Home » Eclipse Projects » Eclipse Platform » Dynamic menu contribution to view toolbar does not work?
Dynamic menu contribution to view toolbar does not work? [message #326337] Sat, 15 March 2008 12:32 Go to next message
I desire to contribute a submenu into my views local toolbar. However, the
contribution never show up and I cannot find out why. Is this supposed to
work?
<menuContribution locationURI="toolbar:myViewId?before=additions">
<menu
icon=" platform:/plugin/org.eclipse.ui/icons/full/obj16/warn_tsk.gi f "
id="toolbar.verbosityMenu"
label="%verbosityMenu.label"
tooltip="%verbosityMenu.tooltip">
<dynamic
class="x.y.z.VerbosityMenuContributionItem"
id="verbosityMenu.contributionItemProvider">
</dynamic>
</menu>
</menuContribution>
The CompoundContributionItem implementation is never called and the menu
isn't visible. How can I make this work? Any help is appricated.
Thanks, Regards,
Uwe Stieber
Re: Dynamic menu contribution to view toolbar does not work? [message #326612 is a reply to message #326337] Wed, 26 March 2008 10:34 Go to previous messageGo to next message
You can't add a submenu to a toolbar ... menus are for menu: and popup:
Or are you trying to create a toolitem with a dropdown menu? In that
case, see http://wiki.eclipse.org/Menu_Contributions/Dropdown_Command
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Dynamic menu contribution to view toolbar does not work? [message #326654 is a reply to message #326612] Thu, 27 March 2008 11:56 Go to previous message
Hi Paul,
thanks for the clarification. I've been looking indeed for creating a
toolitem with a dropdown menu.
Regards, Uwe Stieber
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:fsdmkq$e0b$2@build.eclipse.org...
> PW
> Paul Webster
Previous Topic:Tooltips possible for EMF objects in properties view?
Next Topic:How to disable/replace eclipse logger implementation
Current Time: Sun Aug 31 00:58:16 EDT 2025
Powered by FUDForum. Page generated in 0.11826 seconds
