdBtw7uMRUTdgvM
x3bRfJQbGzObjzo2zTLmQ7NoJudDt2fuMR8TlhbMR1efjwOPmejj8z65Lh/D Coc5dq79ILyXLZjq
EXYicK7hZ7oXuoP752fGO3F2fnB6evBfbL/x5Ilnf8vCgMP7RHMjN/hPqRjF DyGoxd9cePA/NeLl
v7XBw9/fU+PG5JADhVibvgdEglmBV2IYc2gBF2Re6sP0qxxJoAdtKccYe0CE ziW/rAXLrIsFIMMM
+S999J+lzOxTOxoHXlir44r11KIKC0d2Hy+6taZm/ruOSmrZZGBH6/ADsZXt P+M0hAtA68hFDrdk
4Z+XKfozXNsbRFe/sH/9V+eZpDq93sAOx24EZfVCfzqff0FI55KtCwAj8kXr 68/wxjfTDdcVGrLW
JwEfXVkhL/69If4nv3hj14X332c/IyiOFjgRr27xOLiaDmx8sXMBKHAE4qng KKzAPGCq2IEdLJ4z
cNB5o2IQQsCtf8XWtVdP+mZoT3h/e0yOSfLhlwQ45ackoPK1Bqjb1AmceKuB aSZgAsVfJkATxkkM
qX1JwCd0Zwyuffmlcv5nrBwT3c5n4Jd5t6Rx4qLaklygN/cBFWx05YSM5/pn fdNjIiXDGI03+MPk
Z93mgVtqZT4e+A19ZDZYnv5AfA0ODHJHzpZ8i4XgpRhV+U4x/34yAHMhJMHu 2BFg7z8QrXWOL1Pk
rVCdX+NytGJhm2peDsoiWn8rBjqDQP7w63I8ZaZk95z8YIN9u3JASAK5OlEI kpW3l965mimp/vbh
2g4Cx7KzfUxMC06ROR180vjOmqkNfjq0tcrPSsT/tHPi/9sU/7OIZynxP+9i +A9iC4higJb1LD/+
p9Xd7rbi/L/dXkvE/1D+t4U8C4v/Cf8Ho3w8TywN/TLx7ew/3h7d9O3RxNcb 44vlGyeYdQKqBrP8
nelB+8EvRfFAIvnYkRAt9woDEiuocklXOdvvkqTHTLSReNyl4TwNubwsl60v fdf1v6FVdWmbYEfZ
ITMDcNHHI+yVbe1x+LHLCzD20nV+/cdvLmjpuhFBiXx9Ki1jhl3APzi23182 oc7Z1H5s8bqPrUzN
L5uyA3wZW4zBPaKask3rkU3MvMCUev1ofw3zvK0VRzrxa3Iuzb7NsvUxfm2b FTJJPXqwk26wpwx1
RRhiYOPFFzMCU/liHN1r0yGuP541reIF7zJIaz+//3n4GdruRCh9M+E/PEu+ zIYQzoXjp2185Hs2
WU9RXxQ4s6O82Z0x001HGMWzMTIDcyhRRTxx42L6aYkHIn+4rn3HYumpk4t3 RYv1uZyBYmFOfCEl
zopyxSR2GZ44ttZdfx78ABXr3MAcS4pFGAeR91SJydyJR6QYl+tz55GM6lgs f5RPkByAct6QU5jD
F3fEXEyYrYyhcH+tclx142mNwXuwtC6dQWJv4ZB/vB3ZNepKCq2xxLCftL+m qHKycAHZiTG99fof
/QPVCWwH7ytbTxDL6+EGm2ylFP9nQAWB/y1kacuTr19NGAaPdhFr1v5fZA9H Bpi2lnbif4rzf502
+olb3c42nf9byLMK63/tbnty/a9D63+LeObJ/3jRsoGJ41x/sOx+0pP/LGL+ K9b/2lsT8r9H938t
6HnKtpo7zdYua3f22jt73R47eYf5XxtPmUygz69CYIeSRFjL2NltnZ9ubd1s sC28DHcDvsm1Qnb8
Cgr7wQizx7Y28L87BjtwXcY/hxjpYgfXtmU0NuOn0TbY0enph1PmeKwZDUfN 1TiTzNbNiIFbY7P2
M2nT/58GLtzhlfdi3dI1vQE/cogBBJ4foVcJXfRd7CI7jviOrWdxjF0MGpJJ dC12GfjD2BNjhohC
uIT+hvrIdB7iyPDxgI7jeHD73un/wpxIGyLumtlQvfMXdJ4HJ5nBYCxOGqbD ClOjwUaBf+Haw5Ct
d5gdBH4QPls2/zz0ZyXsP7r/a2nPIvQ/5ftZ3WdR9l99/39L2H+U/3Uhz8zv f+CmzMiMrpI2Kuz/
Fgb7JPk/urj+02rR/Q8LeV7+283QZepOh7W20VpjYKL6Flhh+2ufPr7Z3F37 t18bL+Np/bXxJPkB
0x/cMn7pwxrYkmsMX4o/m4WAfVxZFoD61v0XKwKDeuz1r6Bp4/fTo/PDD+8/ Hhy/PzptZuH4Dq5n
uoZlX4wHeKWMKAm0eBaZnmUG1h/vcHG6mdzjNj1GI0vdmCYN9RPBBSU1iYT1 qjI8AA2wL5va6C17
wjPPvO9/wDaq+L/d247jf9o9zP/e62yT/7+QZw73P9AtDg/ombn+l3f+6G1U rv+1dzL6f3t7h/J/
LeSpq//ltL5OIiVQB+LZil+raOJlk4OhyvSHuMjzK8oY8Re8lDWH+HdT/8FJ 8Gxk9+GH/HUIxUC9
4wutcd0y4PoaiZrD20HcOBSIF5nEz2bq98tmtoU6TaKJoG7JfbWwFs/A0hma 925PvpBDDE3xKEQO
Kv4uHl3xHZvmcAVFENcTeUVwGTze+2o4AJzcN8bJYKIV9WeIRlUeSS6bnR7c Mx/7D2SK1ka5/Aep
39rJ+P/bPP8vyf/5P1PKf5lOoooM1phlX5pjNwIfiBME3ve1xjCMx3KC/TVj 7deGEP3oJtzKWvHz
NwDjkVT7a3/7x7fwu/C1cgB9HdAvATSD/pUGij+LgT1XA/XcAkB+s/axFYNW DkdxLfKi87gqft85
wkMBDBGL993UvZqGCBTL1oZ83H9jOu4H7wh3RuIKL003tHMR4EVeowN97F36 SWe8YmjA9sKH6qor
d/3BEcZSpzqHgQC50EoAHQSDGLgYizPuX2hDtlUM+xFUoB1psB3pvfue5fBY MlVqfw1I8/zC96PY
W9doge/3XflD+3vTMJr8Ino7XOOKzA/ZpTl0XKhhaMqFj2Zcfw5iNdtxnQvZ LwDhAZz4R6Ykx4Bv
HNoR47z1t39M1P99TdgD0oGTaDxHruQtAL6yCmGEyWWeLMGmUQ7sywKcCgdY kPwrAD7M6XqyVCPw
femE2KmkeHYtJz3IxQ3+nks0vTk0MkFtd2okV1DkdUKQi3xbJqvykJOFxduy wkXzlSExIbMiXp0s
73hOhKpghGcqgFTiVSExKnmDKQyNj/ZwpLeEOgTfveEbC9+VOaLIOjO6GXBF 4voYT3Q1v12hr77L
GvInH9WbzPYh9j20CpJav1eaTudC9M+uS+WoZfqWKatt4+SU0Xd58svLGz8t MCUdz4x0JZBp+mVT
kMwk9WjkwpzL/TXlHARjD48BrBX3WamTlIKe8GN+f/1RadcDyxxFoi9lGIna xyPLjGwuPBPaVqQe
+yL7a9w/46HmOBqbjrdXGiDPD5RhXhrTY6IJFjrQjuinZbs2vJESXht/NYHD r/Ct5Lvp8fRfTHQo
ZZflAwxwaTvg8XsjM4gUs4m4eqnIkuk18ilGR6SpqFa2xH8AAjhqEeqfhGN0 wqnLOWJCYhMz03ZN
7mNSDw6lTw8qHQ1+iXnFJBQTDu6EThDL2IOmwuSjRjqHgY3zDz2qQTN8m7WK SuLN2CpyyQLGxgd/
nzY8xFdbJAmXex5gHcX/L1luU67FNHFy3vp9Pq3qY8q1VDwqdl3GXuQM7XMe ZdZqGdcYTtbqbrUS
u2VuCPjhwBENGxjqdi7a3u3sLqBt3Gzy/BuZ155joTq/3ektAAGxyuNfhJMj sNN6sSgE5PRzYQ5F
Lng2fVBnAyeMgltAraNRxVa711T0EoOkS64o2gsiJg2BLFG3Ogsk6lEcBBlm xqLbWQQedyMtLqIX
gBjYc+AzRxhHOYHFkhnPHIOfl5mxhVKOORpxJb0EiYzawMDIZUeQbdvoxIPQ a3XnhIFIfoDNglI/
7xjbsRrotdvtna0Z9/ycfzxXrZdOicqyAFghSSBWIEZa3fburLXzlFhJnTl3 tEq4xxbb32FKcfda
2wtHIM3AS+FdsPQ5UhmeWaCovzYDnn1WaJsl2FH2DWYWwWXQLEX0Nlut9sLo kjs2t+A0DEGKtnU0
Fo+B4Tre+Ma42e2lcNluzxiXu4g042borJxYE5iFls8xa60QZkLgfllJ3MSo 9a9Mb2CvHHJg54FH
jzvf5y1jN0ZtC1Db7ryYscU5W9yKwQ3bu8LMqdYqD20J+kvHOg/h5WMF8voi AEUKWnRFabUcQSGk
wk3XHwwwuHj5A8rPwvFqcjFeKobXputYvAKundtSO+/iRZ3bM3Z27iTRbcuJ uDxvr5A8j5FajN8B
JG04F/C//hjMyl48Sy90ey7eyhWxBHJbRGSC5z4CvLJsEVCAS/HXZp8vxpcu C7NL03F9j5+/jHcR
tciD72sYToJhAvFXGTbwHVe5L8aD+H0cfABf5N70gRedivWH/TXPX2OpTUax FzixJwmlRXeS77/r
+6Lxlkbqq9r4fPJETI7aNILX/HArgmtxCVCN+hVvScYbTd/VDMeoqu3xzKo5 k3Bh0E/OSjQBhyfN
SSzkLspv2sYbDpvatDIMA6BCHa8p9rnyu4wikv1cMPV/+4ce1fH95zu3/JL3 ox8TJh4gZ54NPmto
BvxyBeHBKsrEiHQW+VOQpUh15QMhfgucKI5UEd1OhUvw8efvn7y0b1LxEc+b z3mwoxyunO8yF6Zx
FQ2fq0HVQimeiGD6yQ2XnK3ZZJNZ72seoNC3d+1v0fiVIl93X6l4BwyG2fjL GRVugqnvU40VFEht
HuaOVtwy7xperaNGh327AmU8HOEGe/gVQcS+a01qyUTTZKglM5SAQen46GFy ZZvKkp/EvQWYMtSz
GC8L/AOutYV7huKu4ak2nuX+IaDvuLhcooUeSGorG+LEAJzYRY4/VXVdsny2 94Vopaa1cvLzkdO/
FuM3sRGenSAMTijaCp+k5wLI2lvUeWLivnXeXZgU00MBl1SIyZXpl4pRye1G fNapojdKI8r42lN7
5Jp9O2DKmLl3//TAXUkbVYwGBJ/HZZX0X8Cgy6P+elJ/TrQkNcgEMdUSJWBG rdA4LniEKm2SfJYr
MEJLGbB4IjA7rFehaRFkyvAt7bo+ZLMNoY1RR+OUsz4P67Fyg3WqFKuEnkLb ZUrcM7Jq1nVO4Dl9
VBW4WDAAV7mcpCSvChZMz+2pKCmugBKNyUlJdiw8INzoBF057O0Z37g44XJ7 HqmY1jTTRvk/JyqY
OkFLdhmXBdzYT8Jh08twP3uEmDreJQ5JlViCuTAEohUsIcLSTCRuvC8rMh2e kFnRvFzbuLv9ufgo
x7TxucxIyIJWFWpzaVOM9x0lMvd46krkpKUJr+2eQqQo5DPl8AnTr8Lfm1Yc xUcQH/C5w5piTF1R
cadUTvXz/7Q7O1vbP7U62zudDuX/WcQz7fxXMeYbAZiikynyP7W3ex1x/r9L 87+IZ17zLwvwk8BV
+R8623L+WxgntcPzf23T/U8Leeqe/5XzKZO+4M5GTUpYk0Vc88J299feZb+z DFxmRQPULF5PpN/Q
MQ6gnqsoGu01m9++fTPsG3M4cnm8alODg6Kixj+PEDPVDnudvezjM29BLyob jRPhlDYZQ2UbTNLi
FjWpZdppiEuYYBRDu7Q5CZNt7K0sWtSULCYbEiZXksGnznyuJeCW/81zfdPa DJ2/wHpqaZ/43bmu
m/MlntgWn9jkw9jDbRTNCAPDSpLbAzasHsizEvlfKf//0p556f+8PHD0rN6z iPmvyv/X2trK2H87
rQ7lf1nIk8nrp5ntpHp/hGde/K/nAazi/167k/X/2pT/czHPAvL/SZJYWBpA zDon21xwijyt5YmE
dyuaum6++l/kgSvn/3a329nO5n/fwvVf4v/5P/PJ/6bWdLJp4PTUKdlkcJOZ gzibZRK8KAOlIkFN
HlhuohoFeK9MNTAEhkpJlBu/5kUM/ic2vGLOWBN7TCL4u/4+cRLMHMkIZrk1 mO5YKu3dzW6SZyAN
puXbG0RfC4C0XHv85J62lZgal5xhUYKjNOIoU05SyWVCRLVjlbDJ/hUMcGBn 97I3dHQ2tCnbyLRX
HjgSV45RBtJyTprM3clNIVUnRKs6DFTkFlL77qmYT9mN6j13yaRGDaQnN5+j dDKxiX12bZv5XpGf
M8Aqvbk/BWIFkXKzwYpXPjVK0+eekuSANML8y9pUUZyJahad17qRE5VQIKJR GGuyOUfEf8/dwi8B
TIWTlMBVRoQwx4MXTnTguuk4N30oNDEah8Hq36fuaLr4t4rqUxohF0LLfvq8 TrKuHOVZHbohCawg
aVdeZ6e2PlMxjjWJ4Z7x36m5K6Yt/HzP/mRpsT7vTXQkhwSqg4rSXVFmTw61 pINLZzIC84rn1pa9
akZ0O1YczC0LvwH4ExnXPYvO6lvoa4yFtnv5R3pvVLV8jKS4xsRU8B9VDe3x PbgNXs1GAV3hhgf2
KeTplc95NubzVP7kIvstLsmNxXOwK8/RAK1VZBD449G59t98pVPQRHWYo4Up npyLsTD07xPsKGMb
RXivmuL7WmGL11wzV0NVWq5aDVUpskk1lf4+YZUraC4wciRVNiJxBnoNBxhp bSJEMXcYpz+bNiPd
hixRZn/PnR6nsx4zMbH30l8pC6Ou+624VWAgBbW67mwFyTA+BjMNBd45WPaO BJh3HGYJ1FfLhs8n
SN6DmVPjqhIV9Ha1iWqq0z3Tauo7HfKZsceUexhn1lprXo0o8plX/bmnoOat mQTJTbGe8xAOL029
67OAU0z3nSg17iVTVX7+dTZO+KqaMPWIt+Qc66PXxwUj9EAPA9WVBDBqrrz+ Vq5ChLWj+6rvf+1k
9n/b2y26/3Ehz9M3gcPewQi0dli7s9fe2et22eHRR4Y5rBr1juHt8/9WAkuw ZfeYHv2pe4xZJjqq
q1xQkMeXAFbGf221Mvzf7W71iP8X8dwt/uNEkAP3g8DYvHQG6BVNHxUyNEXm qbR1od5mAif+9o8+
TJY/FInbQi2vG6ZCGl649clT5B8eRF8NuTCdEz8h6zzjhvd7eBdbCdMyQ6q1 ZI9hMn5iCTbEapz/
6Eye/9ii8x+LeGrK//txWOY+WHpW51nE/Ffo/512Zysb/9nrbpP+X8RzN/1/ IMnhPio/J17RubZT
irZm7ZsyHdKx9X0zLXfi5H51AhprhEbWCrKcvIc2OAl8TG7qB0boDJI1++Lr cyW/3eKVj8CF2bsw
Y8b8jst5uTWotbbMLm6m4u9NTHLrulAbTPgbfXW9oL44zjWuUm8pvVZSVEcS FFpQSQxQNOhAKW/G
rnuSuZFUhf/KYXqLZ87xl0Zc+b0DGSBy6aYuH8bctK9s6A7f+AcLVwZbfhqB 6Rl+lTcxp2xX/rUo
kgDjpy4Df8jrGQBCHnNlgueSBJx/+4dYqsOOyAxLvCPn9o0TYjiSMo/zwQqW 2gCXY3mJZnqNLMze
MRtq18tmYLV29LmcbL3OOqvEiK+AV/U5Nxwtv8hEiFnBME1z9WPJSOvdQ/o5 8qxCyimiL4ZSAl/J
2SogtDMBlaE2fCtoLbMroMsh3oLIw50RTjAQ4jh+5hu+7LRa3zFlb25h8Rq+ w9uq2TBdxww5EBQx
+C8o+NW+Bf8usOMP6gUm+MZ/R2aYlIrfTD/uBd5m8X3EB0J+nGBS75vED0zd Qmz/zxjEOYOq21zQ
6kWgA/ihg2FaUeAM09u1NS4mzkcg24oufIs6JEVrfoWx3J1rl0pRmOiTrgs4 JzoBVqN1SRUwA6Ay
eUFyLBQz2iI3YiCngny4jPLMg9EUTyJ5i09/TH/uoyiCK3PHfOVOR0ahf08v SlSgfYedwenwLwhC
S5kJORhnVdynUR0Nlz8U1apuqlyrqaiMuB8Bxg3g2sKkEZQyZXPtNOYAn3GJ 6Jpjrw/Deowv4IPA
OXkvVZzPgf0Qbz3IT6E+wS7ThKZxCSCGDupVEbiq6lw7carLnS8BK5U6OUcu TpXPVF25oFKzL2Qo
pIzIN3anjYUe8U5rm5ZTDka6usnxSJs8ubJvqUuX9MzgmWb/VxLM1BvAVfs/ nVZ2/6fd7dD+z0Ke
++3/SoqouQGcEji0G7wSz734P3X4olgaTM//2x3a/13MQ/z/Yz/z2v/RA0Cq 4z+y8V/dnW2K/1rI
c8/9nwNwtw9/uACQ+++Gr0wEyGrEf1D+z2U9c4r/o/CPB/IsYv4r9H+3tT2R /6u7Tfm/FvJQ/AfF
f1D8B8V/UPwHxX9Q/AfFf1D8x8zjP1Zmr582dOnJPqX+n1jZGwfcQrnT1X/8 4UH+9e7/67Y68L6z
tYP7P3T/2/yfKeYfzLcjecHrdCs6Ff7/Vqel1v/b273tNsx/b2eL/P+FPBnH Xptj9hrUxcAEKwut
gQYTZtX+LB5uhskKT8dorQpnKE5pzcBkQWclvlD4wkZzGIkyYnmPXqHIy6jK Go7FvjnRFbcEndgm
jPwRc+1rO25Db8JQVYoajy/1yizfDpnnR4y7IsxBtLNOeRzSpZXTawQDXHir b6X7l1tkAzH12K0/
ZkMgU7R4rh3L5vgn3RY1Kj+SXdwycGLQchBZCpXpJQ1J4TEXP9pAHlgWzgN6 jr8K6xmTG9pm/6rG
6OVVOFPayab9VmSrUy2b3EEa2J4dOP3JLaRUOnU2abRGtyM7ayevsfx86Y41 7RIWr4nFO0JMM8TY
3FhPDgLMJlM7WpxmBJulLvPGSF2nP3ZBVPZ1pRCmJvjjFTjQjA8x9PWW9VWe LPEqsq2kIeGxhmwd
h8xCNsqhmNhK1Xbhvj8DBCM2NG9BRISAOpDpKLB5Aq6RL9gEXVLuP+fTtK38 6pig0SqPaRlr4m9T
XZ2btJkXk2R55P57pFlmypmctZQflIhE8i5W85nC/kttvk9jAZbbf2Dz7/Tk /U/tVq8HfgLeAt4l
+28RT8b+E/cGhCO771w6fSkmRXLDJLxP283x/NfiT3GHy6wF2N0MxKTs3U2Y pI5Z9ie7k5GYLZjM
OrvLg6nHMk6XEKPOcOQHycGKTDXfhVlSaCEVXuMwaUKxzMrqnKZ4lvWl89TZ 0Suwsg9BvoHW91K5
+/tXdv8rT0H4im+RjT3XxuVlPMfxKs7ij3WFQV9bscNvn07f8vSEYZS3JWcY TTxytYkGvkiUKtbf
xp46YqI2q76n0teLFKmytXqVll1Uk+peZndJkY5EIllLjXs/Wf08Zv4QsWQ+ t+dGYgdG7JD1/QC7
zgIbbDoHh0AXCdLo4uwiDFQoHvLKoK6P5gDsTBxoGD5rXrycJbR35ohnpM8l MfgYpkmMv8lbHc/0
JBYK/3508FpRUv86ZPC/U7mWjEVgTHy5d2MO7PgtQJRQ6pCjFZkDBa81/L0+ hSV9ydu/jHubUF0u
GuWtAZLJCOMWoXgh28UBKetkMzUcfXG/H6+DiS/Q4YI+z5ZuClIVK8rwfPGi SkTXTEgrwRXZTJHb
8y1m0CzY3dDGNr3RLu1IkRa0MMNn/T5oqEz2YEKe1kctK3MFItkbQwrWdPJv EHn+vPk8SYyde4cI
R3cRQvUsskfcq7d8MGpAOtq4JDQeLUIQgid+hm1N3KI2746al+C+yn7i+oDq eIQrF3IxjE+plEwL
GQw/jOLRyLmLY9I6WYjSzaGPSzvqX6WHKTatF0M1bxCDJVHNsnsPZLKc7svZ l8tz6RGQC3QLMZ9g
/v8ulwiXRALLHwIgAn0McnKMC1NhWSJCJqNPhgf90eTCozxPfFG0I4OQlkQ6 KzswQFHLGpkMzcRr
zwsiCBWfvCSKWFK/Yb6X1vHMhKvzAosSAKK5ZU/3QnuN3L3Ubid60gHnGyzY hfWbr1IX2NQZl3Gh
4wL/xc0TbWTAXxy7i7EiseWFUwL8dzS+cJ3wajmdlo0vpN9yp0PtHd/xWcCg 6JsyPP70ymdDsAL4
uuB/qWgSsclzy0zVIcxlxBzv2v8qrBm8XYjvSmT4iPZuH9Ezxf6vsG3rXvqi PeX7v532znY7if9s
7+D+b7tH+T8W8jyd7dN4yg790W3gDK4itt5/hmlEtjbwvz12/OodfAxGvoyn wU1lH7V1aEAxzCTA
i4WoP+zgGnduPqIQAoob4BIxwqOSMftIr6Z3i2JqCO5y4JhuCFWYYIAOTQsg 4l2IsWdJSwXAhqGK
xzkSW3nsBNVHn711+rYHP6/bRgvq+Xbl9K/iZoDShTDUrw7e4NjAy6QpM4Ki V1E02ms2v337ZqgA
fz8YNHE/1W3aI3fzut0yrqKhC7B8rDxRpR+Ee/Abn+wwbTK8Vwu6yA5OjkWz w5HwKTlAY+ZTWDCx
J7hQb8M4hvLA0QVOwJX/jSMF2iPAQCdm39j9cWRr7jCU/Xg7cvCyt3GIxT3b xn1591amyxP3MPqu
63/jZnQsYuSY6JGSMB6yKVyxC3l0JE48b4r7XAPT8UC/4Uv8A6xD25L1+H7U d8EpwySCjMer8brF
DY6AuxSEcR3rkcD7lgURnlx6JuoRcWFg4HDEXQwDBcL6hx9usG/wP35FdjZO DmoXo8Fg4qGaD5cA
MQ5CDFy7VXQpIzdDxnvYNz3wq/huReBYli2CO0Ft/4z9hDqgyBDjG7Co3NMC bDybrdvGwNhgm6/1
kdu39pqSKBvpSWYnpx9efzr82Dw5OPxfB38/fv93dvjh/cfTD29ZmghgZqxx P9qXB40wjlVuizDH
auKoNiO/aUiwBvhF0kUJ9nGjBZo9s4V5zI/wyF7L4zfwtwlWiOO60oJMzkrK CmN60s5zimNC+w0k
Mg6JP7WqYACB6HiAYSYSUdRhNFLnjfaTEeL1xXG1XJJIyQDVStSFweuPo9E4 aU8e3gEB1sie49nP
Hm+K25mWiLhohMJ8q4xLIvbzv/wMFIT7adg/VePPG8lbPKkFsiOE8m8wEObG RFGywaTokXS9D1y4
1dkQ/73Z7bF/YTwWcGPoR84lvgH4V7cqCogPRIzG8w34v8ZTxSL78IL/fyN5 Iypjg+jrBuOVpdtl
8h/R8n83nj7RC4xGffYv8DJbSw4ovD3vbac/iC5oBULfNQMnjL+AbAj62W+8 Ov2L6SR1cYz426uR
1sTJwfnp8dmh/DQ0+34IH/tmcIHqAwo10qN48vpI3h0b8hBVxRXrghmeMdy0 AqEf3PKpTUhaDaza
cUd5exaHgMOUiLlB5xTKciLtm2PUftAivOWCWLTMG5bUnLnynutX6JjZlyHB KrZ35JoR/AblWonW
IPDHo5RRGSq58JFrgADUeUYqGPoYmXjjLlKZvGQXWJvj50X/2xkZohZO9yg6 Rb9ELzSMVDgv9kHw
M36TwSIKB67uLy9tPBCIwsTDhhPBE77hYDkEuymRySdc9VVQMDxZIi4uLok5 BcAmiTpdQT5xF8Bo
RJ6GyBJ7+msu0adBcog/hmg8kUoByRNFyCVX6d9MTwgWSY0o+WzQC6Z1K6jP U7YDnpde93wWOpGN
K++JiAdtLUp/4pC/o5LfZzzpQiPdKNb4u+eO4m0gNKv6vmVz6yC88scg5S/w CP+n07c5ysUMOa48
ilxeDx3YwBfIv1AiVDwh0EFOkDhio/sCo6df4G9DNbr/Mm5+HLi/yq9fOvgF /6tSdqgvqKdc+GYy
8Zd6rxr6cHmJlsEB2li2xbmOa29sOh4x9tJPgTV/BatWGKj2pAJVAREx5kKI 4+FV/tf3J0+ePB17
aJhwLvJxOUEtHCJf4lvJ7EmtWJcMBONn9hP7RmdebS+lUUI/Pj/nzs27xlP8 E2lAjXdy9hyGDf/5
Vb6Lz6G/VH/FZoACSY6jJzD485sfWL8CRgfBYCx2fRAHGz0XX90YLi1kdBoa 8BPzTuyXFUH/VCsi
U1VgEe4++EIMc4mIQ4P0xwdQl+BcRQuKYTJwhQvqnGMOm0ycIlIyNyFWlffz LaZg2Fd8lLYkX306
fvuavT94V2hECmcCJbWlgmsAE+hrIowzW/CmClBATlOuhjB/JWhkfgV64UGB RiMduLM/xYXXDeGp
cMNU2VmfpPEIBmt6c1jyMlO+DSgbTds66JBybXrJjjfY+w32boOdbTDDkAhi O/vH2OLx65Q1WaPN
hkx3s//RlovhWA+PdIq3HWvW1UiCpPZlzBNi9t1IcurwUXGG0BRYi1PXH6mS +63WjlT0sUGi5Keq
FPMNOJcOyAhOxZNexjd1IE7xt3SObM0IxWkeoygBIh5ZtqG3yaU2NwxQmo9G rmNzPptoCUW25fRF
REB25WtDQ3RfiLIbZBToRt8+FD//Q0Hsv0xQm+gnyoojj68fNHGBwVRnsBJF JIYiHF+iX6MqiLHk
ugiNOSOu02Cix4lMlYXRblJjg6sbAfeXpZTJCGQ14Ezjf3kwSIqBM16pst/S QuDg7KjAg4xN02SD
nCs5tSLTj4OhOKv/DnzLuMsOts4FCD5cjUFTVDroQmZk1wDQAsbIqsR7EybD bZSJ8sGFiDzHP+Mf
QXVAHEM8XHZ6eIJ0g5Qi6HPTAYMm7ke8SpHYDJHuRQqyDuxrxx+H7i2vWC5R xEOQ7hs3hZFQVQ2B
apahhaA5nbwHVrxMhphathuZfFvSaDS4WcGlofRxN+Upg6aOeSO1ZCAjxON1 g6cfwuZ/hk1M3dH0
Yi9YflXnRgTrTVTqh/vcXuU/voX7YG/yP9Gm3kc/sPE0kut9Ih5aciDMOLA9 LhSmLUOM1QQE5GgI
ekn4wheD4oUgHNCwt8ZBeu4FhOsMnciOdS2QHq4/glYUYfJqASKutylFRSqc oyEMG9t6zSO/ba9/
ywOpYx1Z1S9uPNpgiY8zxIPbqkh7Fp5U8UfckBritK87BrhGYIqg5TEEPY1+ PWDjWWg58SOI6Bq5
dgRD8KyRVG5AVe+ghhi35FywWEVQ6waKZrnxKmkRTTg8CiSHQB9xtSTBi8O/ yULExW3KTxS2ifwM
1Lz+C9L0HhjrZsInTiiV5x4KoM0JJlKJklBg84UVIQidUDaV1Rt7LF6duvR9 QxbV32ErpmaS8Pqk
BYXDonLr8HIxOYTji7hIHp6mwgA9kw2BbsA6RpuF0a2rMA03NLS5D4OAgTng R0pvcLU4mSUw/NQh
DSF8JfeBn7H/EnwFccRJcqTlf/Nc37S4d/SrAn0lzYeXx/yEqhI8MV/wfb70 cZf9+PwLnn2JJYia
1M3keIzKxMedYgyHbmTVw7uDE/bm+G2BilD2IaehPh9IMEUdZMzDP87wsALn btR53BpIBW9mTpEI
vlInSFAtHKfdA144VVIU1I6dNOMJBQf2yvQGSkHHJz7UBqpaZsiekxQThocV xISp4xr7eyO+0RHs
mZ7v3Q5BJfwmVQ54U8OYOhGZhjq+sK/e4otG5szGPh4SQXkjzkYkzYnjDfvX ulWXmhV2enTy4ez4
44fT/yqalqJZSewiNlJbBM5fakbikXSEvAs0olckjrayEl0pKc6VOpez/gUy IpqKMD1g4UgXopga
Yu8hXjOdWLSU6k+oUFEDCCyYD5QjcjJx8PiSvei7tFy5uxHJJSvB53z9PWf5 VaMk0EReJKzGddf5
ml6Yjin3WazB0YMQ5i12iDcNrzTDRPQWJxY4g889+Bh/vN+/7mBW1XarDeAx CCcNJEQeaizttgxn
/n7wxwFM/7sT4M5T9uHk4/GH92cshwwmpTG31Ar2UTJOki13U7ikAm4M2O+v /1fz99OjxtPUDs0+
Zpi7No0rf8hTZF00Rbm9yfe2yDYX5n/+Eor0dzlf+gUfgNODEPk39yvY981w 7I2+9sN2uxjE8kKv
pAaxUmOZkVnaCuB4LlN/BAiItB+f0IVR0zR13tCLpAzyqBwyFKc6DVJxngwI 4QuqSHuv+PvNU/t/
xrg0esSXIKCZI+/aCXyP6yb2KV7fQapFk0w7lGcnkNJTQdkbjkd4fLXx9PD1 4WbbaDXf+NAS7wH+
3E/UsphuBdhOA7b3wRo9+7vTfOd4znA85GUnXrX3m+MwEHN9PeTrAJu9TRjV xlMYugqAzhlCdCoh
tiohtishuoUQyFkcpFcEovNGGYjig8bTE/DhfM90sW45lplXnf1kgtQnsAWc UI5z9psslnxqTxRr
53xLEEDXUIYkaeu+6T0BtYIDJD8Q8l4ZOl8sbv0hbTfg49ENOLM8pTEeysK6 /1Oa2kCWmLwH6F8d
4LJAEQzg16WfXqYVy4Y4hP3XCHIMEMJqZvkVXpqOq0dFcpwxM0mgYQ7y3FfV voECH7wjfKP8aCZX
A/wgXg4AFXDhQ6Pc7s8MhKjnDwGR1HETBSZmZxwnGVz0UkooIGLJWX9fWtXX ZoKtUL44qgYuiIu3
B8GAT5cKiEuvbahlRrWlzQUz91UNXYfKyRKzKGrme//Km+PiwvL52IZy07iG RMKBQ3A+LmeibZjV
7ApOQ/u+D5xVuzsXt5HojDT64iiVxfXqY2xtZntlNDQA0a2qEL2753/7Z+0Y o4r8b71WZ0vFf3Xa
7R6P/+rsUPzXIh7K/0b53woG8uHnf8NWVzcJHO4amgP7TJjDRYngVhT56MoJ rBMTSrxV6/IPrAdf
Rv5N6dgLQltR7KsyCK426SfYH1m4NlI2AZQJkTIh3n+Wp0mFOCkZJnIh5nDW lMkQdcK+a6bGFPPM
NV/jKueSnA63XK27QvgVK1ZKyEkPPfTQQw899NBDDz300EMPPfTQQ8/Uz/8D 4RUw7wAABQA=
--nextPart24128817.3K8mAqcnLh--
Re: PDE build problems with enum [message #1386139 is a reply to message #326347] Fri, 13 June 2014 11:06 Go to previous message
Hi Florian,
Did you ever find the root cause for these errors?
I'm having the exact problem (it builds fine within eclipse, but it fails with headless mode). We also can build the product with Buckminster, but we actually required to use Bamboo.
We are using Eclipse Kepler 4.3.2 and Java JDK 1.7.0_60:
[javac] 1. ERROR in /home/bamboo-remote-agent/xml-data/build-dir/ADVOCATE-ADVOCATE-JOB1/gov.nasa.arc.advocate.egsn/src/xxegsn/util/XxegsnSwitch.java (at line 0)
[javac] /**
[javac] ^
[javac] The type java.lang.Class cannot be resolved. It is indirectly referenced from required .class files
[javac] ----------
[javac] 2. ERROR in /home/bamboo-remote-agent/xml-data/build-dir/ADVOCATE-ADVOCATE-JOB1/gov.nasa.arc.advocate.egsn/src/xxegsn/util/XxegsnSwitch.java (at line 25)
[javac] public class XxegsnSwitch<T> extends Switch<T> {
[javac] ^^^^^^^^^^^^
[javac] The hierarchy of the type XxegsnSwitch is inconsistent
[javac] ----------
Previous Topic:TextMergeViewer with custom diff-generator, or reuse its visual parts
Next Topic:API Guard - what is it???
Current Time: Fri Jun 27 11:16:53 EDT 2025
Powered by FUDForum. Page generated in 0.23201 seconds
